Old 02-13-2018, 07:40 AM   #15
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Likely that tail and tongue jack drag may be a problem. A 4x4 may do it. You will probably tear up your grass. Consider stationing a tow truck to winch you up, and down, at the top.
Old 02-13-2018, 07:56 AM   #16
Mollysdad's Avatar
With my luck the first time I tried it, it would be raining.
The shed would be a hood ornament.
Mollysdad is online now   Reply With Quote
Old 02-13-2018, 08:14 AM   #17
Lumatic's Avatar
1993 34' Excella
Images: 16
The total length of TV hooked to a 34 will be over 50'. A 34 triple axle will stand on it's own without the tongue dropping to the ground. If turning radius hitched to TV is a problem a tow truck stationed at the top may be able to winch up the trailer or even the whole rig.
Old 02-13-2018, 08:18 AM   #18
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Good visual, how wide is the 21% side from house to fence and from corner of house to corner of shed.
Seems the driveway sounds great except maybe to the wife.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 02-13-2018, 09:14 AM   #19
2014 25' FB Flying Cloud
Hillsborough , North Carolina
Does Enterprise Contract include towing
Does the Enterpirse contract include towing? If not, then if there is an incident, you could become quickly no longer covered by contract. So having a clear understanding of your personal car insurance coverage becomes important at that point.
GeeSag is offline   Reply With Quote
Old 02-13-2018, 09:29 AM   #20
1969 27' Overlander
Kimmell , Indiana
I would consider a 75-100 hp 4 wheel drive tractor for entry. Much easier to see and it will turn shorter. You could pull it out with a conventional TV.
Hoosierdaddy is offline   Reply With Quote
Old 02-13-2018, 09:47 AM   #21
2011 30' Flying Cloud
East Jordan , Michigan
What Hoosierdaddy said.
Plus with the ball on the tractor’s 3 point hitch, it can be raised and lowered easily to maintain ground clearance. We move our 30’ FC this way at our small campground. Works very well in tight, hilly spaces.
Klondike is offline   Reply With Quote
Old 02-13-2018, 10:16 AM   #22
2017 30' International
Lincolnwood , Illinois
trailer on property
In my community I could never get away with having a trailer on my property for anything more than 2 days. Village ordinance prohibits that. What do your neighbors think about the TT being there for a very long period of time. I would make sure that they are onboard with this, otherwise it could cause alot of friction. Check out to see if there are any village ordinances prohibiting this as well. Cross your T's and dot your I's. Cover all basis before you commit a significant amount of funds to your project. Better safe than sorry.
Milo1952 is offline   Reply With Quote
Old 02-13-2018, 10:54 AM   #23
2018 28' International
Fayetteville , Georgia
What about backing it straight down your driveway, which has less of a slope. Then use a powered trailer-moving dolly, such as a Park-It” to manoever around the retaining wall and into the back yard?
brick
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 02-13-2018, 11:15 AM   #24
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Best idea yet!
Tool rental yards often have farm tractors for rent. Actually a 50 hp should have enough weight. Make sure the tractor weighs at least 5000 lbs.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 02-13-2018, 11:18 AM   #25
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
A LOT of good ideas here. One possible other solution might be to rent vacant commercial space month to month. I recently saw a vacant Walmart store being used as covered storage and maintenance for RVs. The down side is that if the property management company gets a new tenant, the RVs will have 30 days to vamoose. The store had been empty for 3 years so?
The cost was surprisingly reasonable... and at last count almost 30 rigs are stored. Gasoline, propane and diesel have to be emptied, but rigs can be pulled outside if those systems need work.
Old 02-13-2018, 12:10 PM   #26
2007 27' International CCD FB
San Diego , California
Given the drawing, I would back the trailer into the backyard via the driveway and 12% grade. If you can pull it out that way, you can generally back it in. How wide is the side yard on the 12% side?
4x4 short wheelbase SUVs certainly have an advantage in this regard. I can readily get my trailer into my narrow sideyard entrance which is pinched off at the front as I'm in a cul-de-sac. I've done it many times with my car alone, but my Trailer Valet XL dolly is safer for sightlines of course. I wouldn't use a dolly on a grade, especially if the tongue is on the uphill side.
If your 12% side yard is wider than this, I think you can likely do that same and back her in. A tractor would certainly give you the maneuverability to do it.
2007 27FB Ocean Breeze "See Turtle"
2009 Lexus LX570
pteck is offline   Reply With Quote
Old 02-13-2018, 12:26 PM   #27
1976 31' Excella 500
Chappell Hill , Texas
I think it will wind up further from the fence than you are showing. You don't appear to have enough straight fence along the back to straighten it out like you have shown, at least not without a great deal of finagling. Also the tail might hit the fence making that turn. I agree with taking the neighbors fence down. You may need it as close to that back fence as possible to get it around the exit turn and still clear the house.
tbashin is offline   Reply With Quote
Old 02-13-2018, 01:02 PM   #28
Boxite's Avatar
2008 22' Sport
If you (as it reads) are going to RENT a truck for a TV just to make this re-positoning effort.... I'd recommend you make your life simpler and lay the responsibility for the job and safety onto a wrecking-truck company to do this job for you. A good winch-truck operator could do this in an hour and you'd be assured of a professional job and you would not be responsible for an ad-hoc attempt at something you've never done before.
Otherwise...if you're insistent on doing this yourself.... the recommendation to rent a 4-wheel large tractor is a good one. Back it up with a winch and cable to govern the descent so things don't get away from you... but be forewarned...
...just because you've rented the correct equipment (tractor/winch/etc) doesn't mean you have the experience and skill to operate it correctly or safely. Lots of city-folk move out here in the country near me and end up in the news with overturned tractors having killed them because they thought they were "saving money" instead of hiring a job to be done by experienced professionals.
Stay safe. An injury or damage can cost far more than a job hired-out.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
How far would you drive in a vintage MoHo? cdufault Argosy Motorhomes 37 07-23-2016 12:29 PM
4th Annual Texas Hill Country Rally- The Cat in the Hat visits the Texas Hill Country bwoodtx The Rally Zone 92 04-07-2016 08:52 AM
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Hank Hill Would Approve ;-) fotochop Fun & Games 2 02-19-2010 04:16 AM
Drive vs Over Drive joshua32064 Tow Vehicles 10 10-17-2003 01:25 AM
