Old 05-24-2012, 01:09 PM   #1
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
Question 12 v Outlet in overhead-plug doesn't fit
The 12v outlet in the forward overhead that is part of the panel with the TV antenna amplifier seems to be a little undersized. I haven't finished fighting this battle but I can't seem to get any of my normal 12v plugs to fit.
Anyone else have this problem?
Wayne
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 05-24-2012, 01:19 PM   #2
1974 Argosy 20
Kooskia , Idaho
I know the European "cigaret lighter" size and the US one are slightly different and I have had some issues over the years with plugs that did not fit in outlets, either too small or too big. No real standard for them it seems, and as most everyone agrees, it is a very poor plug/outlet arrangement which kind of just happened. You may have to replace the one you have with a new one, and hope it works better.
Old 05-24-2012, 03:42 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Yes there are 2 distinct different type of this receptacle I can't say which is which but I can say there are 2. I had to wire a new one for my pletier cooler and use the original for my I Phone adapter.
2004 Excursion 4x4
Old 05-24-2012, 04:38 PM   #4
2011 25' FB Flying Cloud
Anywhere & , Everywhere
There was a problem with this several years ago and I think there may be a thread on Air Forums. Suggest you do a search but the only fix as I remember is to replace the socket.
Al - K4GLU is offline   Reply With Quote
Old 05-27-2012, 05:05 PM   #5
KerriO's Avatar
2008 27' International CCD FB
Bay Area , California
I had that same issue for the socket that also includes the Winguard power switch. We intended to replace it, but instead found a 3-outlet adapter at Radio Shack (it's black and has a pivoting hinge, if you go look for it) that fits in there easily. Added bonus: we can plug in two extra items.
[[ Captain's Log ]] Our full-time journey in our 27'FB International
KerriO is offline   Reply With Quote
Old 05-27-2012, 05:14 PM   #6
ben322's Avatar
2009 Interstate
Bethesda , Maryland
I had the same problem when I wanted to power a second monitor in that single DIN slot that has the odd connector. I was going to replace it with a standard plug but that's when I found a 12V switched house battery lead in the wires above the headliner on the LH side, (above the driver), so I never bothered to change the outlet.
Ben
2009 Airstream Interstate
ben322 is offline   Reply With Quote
Old 05-27-2012, 08:01 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
Wayne,
Airstream had a problem with undersized 12v outlets in 2010 and maybe a couple of years before and after. The only fix is to replace the outlets. Depending on when your rig was first sold it may still be under warranty and if so they should cover it.
