Old 01-31-2009, 03:02 PM   #1
6PackCharlie's Avatar
1995 30' Excella
Logan , New Mexico
Wiring 2008 Dodge 2500 to 1985 Excella
I just bought a 2008 Dodge with a 7 pin flat plug and I need to wire my 85 a/s that currently has a 9 pin round plug (I assume you have to do away with the tire-tele wire and the refigerator switch wire?). I have grounded the pickup to the trailer. When I hook a tester to the pickup and then to the corresponding wire on the a/s nothing on the airstream will light up. Can anyone give me a hint on what I am doing wrong?
I have all the diagrams, but can't figure why nothing will light up. I am going to put a 7 ping trailer plug on the a/s.
6PackCharlie is offline   Reply With Quote
Old 01-31-2009, 03:11 PM   #2
SteveH's Avatar
Common Sense , Texas
Obviously you can do that if you want, but wouldn't it be better to install a 9 pin round connector on the Dodge and wire it up? You will need at least 8 of those pins, 9 if you wire up the backup lights.
Just my opinion.
Old 01-31-2009, 03:27 PM   #3
1995 30' Excella
Logan , New Mexico
The 9 pin on the a/s is pretty much shot. I already have the 7 pin plug to replace the 9 pin, but I can't get any of the lights on the a/s to light up. I may go back to a 9 pin later, but I need to get ready to pull the trailer by February 13th. All the lights were working on the a/s when I parked it in October.
Old 01-31-2009, 03:31 PM   #4
SteveH's Avatar
If you can't get ANY of the lights to work, it is most likely a ground problem.
Old 01-31-2009, 04:07 PM   #5
1995 30' Excella
Logan , New Mexico
Figured it out. My test probe was showing continuity, but wasn't pushing enough juice to light the lights. Used alligator clips with 16 guage wire and the lights worked. Thanks for you suggestions.
Old 01-31-2009, 05:54 PM   #6
SteveH's Avatar
Glad you got it figured our. Good luck with the rest of it.
07 Tundra vs F250 vs Dodge 2500 vs Chevy 2500 outthere Tow Vehicles 248 01-13-2011 09:48 AM
2008 31' Classic / 2008 Silverado 2500 4x4 duramax ddarr2 Member Introductions 19 03-09-2010 01:14 PM
Dodge 2500 Brakes YIKES! Trackers Tow Vehicles 7 10-14-2008 03:26 PM
Dodge Ram 2500 Diesel Foiled Again Tow Vehicles 23 10-18-2007 10:01 AM
Will 2000 Dodge RAM 2500 with Cummins 5.9L tow A/S well? idahosafari Tow Vehicles 23 03-11-2004 03:34 PM
