Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 12-30-2006, 04:15 PM   #1
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
Your best TV Maintenance Tips &/or Upgrades
How about posting your best tow vehicle maintenance or upgrade ideas here.....
for example -- add an inline transmission cooler in addition to the factory cooler, and a gauge to monitor transmisison temperatures.
--Use a 'water wetter', or coolant additive to keep radiator temps lower when towing. I like CRC ( sold at NAPA)
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 12-30-2006, 04:28 PM   #2
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
Change the oil. Goes without saying. I try to follow the company maintenance schedule as close as possible. They built it, they should know.
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 12-30-2006, 04:40 PM   #3
scf31
scf31's Avatar
Profile:  1977 25' Caravanner
winchester , Kentucky
Tire Air Pressure,,,, up high on my list ,
Master of Airstream
creations for less than 4 Years!
scf31 is offline   Reply With Quote
Old 12-30-2006, 05:00 PM   #4
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
Synthetic gear lube in the rear end, if your tow vehicle does not already have it. Reduces wear, and helps fuel mileage.
Change is inevitable, except from a vending machine
AIR#2611
Old 12-30-2006, 05:07 PM   #5
codybear
codybear's Avatar
Profile:  1964 22' Safari
SACRAMENTO , California
Images: 87
Check the brakes!
Stop and experience life.
You are invited to view my Blog:
http://berrytarts.blogspot.com/
codybear is offline   Reply With Quote
Old 12-30-2006, 07:20 PM   #6
ROBERTSUNRUS
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Hi, Wash it. Clean vehicles always run better, because you feel better driveing a clean vehicle.
ROBERTSUNRUS is online now   Reply With Quote
Old 12-30-2006, 07:43 PM   #7
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Add a MagHytec rear end dif cover on your first rear end lube change. From then on you do not have to fool with removing the pan, replacing gaskets, RTV or other sealers. All you do is unscrew the bottom magnetic plug, let her drain, wipe the plug off, unscrew the top magnetic dipstick tube, wipe it off and fill with the appropriate synthetic gear oil. There is one other hole in the cover which usually is set to let the lube weep out the hole when the dif is properly filled. This replacement aluminum cover uses a large O ring and I haven't had a single leak in over 56,000 miles. It is a breeze and just makes you want to change gear oil more often.
Add to this a dual bypass oil filtration system with larger filters. This increases the oil capacity and better filters are available. It also takes care of some of those crazy places manufactures put filters which drip oil all over skidplate pans, driveshafts, etc.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 12-30-2006, 07:49 PM   #8
SafeHarbor
Round on both ends
SafeHarbor's Avatar
Profile:  1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Get a diesel.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 12-30-2006, 09:56 PM   #9
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Oil changes and lube regularly at proper intervals
Moved to synthetic where possible
Air filter replacement at intervals or when needed
Tire pressures
Wash and a wax
I used water wetter too and found no change in temps before or after.
Cooling has rarely been an issue. I added a 160 stat to the sedan (came with a 180 degree stat) when I towed with it and it remained no higher than 190, even when towing when it was hot out.
The suburban sits at 210 and doesn't move past it no matter what....so far.
The trans cooler in the sub seem ok. Never saw temps hit 200 degrees yet, even when towing at grade....came close, maybe 190, but not 200. I was thinking of adding a fan to the factory trans cooler. I like the trans to stay at about 155-175, which is where it sits mostly...until I tow at grade or when I tow and it's REAL hot out.
Old 12-30-2006, 10:49 PM   #10
CA Streamer
CA Streamer's Avatar
Profile:  2005 28' Safari S/O
Atascadero , California
I added a camper shell to my pickup TV. Great upgrade. My 2 labs love to swim and can create a big mess in the AS when wet or when raining. Now I can just put them in the back of the truck...keeps me happy Of course, they get to stay in the AS when dry.
Also, I can put stuff in the truck bed and not worry about it being stolen, the the shell locks. It also provides shade for the dogs when traveling.
Steve-- "Mongo only pawn in game of life"
CA Streamer is offline   Reply With Quote
Old 12-30-2006, 11:13 PM   #11
Smuzz
Profile:  1971 31' Sovereign
Cleveland , Tennessee
If you have a Diesel you should have a EGT exhaust gas temp mounted pre turbo. This is especially important if you have any kind of chip or upgrades. I also agree with a real tranny temp gauge if you have automatic. You can find out alot about this stuff on some of the diesel truck forums. You really need to let diesels cool to 300 egt or below before shutting it down this may take ten minutes if you just pull off the interstate from towing hard. Most newer vehicle gauges are just idiot lights they have two or three settings in them and most likely won't warn you if you are right on the edge of overheating something. You would be amazed at how much thing change as you drive that the factory gauges don't reflect.
Smuzz is offline   Reply With Quote
Old 04-13-2007, 10:58 PM   #12
DIMMER
Vagabond
DIMMER's Avatar
Profile:  1973 31' Sovereign
Semi, Pro Rock Crawler , Motorsports Photographer
RainX!!!
Never has so few. Done so much, With so little, That now we can do anything, With absolutly NOTHING!!!! AIR# 300
DIMMER is offline   Reply With Quote
Old 04-14-2007, 07:22 AM   #13
Silvertwinkie
Aluminut
Thumbs up
Originally Posted by DaPlumber
RainX!!!
That's one meaty Suburban in your Avitar!
Old 04-14-2007, 09:57 AM   #14
Airhog1
Airhog1's Avatar
Profile:  1975 31' Sovereign
Searcy , Arkansas
I would love to see his trailer!
G
Airstream of Arkansas
www.airstreamofarkansas.com
877-Air-hog1
877-247-4641
Keeping the Airstream Dream Alive!
AIR #8844
Airhog1 is offline   Reply With Quote
Polishing tips? Rog0525 Cleaning, Stripping & Polishing 10 04-30-2007 08:27 PM
Tips for installing wood flooring? 64GT Repairing/Replacing Floor &/or Frame 31 12-05-2006 11:00 PM
winterizing tips for 1971 Safari frydmans Winterizing, Storage, Carports & Covers 9 11-25-2002 06:50 PM
Fixing things-'RV Repair and Maintenance Manual Joan D'Andrea Our Community 6 09-19-2002 04:49 PM
Quicky Hints and Tips FrankR General Repair Forum 5 07-22-2002 09:19 PM
