Old 05-30-2016, 08:01 AM   #1
2015 Interstate Ext. Coach
Manassas , Virginia
12 volt power for Interstate front camera
I have a 2015 Interstate Grand Tour. I have mounted a front facing camera on the windshield forward of the rear view camera display. Currently, I snake the power cord around the edge of the windshield to the cigarette lighter socket.
Instead, I would like to get camera power from the overhead center console. I am told that I can splice the forward camera power cable into available 12 volts in the overhead center console. Can anyone tell me how to drop the center overhead console without damaging it?
Thanks.
curmugeon is offline   Reply With Quote
Old 05-30-2016, 11:02 AM   #2
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
IIRC, it is held by clips on each side and you can release by pushing in on one side and when it drops down, the other side can be dropped also.
Old 06-01-2016, 10:53 AM   #3
David M's Avatar
2013 Interstate Coach
Orange County , California
Push the overhead plastic console sideways towards the driver and pull down. On mine, the cardboard-like overhead got frayed by the spring loaded clip on the plastic consol, so I used super glue to harden the cardboard up. I also have a dashcam that's powered (switched) from the overhead area so it's available. As you may already know, many dashcams run on 5 vdc so you may need a power supply.
David M is offline   Reply With Quote
12 volt
Backup Camera as Rear View Camera Rapa Nui Tow Vehicles 10 07-10-2013 04:37 PM
24 volt or 12 volt solar panels advantages?? purman Electrical - Systems, Generators, Batteries & Solar 13 09-06-2012 02:29 PM
6 volt vs 12 volt brakes? lwebb Brakes & Brake Controllers 17 07-14-2005 08:32 AM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 09:03 AM
