Old 02-10-2014, 05:39 PM   #1
BikerBill
2014 Interstate Ext. Coach
Poconos of Pa , Pennsylvania
Adding 110 volt and 12 volt outlets
Added 110 volt and 12 volt outlet up front near counter height. The 110 volt is added to the existing 110 GFI circuit breaker in the electrical panel and operates only on shore/generator power. The outlet is a Hubbell 24PK87, cost about $29 each, with 2 USB charging ports. I used the Hubbell as it has ample USB power for iPhone type devices. The 12 volt is one of 3 I added and they are all on the same 10 amp fuse which I added into the 12 volt side of the electrical panel to one of the spare fuses. Since there is no “depth” in the wall cavity here due to horizontal Mercedes supports we somewhat surface mounted it. Part of the Airstream wall covering and paneling was cut away so the surface box does not protrude too far. At a later date when I can acquire either matching “suede” or laminate it will probably be covered.
We added 12 volt and 110 volt outlets mounted on the driver side forward of the rear couch. The 110 volt is on the inverter feed and we connected to the GFI which is just behind the driver seat. This outlet too is a Hubbell with 2 USB charging ports.
In the rear we added an outlet also tied to the inverter outlet circuit and a 12 volt power source via a quick-connect cable in case I want/need to remove the new rear-bulkhead. This 110 volt outlet allows me to power via an extension cord my CPAP machine which will be located on the forward side of the new bulkhead. All 110 volt wiring was done with 12 gauge wire just like Airstream uses therefore all outlets have a capability of 20 amp appliance, not that we have power for more than 1.5 devices drawing 20 amps on a 30 amp shore cord.
LED strip lights in rear area. 2 sets of 1977W from Amazon cost of $25/set. Didn’t use the 115 volt power supply but wired them into a switch and 12 volts from the camper batteries via a fused circuit added into the fuse panel for the 3 12volt outlets. The strip lights come with small plastic clips which are nice but too easily dislodged if you bump them so I installed 5--3/8” white plastic straps for each set of 2 strip lights. I believe the current draw I saw was like 0.7 amp for each set of 2. And they are only used at night to see in the back area.
ID:	205309   Click image for larger version
ID:	205311   Click image for larger version
Bikerbill is offline   Reply With Quote
Old 02-13-2014, 02:13 PM   #2
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Nice work!
- - Mike
Old 02-13-2014, 06:22 PM   #3
BikerBill
thanks for appreciating.
2014/13 ext couch
12 volt
