Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 06-17-2018, 04:08 PM   #1
2018 28' Tommy Bahama
Decatur , Georgia
AC problem Airstream Interstate 2018
Howdy,
I have a week old 2018 Airstream Interstate Lounge. . Used AC off campground 30a last weekend and several times off generator with no problems. Last night used for four hours on generator no problem. Arrived at canpsite this afternoon plugged in, nothing, nada, zilch. Tried with generator same dispiriting result. It’s hot here in Columbus Ohio. I’ve flipped breakers, cut the house batter off and on, tried to take a break and restart everything. Nothing works, not even the fan by itself. If you toggle fan speed between low and high, you can hear a click but nothing else.
If anyone has any ideas on how to get it going again, I will be grateful , extremely grateful.
Best,
Michael
Roasting newbie,
Zeitgeist1 is offline   Reply With Quote
Old 06-17-2018, 04:13 PM   #2
dznf0g's Avatar
Oswego , Illinois
JC is just up the street. Ask them, " what's up with this after a week".
-Rich-
Old 06-17-2018, 05:44 PM   #3
2018 Interstate Lounge Ext
LV , Nevada
Originally Posted by Zeitgeist1 View Post
Howdy,
Michael
Roasting newbie,
Welcome to forum. And sorry it is under bad circumstance. If no A/C from shore or gen, very possible transfer relay having issues. Though, normally I am guessing it may only be stuck using one source and not losing both. Unless it's output is the issue, like lost connection.
Are you able to run lights or audio/video via inverter? If can't run anything from batts either, maybe Magnum inverter fried like my current problem. If Magnum fried, it's ATS Auto Transfer Switch may not work either, and not pass 120v to its loads. But A/C has its own path via it's own breaker, so it shouldn't affect it.
The clicking you hear yrying to turn fan on may bw the Firefly fan and/ or A/C modules. Each one has a separate one.
As suggested, may not be much else user can do, other than call dealer or JC.
Alex AVI is offline   Reply With Quote
Old 06-17-2018, 05:52 PM   #4
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
Sounds like a problem with thermostat control. Are all indication on the thermostat normal - or does that function go through the FireFly system on the new Interstates? If so that might be a clue to problem and you need help from Airstream. Call customer service for starters.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
Old 06-17-2018, 05:57 PM   #5
LV , Nevada
MIKE - You right. I think I misunderstood OP description of problem. Could OP please elaborate. Is it just A/C not cooling properly or A/C not running at all. I had A/C comm problem with Firefly, which limited A/C compressor run time to 3mins, then only fan would run. Requires new firmware upgrade and new Firefly front panel.
Old 06-17-2018, 06:11 PM   #6
2024 Interstate 19
Fulton , Maryland
Thanks Alex - just downloaded the 2018 Interstate owners manual and see Climate control is totally through the FireFly multiplexed system. OP, Zeitgeist's problem sounds like it needs intervention by Airstream.
- - Mike
Old 06-18-2018, 11:38 AM   #7
2019 27' Flying Cloud
Yorba Linda , California
You do have roadside assistance, which came with the AS. Give them a call.
soling917 is offline   Reply With Quote
Old 06-18-2018, 12:33 PM   #8
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi Zeitgeist1,
We are very sorry for the issue that you are having in your 2018 Tommy Bahama. Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team.
We look forward to helping you get this resolved. Thank You.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Please help: 2018 Globetrotter => 2018 F-150 Lariat SuperCrew Confirmation ddrg Tow Vehicles 169 07-10-2023 05:38 PM
Airstream interstate AC problem 2018 Zeitgeist1 General Repair Forum 3 06-17-2018 04:15 PM
2018 Jeep Eco-Diesel VS 2018 Expedition? Barretta2 Tow Vehicles 57 03-10-2018 03:39 PM
