Old 06-20-2016, 06:56 PM   #1
2015 Interstate Ext. Coach
Manassas , Virginia
Accessing the hot water heater bypass
I have a 2015 Interstate Grand Tour. I am trying to find the best way to access the hot water heater bypass valve. Last fall I laid on the floor forward of the lounge and reached though the storage doors under the lounge to turn the valve. I found that to be an unpleasant experience. Is it easier to reach the bypass valve from behind the lounge via the rear doors? There are some covers blocking access to the water heater that seem stuck. I don't want to apply more force to the covers unless they are intended to be removed.
Thanks.
curmugeon is offline   Reply With Quote
Old 06-20-2016, 08:08 PM   #2
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Not sure if the extended version is the same but on mine, I have to remove the gray, fuzzy fabric (Velcroed on) behind the W/H and then reach in to change the valve position.
Old 06-20-2016, 09:29 PM   #3
Trying to Retire
MILATV's Avatar
Decatur , Illinois
From rear, reach under lounge. You do need to pull back the carpet covering the opening, just like you do from the front. There is no good way to get to it. I wear a headlamp so I can see what I'm doing.
Mike
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 06-21-2016, 02:52 PM   #4
2013 Interstate Coach
Raymond , Iowa
I cut out a 3" wide by 6" high U shaped piece below the lounge seat in front of the water heater. Then put in back in with a spring-loaded cabinet hinge that keeps it in the closed position. I simply open it and reach in to the shut off from the front. It doesn't look bad when the seat is up - though we almost always have the seat made into the bad so it almost never shows at all.
Titus is offline   Reply With Quote
Old 06-21-2016, 05:51 PM   #5
Boxster1971's Avatar
Fulton , Maryland
That is a great idea!
Old 06-22-2016, 11:44 AM   #6
2014 Interstate Ext. Coach
fairfax station , va
HWH bypass
On the 2014 EXT the L-shaped rear water heater cover is attached with two or three screws.
It seems that it can't be removed entirely but can be pulled back a couple of inches.
With the lounge back in the up position you can actually reach OVER the top of the cover and then barely reach the yellow bypass valve.
Since it only has two positions it it pretty easy to manipulate in the blind.
VAtom is offline   Reply With Quote
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 09:45 AM
Hot Water Bypass kirbyjunewri 2011 - 2015 International 2 10-07-2013 11:41 AM
Hot water bypass - 1996 Excella SteveFE Plumbing - Systems & Fixtures 4 11-14-2012 12:53 PM
Hot Water Bypass Lumatic General Appliance Topics 4 10-09-2012 05:57 PM
Help, no hot water heater bypass in my 1975 31' Sovereign ShinyTwinkie Winterizing, Storage, Carports & Covers 5 11-30-2008 05:52 PM
