Old 05-21-2014, 05:54 PM   #29
Jeff
jkinglet's Avatar
2013 Interstate Coach
Seattle , Washington
Images: 37
I'll put it together tonight. Getting ready for the Memorial Day romp!
jkinglet is offline   Reply With Quote
Old 05-21-2014, 08:30 PM   #30
Jeff
jkinglet's Avatar
Images: 37
IPS Technical Service Bulletin
The dealer's copy machine's printer cartridge was running low so the PDF quality isn't very good. But here's the link to the January 2014 IPS Technical Service Bulletin regarding Airstream and Lifeline AGM batteries.
Old 05-22-2014, 08:27 PM   #31
Boxster1971's Avatar
Fulton , Maryland
Thanks Jeff!
- - Mike
Old 07-08-2014, 12:39 PM   #32
2014 Interstate Ext. Coach
Sherman Oaks , California
Hi all, I am new to RV'ing and new to Airstream. We have a new 2014 Interstate that we received on 12/18/13. I am told now by a repair shop that the batteries need replacing. We have kept it connected to the house (120v) almost constantly and the repair shops are telling me they have as well. Does anyone have best practices to keep these batteries working? We don't turn off the load because the RV has not been left idle many days in a row.
Thanks for the help,
Rhonda
OhThePlaces is offline   Reply With Quote
Old 07-08-2014, 12:51 PM   #33
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Welcome to Air Forums.
It sounds like the RV sat on the dealers lot and for some reason the solar panel didn't keep the batteries charged properly.
Personally I turn everything off in mine and let the solar keep the chassis and house batteries charged.
Read the posts in this thread and you may be able to get the dealer to replace the batteries.
Old 07-08-2014, 12:52 PM   #34
Jeff
jkinglet's Avatar
Images: 37
Rhonda
Rhonda, See my recent post concerning the Lifeline battery technical bulletin with a link to the PDF. Your batteries most likely were not attended to properly while your interstate sat on the dealer's lot and were in need of replacing when you drove it home. Our dealer and others around the country have replaced the batteries at no cost because Lifeline made it clear to AS dead batteries upon delivery or shortly thereafter is not a manufacturer problem. As an aside, during a recent visit to a dealer I noticed that the batteries on the Interstate showroom model were either toast or had been removed from the coach. Good luck.
Old 07-08-2014, 01:09 PM   #35
Thank you gentlemen and thanks Jkinglet for the post. My favorite is that it is dated January '14 while the warranty department is stating notification was included in the RV 12/13. Anyway, the RV came straight from Ohio and arrived 12/16/13. Could it have sat in Ohio? Is it possible It corroded because I connected to 120v vs 30 amp? I definitely will be turning everything off from here on out.
Thanks again,
Rhonda
Old 07-08-2014, 01:30 PM   #36
73shark's Avatar
Rhonda
Having the shore power plugged in would not hurt anything. In fact, it should maintain all of the batteries. Your shore power if connected to your home circuits would most likely be either a 20 amp or 15 amp circuit which is adequate for everything except for the A/C if on a 15 amp circuit.
When I said turn everything off, that includes all of the circuit breakers, inverter, house battery disconnect, and antenna amplifier. About the only thing drawing current then is the BIM (Battery Isolation Monitor). The solar should be able to maintain the batteries then.
Old 07-08-2014, 01:34 PM   #37
Jeff
jkinglet's Avatar
Images: 37
Thanks again,
Rhonda
Very possible.
Old 07-21-2014, 04:48 PM   #38
Can anyone direct me to the manual that explains the Electrical Management System?
Thanks in advance,
Rhonda
Old 07-21-2014, 05:48 PM   #39
BikerBill
Poconos of Pa , Pennsylvania
Did you look in the Airstream manual, section H about electrical? Its also available on the Airstream webpage to download. Its about 1.3meg PDF file.
I've attached two smaller files that give you more details on some of the systems in the AI.
File Type: pdf 0010021000BatteryIsolationManagerRevD.pdf (77.4 KB, 38 views)
Bikerbill is offline   Reply With Quote
Old 07-21-2014, 06:08 PM   #40
Oh those are new ones. I am trying to find out more about the inverter remote switch.I don't see that covered in section H. I keep getting a Fault error. Everything is charged...so I am looking for the manual. Thanks for the help.
Old 07-21-2014, 06:50 PM   #41
BikerBill
Ok lies try these files for the Magnum inverter.
Old 07-21-2014, 07:43 PM   #42
lewster's Avatar
Naples, FL , Hood River, OR
If you are getting a fault on the inverter remote panel, you more than likely have to re-set the inverter. It should be under your rear bench seat, bolted to the rear vertical wall. Remove the outer screws and lower the panel so you see the inverter. The cables should enter the inverter on the driver side of the unit.
There is a small button just above the green LED light on this side of the inverter. Push the button and hold until the LED starts flashing rapidly. This is a 'soft' reset.
If you still have a fault code, you need a 'hard' reset, which means removing all AC and DC power from the inverter along with any communication cables (look like phone cables) for 10 minutes..... then re-connect all. If that does not reset the inverter, you need to have a factory authorized Magnum service center look at it, as you might have a more serious problem.
Let me know if you have any other questions.
lewster is online now   Reply With Quote
Univolt is toast- replacement suggestions? mprokop87 Batteries, Univolts, Converters & Inverters 9 08-01-2013 07:09 PM
Toast Noco Interior Restoration Forum 10 05-19-2013 06:27 AM
Are my batteries gonna be toast? Gringo Batteries, Univolts, Converters & Inverters 38 10-13-2012 01:01 PM
How Do You Make Toast? Fly at Night Stella's Kitchen 38 09-12-2011 02:49 PM
How do you make toast ???? polarlyse Stella's Kitchen 40 05-15-2010 05:18 PM
