Old 09-30-2017, 09:15 AM   #29
KatMacz's Avatar
2017 25' Flying Cloud
Fenton , Michigan
Originally Posted by DKB_SATX View Post
Living in Texas, we do this all the time when we travel with the dog in the summer. I don't usually let it sit around idling for an hour, but often for shorter 10-20 minute stints while going in for the bathroom or to pick something up in the convenience store after filling up, etc. As mentioned above, extended idling isn't beneficial to the vehicle but using it occasionally isn't going to cost you much. It gave me new appreciation for Ford's keyless entry keypad, too, though there are other ways to make it work if you don't have that, and newer pushbutton-start vehicles make it even easier though my new truck honks at me when I close the door from outside with the key in my pocket.
Thank you. We have the keyless-entry system.
KatMacz is offline   Reply With Quote
Old 09-30-2017, 09:32 AM   #30
McDave's Avatar
2014 23' Flying Cloud
Fair Oaks , California
As the owner of an F-250 diesel, Im not too worried about the safety aspect of leaving the engine running, but I am worried about somebody driving off with my truck, and the safety of my dog if somebody decides to do that. It's fairly difficult to lock the truck with the engine running. Can't pull the key out with the engine running, and pushing the lock button on the door panel or key doesn't work if the door is open with the engine on. What does work is carrying the spare key, which will lock the door with the engine running if the door is closed. Still, having the door locked only offers minimal protection against having the truck stolen if the engine is running, so I limit this to short trips, 20 minutes or less, where I can look out the store or restaurant window and see the truck for most of the time Im inside. This is also a good idea in case some good samaritan would decide to break my window to free the dog. Hopefully they would look around first, which would give me time to rush outside and explain that the dog was more comfortable inside than either of us were outside.
McDave is offline   Reply With Quote
Old 09-30-2017, 10:03 AM   #31
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Originally Posted by McDave View Post
As the owner of an F-250 diesel, I’m not too worried about the safety aspect of leaving the engine running, but I am worried about somebody driving off with my truck, and the safety of my dog if somebody decides to do that. It's fairly difficult to lock the truck with the engine running. Can't pull the key out with the engine running, and pushing the lock button on the door panel or key doesn't work if the door is open with the engine on. What does work is carrying the spare key, which will lock the door with the engine running if the door is closed. Still, having the door locked only offers minimal protection against having the truck stolen if the engine is running, so I limit this to short trips, 20 minutes or less, where I can look out the store or restaurant window and see the truck for most of the time I’m inside. This is also a good idea in case some good samaritan would decide to break my window to free the dog. Hopefully they would look around first, which would give me time to rush outside and explain that the dog was more comfortable inside than either of us were outside.
I guess you don't have the 5-button Ford "Keyless Entry" pad on your F250? My first vehicle with that feature was the '07 F150 I bought when I bought our first Argosy, and that works REALLY well for the purpose. Just hit the "7-8" and "9-0" buttons after you close the door and it'll lock the truck, then enter your code to unlock when you return. I thought it was a gimmicky thing before I got used to having it on the truck. Even now with the new pushbutton-start truck I use the keyless entry pad if I don't happen to have the key in my pocket when I need something out of the truck.
Oh, and if the "good Samaritan" can't tell a Powerstroke is running and they're not hearing-impaired, they may not be smart enough to look around for the truck's owner either. I knew the new ones are WAY quieter than a 7.3 but it still ain't no Tesla!
David
Old 09-30-2017, 10:15 AM   #32
FishByFly's Avatar
Oak Park , Illinois
I have a remote start on my F250. If shuts down after 10 mins. Allows us to be in a restaurant and turn on the truck to cool things down, or warm things up, a bit. In the winter, I start the truck a couple of times to soften the snow and ice. Has a block heater too and I plug in when we expect temps to fall into the single digits. Sorry, I digress. Yes, I will idle my truck. Usually less that 40 mins tops.
FishByFly
because I catch fish on a fly...
2017 25' Safari FB
2010 F250 Lariat
FishByFly is offline   Reply With Quote
Old 09-30-2017, 01:00 PM   #33
McDave's Avatar
Thanks for the tip! Just tried it and it works great!
As for the "good samaritan," remember, this is California. Now that people are allowed to break your window if they think your dog is in distress, I wouldn't be surprised if someone broke my window because they thought that Lupe looked lonely inside all by herself.
Old 09-30-2017, 11:49 PM   #34
3wd67rg's Avatar
1988 32.5' Airstream 325
WhereIam , Left Coast Proud
Originally Posted by PammieSue
Doesn't the Airstream have air conditioners? And a genny? Seems an easy answer to me.
If you're talking about one of the motorhomes, that's definitely a reasonable approach. However, for those of us with trailers, stopping en route at a truck stop or rest area for a brief time it's not practical to haul out and hook up a generator, wait for the interior of the Airstream to get to a reasonable temperature and put the dog back there. I also suspect that people who are afraid to leave the dog for 20 minutes in the truck with the engine running and AC on wouldn't trust their generator and Airstream AC for 20 minutes either.
Are you saying that Airstream trailers don't have the genny installed like the mohos do? That seems very odd. But for myself and my boyfriend the extra time necessary to cool it down for our animals is a non-issue no-brainer. We're retired and living on our own time, no problem waiting for the Airstream to cool down. Our two cats Chibi and KatyCat, and our dog Turbo mean everything to us.
It is possible to travel with the Airstream's windows open, we do. We only close them for dust, a very hard rain, or when temperatures are at either extreme. Open windows are not as cool as air conditioning, but it's better than a hot stuffy Airstream and will be easier to cool down when the air conditioning is turned on.
3wd67rg is offline   Reply With Quote
Old 10-01-2017, 03:49 AM   #35
2012 19' International
Southeastern MI , Michigan
i don't walk through parking lots peeping into people's cars, but hopefully "samaritans" remember you have to contact emergency services FIRST before breaking into someone's vehicle.
Countryboy59 is online now   Reply With Quote
Leaving Fridge Running Idaho air Boondocking 8 05-16-2012 06:45 PM
Losing engine elec. engine dies while driving ccgartman Airstream Motorhome Forums 4 12-10-2011 08:46 AM
Running the engine on Propane chasgould Mechanics Corner - Engines, Transmission & More... 8 05-24-2004 06:56 AM
OK, I'm leaving tomorrow to go get... drboyd On The Road... 11 07-18-2003 11:23 PM
Leaving!!! LKappenman On The Road... 0 03-07-2003 03:39 PM
