Old 02-05-2016, 08:19 AM   #15
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by Prairie View Post
Another issue appeared this morning when the generator wouldn't start. It fires up and then dies after running about three seconds. The low oil warning light is not flashing.
That happened to me a couple of years ago. The generator's voltage regulator was fried. Literally. The Onan dealer showed me the old one, and it had scorch marks on it.
While I had the generator in the shop to get that fixed, I had them install a resonator on the generator's exhaust pipe. Quieted things down quite a bit. At least from outside. It still sounds the same from inside, but that's because a resonator only quiets the exhaust, and does nothing for generator vibration, which is a major source of interior noise while the generator is running.
In a pinch, you should be able to charge the house batteries from the engine alternator, but you have to drive the van around for that to work; just idling won't do much.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-05-2016, 09:31 AM   #16
2011 Interstate Coach
Muskogee , Oklahoma
Thanks gmiller, I believe your analysis and suggestions may be the solution to my charger problem. However it is beyond my ability to carry out those procedures. I am in the process of contacting Orlando RV to set up a service appointment and will share your notes with them.
So now I have further discharged the battery and have no place to plug in to recharge it.
Well, you can tell them how to fix it, then!
As for the genset, make sure there is propane available. Check to see if you can light (and stay lit for a minute or two as there is some gas under pressure in the line) the stove. If not, then it's not getting any gas. Check the switch to be the valve is turned on, and check the level of the propane. If the switch is on, and the meter shows you have plenty, then it could be something as minor as something in the line (I also had that problem at one time, or serious, as Progag mentioned. I don't know how many times, I've started mine, only to have it die in a few seconds, before I realized I did not turn on the switch to the solenoid valve. You can take it to a propane shop and they can check the lines for you. If it's not that, you will have to find a Onan dealer near you to troubleshoot and repair it.
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Install New 120v Circuit and Outlet dbj216 Batteries, Univolts, Converters & Inverters 14 04-09-2014 04:07 AM
my converter hums dusty b Electrical - Systems, Generators, Batteries & Solar 8 01-27-2012 10:49 AM
'72 Overlander AC fan hums when off JollyGreen Furnaces, Heaters, Fireplaces & Air Conditioning 4 05-24-2011 11:01 AM
Changover Trouble(120v-12v) 73ANDY Electrical - Systems, Generators, Batteries & Solar 5 04-22-2003 09:04 PM
wiring diagram 120v brunoffrance Electrical - Systems, Generators, Batteries & Solar 3 02-08-2003 01:41 AM
