Old 02-05-2019, 06:25 PM   #1
Forest City , North Carolina
Adjusting sliding door.
The sliding door on our 2016 was out of alignment and did not look good. I move the upper stud in and the door aligns perfect. Problem is it put lots of pressure on the screen and has to be slammed to close completely. Anyone else dealt with this?
tomhamrick is offline   Reply With Quote
Old 02-06-2019, 06:31 AM   #2
2017 Interstate Grand Tour Ext
Dayton , Montana
Never worked easily
I have been tempted to remove the clip on the door frame completely and see how it works. If it does not close right I may put a magnet solution in place of what is there now. I will check it out again before getting on the road this spring.
Pez Vela is offline   Reply With Quote
Old 02-06-2019, 10:59 AM   #3
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
This thread might help ...
http://www.airforums.com/forums/f240...en-165207.html
- - Mike
Old 02-07-2019, 08:44 AM   #4
Today I removed the sliding part of the screen door and left the fixed panel. The Sprinter sliding door is no longer in a bind when closed but I still have to slam it pretty hard to get it to fit flush when closed.
Old 02-07-2019, 11:02 AM   #5
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
TOMHAMRICK - I notice the screen door on the GT is different than Lounge. Mine is like an accordion that folds away all the way. I am not sure why AS made it that way, it is flimsier than your rigid 2-pc. screen panels. But maybe the accordion type works better with your sliding door? Just a thought, no idea if it even fits with the different furniture. We never have issues with screen door binding with slider, but we also don't use either one much of the time.
Alex AVI is offline   Reply With Quote
Old 02-07-2019, 07:59 PM   #6
We will leave the screen off for now. At least until spring.
Interstate Sliding Door / Side Door Lock Jammed Pondiki Sprinter and B-van Forum 14 11-15-2018 11:15 AM
Sliding screen door for the sliding door! weirdstuff Sprinter and B-van Forum 29 02-28-2014 08:19 PM
Adjusting Weight Distribution - Equalizer campadk Hitches, Couplers & Balls 33 11-06-2006 01:08 PM
adjusting trailing axle and towed cars monkey mobile General Motorhome Topics 2 04-22-2004 06:20 AM
Adjusting burner on upright furnace Jabba Furnaces, Heaters, Fireplaces & Air Conditioning 4 04-15-2003 06:16 AM
