Old 03-15-2014, 11:45 AM   #1
2010 22' Interstate
Vincennes , Indiana
AC Outlets When Using Generator
Which, if any, AC outlets should be active when the generator is running?
aa9zz is offline   Reply With Quote
Old 03-15-2014, 01:10 PM   #2
weirdstuff's Avatar
2018 23' International
San Diego , California
Wouldn't swear to it, but I think all of them will be, with the generator.
weirdstuff is offline   Reply With Quote
Old 03-15-2014, 01:57 PM   #3
2010 22' Interstate
Vincennes , Indiana
In my unit, only the outlet used for the TV is active. Is this normal?
Old 03-15-2014, 02:42 PM   #4
Newbie
joemikeb's Avatar
2013 Interstate Coach
Fort Worth , Texas
I don't know about your 2010 model, but in my 2013 all of the 110V outlets are active when the generator is running. I just went out and tested them to be certain I was correct. Is it possible the GFCI in your unit has popped and needs to be reset?
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
— Navajo saying
joemikeb is offline   Reply With Quote
Old 03-15-2014, 05:27 PM   #5
Boxster1971's Avatar
Fulton , Maryland
All outlets work with generator on my 2013 EXT model.
- - Mike
Old 03-15-2014, 06:29 PM   #6
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
On my 2011, the rear floor outlet and the one over the stove only come on with shore power or the generator. They are 20 amp. The others (15 amp) are on either way. So all outlets should be live on shore or generator power.
Old 03-15-2014, 07:17 PM   #7
2010 22' Interstate
Vincennes , Indiana
On my 2010, all outlets work on 30 and 20 amp shore power but only the outlet above the TV (curbside just past the wardrobe) works on generator power. I'll check the GFCI breaker tomorrow.
Old 03-17-2014, 09:03 AM   #8
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
You do plug the shore power cord directly into the generator, right? Power should act the same as if you were plugged into the shore power post. Are you doing anything differently?
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 03-17-2014, 09:20 AM   #9
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
They're talking about an Airstream Interstate with an on-board 2.5kW 20-amp propane-fueled Onan generator, not a portable generator plugged into a trailer. Understandable mistake, though, since there aren't any Airstream trailers with a similar setup.
And since the Onan generator only puts out 20 amps versus the 30 amps of a shore power connection, the issue of electric outlets that are hot on shore power and cold on generator power is a valid one.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-17-2014, 10:45 AM   #10
Fulton , Maryland
Shore power and generator go through a power transfer switch before distribution to coach systems.
- - Mike
Old 03-17-2014, 08:19 PM   #11
Fulton , Maryland
I received a PM question on location of what I called the Power Transfer Switch. It's located on driver's side rear area behind the water heater on my 2013 EXT Lounge model. Only a few inches from the shore power plug. Location may vary on other models. The Airstream owners manual calls it an automatic switch over box on page H-10 of my owners manual. Also has brief explanation of how it works.
- - Mike
Old 03-17-2014, 08:49 PM   #12
73shark's Avatar
That's where it is on mine also.
Old 03-17-2014, 10:49 PM   #13
mefly2's Avatar
2015 25' FB Eddie Bauer
All of the shore power outlets work either from a pole or generator....
Old 03-18-2014, 06:11 AM   #14
2010 22' Interstate
Vincennes , Indiana
Yes, I am talking about the onboard Onan generator. I was at a couple of rest stops in Alabama last week and wanted to run a small space heater. The only hot outlet was in the rear of the coach at the TV. When on 30 amp shore power, all outlets were active.
Generator won't start! Lily&Me Generators & Solar Power 14 09-11-2012 05:23 AM
Lots of Generator Questions!! lewishw Boondocking 45 03-02-2012 09:12 PM
No power to 12v outlets on Dash dgmelp Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 3 12-12-2011 08:50 PM
Yamaha 2000W Generator - When Not In Use Frank&Mike Generators & Solar Power 9 11-20-2011 07:46 PM
