Old 03-01-2012, 07:32 PM   #1
solar-guy's Avatar
2009 22' Interstate
Covington , Louisiana
Rivet 2008 Interstate 3500 Generator Exhaust Routing Question
The generator (Onan 2500) exhaust pipe routing on my coach goes diagonally under the rear axle gear housing and exits behind the driver's side duals. The problem is the exhaust pipe with heat shield hangs so absurdly low that it will hit curbs or parking markers if you back into a parking spot. I think it is also very vulnerable to being torn off just becaue it hangs so low. I was wondering if anyone else had the same issue and tried to solve it by re-routing the exhaust or why Airstream would have installed it that low to begin with?
solar-guy is offline   Reply With Quote
Old 03-02-2012, 05:10 AM   #2
Lily&Me's Avatar
Normal , Illinois
On ours, it is the engine exhaust that hangs low and exits behind the driver's side rear wheels.
We have scraped the heat shield here and there, never knocked it off nor hit a curb when backing into a parking spot. Doug has cinched it up a few times for reinforcement, and we have also had its' holding bracket replaced once.
It may look like it won't clear, and you may need to watch it carefully, but it may well clear and you just don't know it. Might take a measurement.
Yours may also be hanging extra low because it has been bumped and something has come loose. If it hasn't been looked at good from underneath, that would be your first step.
Doug's concern if you tried to reroute this is that you may affect the performance of the generator.
We have more problems with the front bumper and high curbs. Ground clearance is not the Interstate's strong suit. It's all part of the charm.
Maggie
Lily&Me is offline   Reply With Quote
Old 03-05-2012, 11:30 PM   #3
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
You might contact Jim Parrett at Airstream. jparrett@airstream.com
Might be able to supply a picture of how it left the factory. He's always been very helpful for me.
Glass half full or half empty to an engineer is the glass is twice as big as it needs to be.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
73shark is offline   Reply With Quote
Old 03-06-2012, 06:19 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Speaking as a mechanical engineer, the main thing about the exhaust system is its length. If you make it longer or shorter, you will affect generator performance by changing the back-pressure. If you keep it the same length and simply reroute it, there should be no particular problem. I still wouldn't recommend it, though, until and unless you do snag it on something. If the exhaust pipe is damaged anway, then you might as well reroute it to prevent a recurrence, otherwise, I'd leave it where it is.
Not having done the factory tour, I cannot say how much of the generator installation was engineered and how much was fitted by trial and error, but they put the exhaust where it is for a reason that's NOT just simple carelessness.
Generator runs air conditioner, no AC current deltatango Classic Motorhomes 4 03-05-2012 10:35 AM
newbee interested in buying an interstate echo44 General Motorhome Topics 11 03-03-2012 09:08 AM
Lots of Generator Questions!! lewishw Boondocking 45 03-02-2012 09:12 PM
Lifan Inverter Generator TankerIP Generators & Solar Power 10 03-02-2012 02:06 PM
00 Airstream 190 CLASS B*93K Miles*Generator*Sleeps 4*MANY UPGRADES eBay Watch Airstreams on eBay 0 03-01-2012 07:10 PM
