Old 09-26-2017, 03:08 PM   #15
mikeinca's Avatar
2018 30' Classic
Santa Rosa , California
Originally Posted by DKB_SATX View Post
In a note in the manual lower down is says the time is 30 minutes.
I went straight to google, Should have just kept reading. Thanks.
“The good thing about science is that it's true whether or not you believe in it.”
― Neil deGrasse Tyson
2018 30' Classic Twin
2017 F250 4x4 6.7 max tow Platinum
200W portable solar
240Ah LifePo4 upgrade
mikeinca is offline   Reply With Quote
Old 09-26-2017, 03:22 PM   #16
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Originally Posted by Landrum View Post
It may be programmable, but our 2017 F150 shuts off after 10 minutes.
You may be thinking of the timeout for the remote-start run cycle rather than just leaving it running after having started it from inside the vehicle. I think the default timeout for remote start is 10 minutes, with the option to set it to 5 or 15 from a menu.
— David
Old 09-27-2017, 12:40 PM   #17
OttawaValleyGuy's Avatar
1991 35' Airstream 350
Barry's Bay , Ontario
Originally Posted by Countryboy59 View Post
Never ever. Sorry to be the dissenting vote. The catalyst and turbos on these engines stay very hot and I would never ever leave a dog or human inside a running car. Too much can happen. Especially on grass. Fought enough vehicle fires that I won't even nap inside a car with a tank of gasoline attached. Until recently I wouldn't even park inside my attached garage, shut off, without disconnecting the battery.
Police vehicles are sometimes equipped with an automatic door opener to protect canines that must be left in the car, because engines can stall or run out of fuel.
Diesel may be another story.
WOW is all I will say
Howard and Ann Schutt
OttawaValleyGuy is offline   Reply With Quote
Old 09-27-2017, 12:53 PM   #18
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Frequently we find the inside the Airstream, with both roof vents opened and fans running, it is very comfortable, when inside the tow vehicle the solar gain through windows is what's causing the dangerous temperature. Obviously not when the air temp is also very high.
The AKC sells a collar that uses cell service to track your dog if lost and gives the temperature. It sends you cell phone an alarm if it reaches a certain temp.
2012 Dodge Durango Hemi/AWD
Old 09-27-2017, 06:02 PM   #19
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
I do it every now and then. Not for an hour, usually a lot less. Heck I do it while in the car nevermind the dog. Understandable being overly cautions, but my car is well maintained and serviced as needed.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 09-27-2017, 08:37 PM   #20
ITSNO60's Avatar
Tucson , AZ
Ford actually recommended that you park your vehicle outside and away from any structure if it was on one of the recall lists for 1. faulty ignition switch that can start fire or 2. faulty brake pressure switch that can start fire until you have had the repairs done. It was printed right on the recall notice I received in the mail.
Brian
ITSNO60 is offline   Reply With Quote
Old 09-27-2017, 08:43 PM   #21
ITSNO60's Avatar
Tucson , AZ
I will leave my diesel run if it will only be a few minutes (no pets), normally when I can see it, and when re-fueling. I put a steering wheel club on it and lock the door with my key if I have to walk away from it. The key ring in the ignition does not hold the key for the club. I just don't like to shut it off on short runs and high temperatures. Also the turbo needs a good cooldown period after a hard run, shutting down a turbocharged engine without at least a minute or two of idling can result in oil coking on the bearings.
Brian
Old 09-27-2017, 10:11 PM   #22
ITSNO60's Avatar
Tucson , AZ
And if your're worried about someone stealing it you could always get a trunk monkey
Brian
Old 09-27-2017, 10:27 PM   #23
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
We leave it running when it is hot and we are traveling with our dogs. Generally I park where I can see the truck, and always I go out and check on the dogs and check that the air conditioning is working every ten minutes or so. Sometimes its just a matter of practicality.
Old 09-28-2017, 03:19 AM   #24
2012 19' International
Southeastern MI , Michigan
I've seen them caused by leaves caught in the undercarriage, overheated catalyst from a misfire, and items left plugged in inside the car.
I've seen unattended junker cars with kids inside idling outside the grocery store. Amazing that the AC still works in some of the works of art I see on the road around here.
Countryboy59 is offline   Reply With Quote
Old 09-28-2017, 03:51 AM   #25
I drove highway coaches for many years.
There where many times that coach was turned off just to fuel it.!!!
It was parked in directl sunlight and on grass, concrete, pavement etc
Never ever started a fire inside or outside the coach
Can you just imagine the war that woukd happen if the air conditioning was shut down when the outside temps went to 105 degrees or the heat was shut off at minus 40 degrees??
But then again the passengers where just humans, not pets
Old 09-28-2017, 05:54 AM   #26
Yeah, semis and locomotives are left running for days too, but the OP asked about leaving a gas F150 running, not a bus or coach.
I don't judge, I just show up and put the fire out, then I go home.
Old 09-29-2017, 03:28 PM   #27
3wd67rg's Avatar
1988 32.5' Airstream 325
WhereIam , Left Coast Proud
Doesn't the Airstream have air conditioners? And a genny? Seems an easy answer to me.
3wd67rg is offline   Reply With Quote
Old 09-29-2017, 04:39 PM   #28
DKB_SATX's Avatar
1976 Argosy 28
If you're talking about one of the motorhomes, that's definitely a reasonable approach. However, for those of us with trailers, stopping en route at a truck stop or rest area for a brief time it's not practical to haul out and hook up a generator, wait for the interior of the Airstream to get to a reasonable temperature and put the dog back there. I also suspect that people who are afraid to leave the dog for 20 minutes in the truck with the engine running and AC on wouldn't trust their generator and Airstream AC for 20 minutes either.
— David
Leaving Fridge Running Idaho air Boondocking 8 05-16-2012 06:45 PM
Losing engine elec. engine dies while driving Clyde Gartma Airstream Motorhome Forums 4 12-10-2011 08:46 AM
Running the engine on Propane chasgould Mechanics Corner - Engines, Transmission & More... 8 05-24-2004 06:56 AM
OK, I'm leaving tomorrow to go get... drboyd On The Road... 11 07-18-2003 11:23 PM
Leaving!!! LKappenman On The Road... 0 03-07-2003 03:39 PM
