01-16-2014, 08:19 AM
2013 Interstate Coach
Tallahassee
18" Wheels?
We have logged 70k miles in one year and it is time for new tires. I would like to swap the factory 16" wheels with 18" wheels and slightly larger tires for both look and performance. Does anyone have any experience with this? Who makes an 18" wheel that will fit the Sprinter dually?
01-16-2014, 04:13 PM
2014 Interstate Ext. Coach
Vienna
, Virginia
I would bet that Alcoa probably has a potential set. I went on their website and there are many offered models.
01-18-2014, 11:03 AM
Newbie
Fort Worth
While you are at it you will want to change the gear ratio in the rear end to compensate for the gear ratio change from the new wheels, have the springs and shocks changed and adjusted to compensate for the greater unsprung weight of the new tires and wheels, and have the speedometer recalibrated.
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
— Navajo saying
01-18-2014, 01:32 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Also, your fenders are ideally sized for the tire you already have. If you go with larger tires, so may run into clearance problems.
01-18-2014, 01:51 PM
Broadway
, North Carolina
Tires for the 18" wheels would be a lower profile allowing the overall diameter, width and gear ratio to be the same as the original 16" wheel/tire combination if desired.
The unsprung weight of the 18" combo would also be similar so suspension changes would not be necessary.
In most vehicles, especially trucks, wider tires can be fitted at the option of the owner (keeping the diameter about the same). This is called " plus sizing" and is very common.
Overall the upgrade to 18" would give some newer tire tech options, better stability and steering response, and would update the looks of the van.
2006 Safari SE FB
2000 F150 4.2L (retired), 2011 F250 6.2L, 2010 ML550, 2000 Excursion 7.3L
Broadway, NC
01-18-2014, 02:53 PM
2011 Interstate Coach
Overland Park
, Kansas
Lower profile tires will increase ride harshness. And larger wheels will weigh more.
But you are correct, larger wheels with lower profile tires and the correct offset should not cause any interference problems.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
01-19-2014, 09:05 AM
norman
, Oklahoma
Finding an 18" tire with the proper diameter (via lower profile) and a sufficient load rating and then finding a set of wheels with the right combination of width and offset to make them fit may be a problem.
Your stock 215/85/16 tires are about 30.4" in overall diameter. The closest I can figure in an 18" tire that is made in a size with a similar diameter is a 255/60/18 (its right at 30" tall). So your gearing, speedometer, etc. would be thrown off by less than 1% and should not be problematic. However, that tire is almost 2" wider in section width (the widest part of the sidewall) and it it is critical that the duals do not touch while absorbing impacts, cornering loads, etc. so the wheels would have to have more dish built into them to keep the tires apart AND the the 255/60/18 requires a wheel 7 to 9" wide (vs your stock 6" wide wheels) so the rear duals would be a custom set up and MUCH wider than stock. You would be literally reinventing the wheel (sorry!) trying to come up with an appropriate setup that would work. Putting custom wheels on sprinter is no problem on a 2500 with singles on the back, but on a dually you've got your work cut out for you. However, it would look cool!
BTW, going from a pair of 215's on the back to a pair of 255s would likely have a significant impact on fuel economy. Might help in a cross wind though.
Stock:
http://www.tirerack.com/tires/tires....omCompare1=yes
VS 18":
http://www.tirerack.com/tires/tires....=yes&tab=Specs
01-19-2014, 02:10 PM
Overland Park
, Kansas
One could always put fender flares on the back to cover the duals that stick out.
01-20-2014, 05:44 AM
CapriRacer
I'm in the
, US
I am going to guess you will not find any 18" dualled wheels to fit your Sprinter dually.
Please let us know what happened in your search, so we can pass that on to others.
01-20-2014, 05:51 AM
Mantua
, Ohio
Very important to check load range for new wheels.info should be on the inside of the wheels. When I had my Interstate years ago the only custom wheels I could find all had a smaller load rating. I ended up buying some from MB, the same ones that were standard in later years. As an aside, my new wheels were scratched by the Dodge dealer up non install. A cash resolution followed. Also the new wheels needed dif lug nuts which were provided with the wheels. Jim
01-24-2014, 01:15 PM
2024 Interstate 19
Fulton
, Maryland
I just discovered that Forgiato Wheels Inc, in Sun Valley, CA makes 18 inch forged wheels used on the Bespoke Coachworks Custom Vans. There web site only shows the models for Sprinter 2500 vans but they may be able to make you a set for the 3500 Sprinters. Here is contact details.
Contact - Forgiato
Bespoke also indicates they use 18 inch tires that are 10 ply load rating E, which is what you need to Interstate.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
