06-07-2014, 03:46 PM
2014 Interstate Ext. Coach
Kuwait
, Kuwait
A/C & Propane
Hey!
Finally our 2014.5 AI is on its way to us
Our main concern is A/C, since here in Kuwait since temperatures are well above 100 in the summer. Also, there is only one place in the country were we could fill up the propane tank. Which obviously seems inconvenient
We need the AI for travel not camping and are looking at major mods to fit our needs.
1. Install an engine driven A/C instead of the maxxair vent.
2. If 1 didn't work, replace the propane generator with the exact same size/power which runs on gas or diesel.
I know those are huge changes but we are desperate.
Any thoughts would be helpful.
06-07-2014, 04:29 PM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
I would think that a diesel or gasoline powered generator would be
a relatively easy fix, even over there. Then use an electric powered 15000BTU AC.
06-07-2014, 04:40 PM
Newbie
2013 Interstate Coach
Fort Worth
The possibility of engine driven A/C has been discussed at length in another thread and as I recall pretty well discarded if for no other reason than having to run the engine continuously. Replacing the propane generator with a gas or diesel unit is probably doable, but when you see how tight the mountings are, it could be a real trick to pull off.
The big problem I see in Kuwait is the A/C itself is marginal at best in temperatures much above 90℉. I live in North Texas and travel a lot in the South and Southwest U.S. and in the summer I often have to run both the engine driven A/C and the roof A/C to keep the interior temperatures at a reasonable level. So I would suspect you may be wanting either a significantly larger or even a second roof A/C unit in Kuwait which, of course, would call for additional generator capacity and rewiring the coach for 50 Amp service or more.
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
— Navajo saying
06-07-2014, 04:51 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
It already has an engine-driven air conditioner built into the dashboard and powered by the main engine. But I think what you mean is a 12v rooftop air conditioner. Fortunately, Mercedes Benz has one as optional equipment on their non-Airstream Sprinters. Shouldn't be terribly difficult to remove the Dometic 120v A/C and install the MB 12v A/C. A generator can power a 12v A/C same as it can a 120v A/C, so no worries there, plus it will run while you're driving.
Also fortunately, Cummins/Onan makes a diesel version of their 2.5kW generator, that would be a simple bolt-in replacement using the same mounting brackets and exhaust pipe. The only real change would be having to plumb the new fuel line.
You would still be limited by only having 25 gallons of on-board diesel, and you'd want to plumb the diesel generator so that it draws from somewhere above the bottom of the tank (maybe 1/4 of the height of the diesel tank) so that the generator can't suck the diesel tank completely dry and leave you stranded. You might want to get a hitch-mounted cargo tray to carry jerry-cans of spare diesel, if you go with a diesel generator.
06-07-2014, 05:26 PM
Kuwait
, Kuwait
Only found a 3.2Kw Onan Genset which is a bit larger than the 2.5Kw LP generator.
06-07-2014, 05:35 PM
From All Over
I stand corrected. That's the thing about getting old; the more senior I get, the more senior moments I have.
06-07-2014, 06:25 PM
2011 Interstate Coach
Overland Park
, Kansas
From what I've heard, diesel generators are physically larger for the equivalent output of a propane generator.
I'll guarantee a 15,000 BTU unit will not keep the RV cool in 100*+ temps. That's the equivalent of a window unit.
Since you need it for travel, I'd go for Protag's idea of adding the MB option for rear A/C although I didn't realize it was a 12 VDC unit. I figured it was run off an engine driven compressor similar to full size SUVs rear A/C. The chassis A/C does do a pretty good job of keeping the front of the RV cool tho.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
06-07-2014, 06:33 PM
1976 Argosy 24
now being enjoyed by Heath and Mary in
, Vermont
S3d
Too bad. You coulda’ bought my Diesel Powered NO PROPANE rig, complete with the MINI for less than your Interstate.
I think joemike might have meant an engine driven power plant, to power a 110 roof top A/C.
I ordered my SPRINTER with both a power take-off and the big 200 amp alternator, thinking I would install an engine driven generator.
That proved impossible. I could not find anyone in North America, including emergency vehicle builders as far away as Florida, who could do it. Even when showed photos of such an installation supposedly done in the UK, they insisted there was no room in the motor compartment and I think they were right. It’s might crowed down there.
But the question remains: why did Mercedes offer the power take off option?
I don’t think that an after market install of the Mercedes rooftop unit will be easily done either, perhaps impossible.
Even the factory installed units are the subject of a class action lawsuit in the USA:
Mercedes Hit by Lawsuit Over Sprinter Model | NBC 6 South Florida
As you’ve discovered, an Onan diesel powered plant is available in the 3.5 kW size. You will need at least that but the plant’s much bigger, much heavier and BIGGER BUCKS. They are also very LOUD, enough to rattle your Interstate.
There is a miniaturized, sound proof diesel made in Switzerland but it is very expensive, $15,000 or more.
Sergei
06-08-2014, 09:44 AM
Newbie
Fort Worth
Originally Posted by SmokelessJoe
S3dI think joemike might have meant an engine driven power plant, to power a 110 roof top A/C.
That is exactly what I meant. Additionally the existing propane generator or a gas version of the same capacity might not be capable of powering a larger roof A/C unit and almost certainly would not be capable of driving a second roof unit (perhaps replacing the ventilator behind the driver and co-driver seats). Installing a generator with greater capacity runs smack into the problem the vehicle and power management systems are setup for a maximum of 30 Amps and the load of a second generator driven A/C would require replacing a substantial portion of the 120V system and power management.
A possible solution might be a stand-alone gasoline or diesel generator mounted externally on a hitch rack and wired to the existing roof A/C and a second smaller A/C unit replacing the vent behind the driver and co-driver's seats.
— Navajo saying
06-08-2014, 10:02 AM
2024 Interstate 19
Fulton
, Maryland
It already has an engine-driven air conditioner built into the dashboard and powered by the main engine. But I think what you mean is a 12v rooftop air conditioner. Fortunately, Mercedes Benz has one as optional equipment on their non-Airstream Sprinters. Shouldn't be terribly difficult to remove the Dometic 120v A/C and install the MB 12v A/C. A generator can power a 12v A/C same as it can a 120v A/C, so no worries there, plus it will run while you're driving....
The roof top Ac unit installed by Mercedes still requires the engine driven compressor to operate. The 12V side of these units is only for the various fans used to move air.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
06-08-2014, 10:10 AM
From All Over
That makes sense.
06-08-2014, 10:46 AM
2024 Interstate 19
Fulton
, Maryland
Were you trying to get a 120v AC generator? ... there are plenty of folks installing a second DC alternator to boost the electrical output from Sprinter engine. Both Roadtrek and Advanced RV install such units. In both these rigs they have a BIG invertor and battery bank so you can easily run the roof top 120v AC RV air conditioner while driving and for a few hours when parked.
Here is a copy of the M-B Technical data on the auxiliary drive.
- - Mike
06-08-2014, 08:10 PM
1976 Argosy 24
, Vermont
Mike,
Yes, I was going to install a belt driven generator. I ordered the 2005 with both the high idle function and the power take off to accomplish that.
It didn't work out and I donated the generator, un-used, to a Mennonite auction.
It was not a sensible idea in any case. You'd have to idle the truck motor at a constant 2200 rpm to make current. How wasteful is that?
Too, when I bought the vehicle, there was no Mercedes support like now. The dealership didn't even know what the power take off or high idle function were for. They only knew the list price.
The heavy battery bank extra alternator idea would not have been the solution in my unique case however.
Sergei
06-08-2014, 09:27 PM
2024 Interstate 19
Fulton
, Maryland
Mike,
Ah - I see you have an older Sprinter - I didn't recognize it on your first post.
Good Luck on selling your rig -- it looks like a sweet setup.
- - Mike
