The battery box is accessible from the rear of the coach on the right side, under the couch if a Lounge model. Not sure of the access if you have a twin model.
The back of my box was covered in Velcroed fuzzy black material that easily pulled off. There are 4 Phillips screws, 2 top and 2 bottom. The batteries sit in a plastic tray that can be partially pulled out to reach the rear battery terminals. In order to reach the front battery terminals, you have to disconnect the rear battery and then pull the plastic tray further out.
The screws are a bit hard to get back in because of the awkward location. It is hard to hold the plate with one hand and line up the screw holes.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
