Old 04-09-2017, 05:14 AM   #1
gomotomoto's Avatar
Longport , New Jersey
wiring harness question
Recently, I purchased a 2008 LandCruiser for the purpose of towing our family airstream. It did not come with a wiring harness, so I purchased the hopkins plug in harness for the factory tow package. It has a 7 way and a 4 flat as well.
Install was simple enough, few bots and two plugs that go right into the ports on the LC. I checked the two plugs against another 200 series LC that actually had it installed from the factory -- nothing to it... plug and play...
When I plugged the airstream plug in the harness on my 2008, it wasn't working -- only one of the turn signals was operating, nothing else.
I check all the related fuses and there was actually a micro 30amp (towing tail) that was blown. I replaced that.
Still not working. I used a test light and OM meter to confirm. Nothing operating.
Any ideas on what might be causing the issue?
The only other thing, probably unrelated was that my brake controller light isn't going out once the truck is shut down. I thought that was odd -- again, probably unrelated.
Trying to save a family trip in a week -- any help appreciated.
gomotomoto is offline   Reply With Quote
Wiring harness jwebb90162 Electrical - Systems, Generators, Batteries & Solar 2 02-07-2012 03:53 PM
Brake Controller Wiring Harness wlanford Brakes & Brake Controllers 3 08-01-2011 12:14 PM
Coach wiring harness to batteries ? John H. Classic Motorhomes 16 03-28-2011 10:52 PM
New wiring harness RiverRat Lights - Interior & Exterior 9 06-16-2009 02:42 PM
7 Pin Wiring Harness Replacement Jake Electrical - Systems, Generators, Batteries & Solar 4 09-27-2005 08:05 PM
