Go Back   Airstream Forums > Airstream Community Forums > Airstream Lifestyle > The Pet Forum
Old 09-03-2012, 07:58 PM   #21
rastapoodle's Avatar
2004 31' Classic
Rock Hill , South Carolina
Thumbs up
We just returned from 4 weeks on the road w/the Rastapoodles and it was great.
When we left the girls in the trailer, we DID leave the water bowl on a stand in the shower. It took all of 3 minutes for them to figure it out. Most of the drips, slobbers and motorboat, messy drinking was captured in the shower stall.
Many thanks to my wonderful husband, John Barlow, for removing the shower door for me. The shower curtain works great and is way more attractive than the gold shower door that always leaked on the floor. I can change the curtain on a whim.
rastapoodle is offline   Reply With Quote
Old 09-03-2012, 08:05 PM   #22
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
on the floor in front of the fridge.
Old 09-27-2012, 07:11 PM   #23
paisley's Avatar
1960 22' Safari
Asheville , North Carolina
My "kids" are spoiled. They have built-in food and water bowls, as well as a dog cave underneath one of our beds. As a bonus, when only one dog is traveling with me (like on my current trip) I use the extra bowl for my sweaty running socks
paisley is offline   Reply With Quote
Old 09-27-2012, 07:23 PM   #24
KYAirstream's Avatar
Northeastern , Kentucky
Center or rear bath? If center, would u mind posting a pic of your curtain and rod?
KYAirstream is offline   Reply With Quote
Old 09-27-2012, 07:28 PM   #25
Taylormade's Avatar
1978 31' Sovereign
I build a sliding storage container that serves both as their food and water bowls. We store their dry food in the open cabinet underneath the bowls and thankfully they aren't too bad in the slobber department. We have a german shepherd and a lab mix.
Here's a pic of it closed.
and deployed.
Taylormade is offline   Reply With Quote
Old 09-27-2012, 07:56 PM   #26
CanoeStream's Avatar
St. Cloud , Minnesota
Nice solutions all! We have a 50# airedale and a 24# English cocker. This works very well for us. The Road Refresher water dish doesn't slosh out if we keep it no more than 2/3ds full.
ID:	169106   Click image for larger version
5 meter Langford Nahanni
Old 12-10-2012, 10:03 AM   #27
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
South Central Rockies... , "...'Stream'n the Dream" thru the USA
Water and Food Bowl Location...
Here's an option for your pet's water and food bowl in a 1985 25-footer...
I removed a veneer panel on the street side between the sink cabinet and the hanging locker. It revealed an unused space about 9" deep, 4" wide, and 12" high. We place two stainless steel bowls side-by-side in this recessed area and its perfect for Jaki's food/water needs.
The flooring is a rubber interlocking tile material over a vapor barrier covered waterproofed subfloor.
ID:	174355   Click image for larger version
Art - W0ABX
High Desert Country of the Rockies
'85 Sovereign 25'er
WBCCI: 2197; AIR #: 36503; TAC #: NM-5
MaxAB is offline   Reply With Quote
Old 12-10-2012, 05:01 PM   #28
Like your floor. Who makes it?
What sort of vapor barrier did you use, and did you treat the subfloor with poly to make it waterproof?
Old 12-11-2012, 09:25 AM   #29
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
Interlocking Tiles - Lowe's
The floor material are "Interlocking Tiles" (IT's) - about 14" square. The interlocking feature is hidden and seams are straight. They are made of a rubberized material - very durable so far. Installed last summer, we've had about 6 weeks of usage. We carry a small Honda Trail 90 scooter in the living room area and they show no signs of wear/tear. Easy to clean and keep nice looking.
Vapor barrier is made of small Styrofoam (7 shot size) sandwiched between a layer of red plastic film.
I waterproofed the subfloor with a shower pan waterproofing material (goes on "pink" and dries "red")... Subfloor to wall seam was sealed with a heavy duty silicone caulk.
If liquid spills on the ITs its just a quick wipe-up and you're done. If it spills and stays unattended (which happened once so far) - I just un-snapped the affected tiles and wiped up the liquid from the vapor barrier.
Bought all the materials from in-stock items at Lowe's... FYI.
We repaired dry-rotted original subfloor last summer. From the pix below you can see the silver insulation material I connected to the under side of the marine plywood replacement subfloor.
The new subfloor pieces were waterproofed top/bottom and edges.
Basement insulation was removed and replaced with new.
You can see the red vapor barrier over the waterproofed subfloor in one of the pics.
Hope this helps...
Cheers,
Name:	AS Front Floor Seams.jpg
ID:	174439   Click image for larger version
Name:	AS Front Floor Wood.jpg
Name:	AS Front Floor Insulation.jpg
ID:	174441   Click image for larger version
Name:	AS Floor Vapor Barrier.jpg
Art - W0ABX
'85 Sovereign 25'er
Old 12-11-2012, 08:26 PM   #30
Looks great! I like the foil wrap under the subfloor. I'll have to check out Lowes for those tiles.
Old 01-25-2013, 01:46 PM   #31
lonewolf1977's Avatar
1957 26' Overlander
Winston Salem , North Carolina
We have a 5 year old GSD. I've been wondering what it would be like living with him in an AS environment. Seeing as how you also have a lab mix, I'm guessing it's doable!! I love your water & food bowl drawers. Very nice.
Airstreamin' dreamin'.
Follow our blog! https://theoverlanderproject.blogspot.com/
lonewolf1977 is offline   Reply With Quote
Old 01-26-2013, 05:54 AM   #32
Taylormade's Avatar
1978 31' Sovereign
Thank you and it is very much doable... our lab/boxer mix likes to call the bathroom his, while the shepherd... well, he just calls the entire trailer his, and somehow always ends up in our way. He prefers to be outside, as do we, but tolerates coming in for the night. In the picture below he picked up his bed and moved it to the most inconvenient place in the trailer, set it down and plopped right down blocking any easy passage.
We've been camping with my wife, myself and my 18yo daughter with the two dogs and have had no problems to speak of. Keep in mind we came from a pop up though, ha.
Old 01-26-2013, 07:14 AM   #33
2008 16' Safari
Destrehan , Louisiana
Wow... never thought this could be such an issue. We have two Australian Shepherds. We just put their bowl on the floor. They generally don't spill a drop. The only problem is when they run out of water and play "bowl hockey" to let us know it's time for a refill.
dlb435 is offline   Reply With Quote
Old 01-26-2013, 07:28 AM   #34
"Cloudsplitter"
Thumbs up
There's two four leggers ...and four two leggers with us a lot...
Helps to love the ones your with....
ID:	177463   Click image for larger version
Name:	PISECO LAKE CAMPING JULY 2008 165.jpg
Old 01-27-2013, 02:25 PM   #35
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
...with whatever pet-waterbowl configuration used, be sure to add an additional step to your "Back-on-the-Road Again" checklist - something like, "...empty fido's water bowl before moving."
It took us a couple of wet floors to add this step to our checklist...
Oh, well - old dog and new tricks...
Old 07-07-2013, 06:17 AM   #36
paiceman's Avatar
2020 28' Flying Cloud
Upper St Clair , Pennsylvania
We took the winter floor mats from the truck and use one for the dog bowel and the other in the bed of the tuck to put the two Honda generators on for boondocking. Both work pretty well. Our lab is a drinking slob, so I've trained her to stand over the bowel for a short while after drinking to let the dribble go in the bowel. Works most of the time.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
Old 07-07-2013, 06:56 AM   #37
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
That's a great idea!
I do have to ask though - 3 times you said "bowel" not "bowl". That's either a rough auto-correct or ?? :-)
Old 07-07-2013, 10:24 AM   #38
Tincamper's Avatar
2011 25' FB Flying Cloud
Western , Washington
Our akita is a VERY sloppy drinker, the corgi not so much. We keep their water bowl under the dinette in a plastic boot tray and it works well. Amazon.com: Yaktrax Boot Tray: Sports & Outdoors.
Auburn, WA
Tincamper is offline   Reply With Quote
Old 07-07-2013, 01:01 PM   #39
Rollster's Avatar
Saint Augustine , Florida
We just put our sloppy drinker's bowl outside, but I need to train her to drain her dripping jowls over her bowl like Paiceman did! I love that!
Carol, Aboard "Aggie the DreamStream"
WBCCI# 5248
Rollster is offline   Reply With Quote
Old 11-16-2013, 10:28 AM   #40
weirdstuff's Avatar
2018 23' International
SANTA BARBARA , CA
I'm only 2 weeks into the new Airstream Adventure, so trying to figure this all out too!
I have an Interstate, so, having a bit of space envy of y'alls trailers with so much room.
Me, husband, a 50# dog and a 44# dog...it's tight. We've been putting the water bowl on a little ledge that's behind the second row seat on the passenger side. Bought a collapsible rubber bowl that fits perfectly! And when we drive, we put it in the sink.
My pups have beards, so they're a bit drippy when they drink, but nothing a paper towel can't wipe up.
weirdstuff is offline   Reply With Quote
