Old 10-15-2018, 07:23 AM   #1
Dexter , Michigan
Winter towing
Hey group
We are considering a fall trip in Winnipeg.
Does anyone have experience in winter towing?
Our concerns are with snow, salt, ice, on the road more so than in camp.
Any pointers would be greatly appreciated.
Rusty
RustyB is offline   Reply With Quote
Old 10-15-2018, 08:23 AM   #2
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
1. Winterize the plumbing system.
2. Slow down if the roads are slippery.
3. If the roads are slippery (heavy rain or snow and ice), after you have slowed down (point 2.) back off the anti-sway bars if your rig is so equipped, eg. Eaz-lift. (I am not sure how users of Equalizer, Hensley, Blue Ox etc. where anti-sway is part of the weight distribution setup accomplish this.) This is extremely important to make sure your trailer doesn't force your TV into an understeer situation.
4. Keep the furnace running in the trailer when travelling. You will use quite a bit of propane, but the trailer will be comfortable for sleeping when you arrive at your stop.
5. I use auxiliary propane heat from a Dickinson Newport Marine fireplace, but I make sure to use the furnace enough to keep the plumbing safe if I haven't winterized the trailer.
6. Have a way to keep you house batteries charged up at night to run the furnace if not on shore power. (I use '0' gauge booster cables from my TV with a remote start. I can put 40 amps into the batteries much more quickly than with a generator.)
7. You can get your rig washed at a Blue Beacon truck wash to remove salt and road grime.
8. Use 'wag bags' for solid human waste disposal rather than putting anything into the black or grey tanks.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is online now   Reply With Quote
Old 10-15-2018, 08:39 AM   #3
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Originally Posted by RustyB View Post
Hey group
Rusty
Stay home , when there is snow and ice on the road...salt will eat up the aluminum.
Old 10-15-2018, 09:47 AM   #4
1994 34' Excella
Warren , Manitoba
We live 20 miles north of Winnipeg. You will have a hard time finding any place to camp now. Most trailer parks have closed for the season. We have had 10 degrees of frost, and all campgrounds have drained their water lines. Looks like nice weather for the next week or so, but there is snow on the ground outside my house. Our trailer has been in storage for 2 weeks. There are lots of hotel rooms in Winnipeg, and that would be my choice at this time of the year. JMHO Chris!
WBCCI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 10-16-2018, 01:39 PM   #5
2016 25' International
Deerfield , Massachusetts
Even without snow and ice, your tires lose some of their grip when temps are low. (Snow tires aren't just like boots for the snow, they are also softer for the cold!)
thiel is offline   Reply With Quote
Old 10-16-2018, 02:54 PM   #6
Half a Rivet Short
Carlisle , Pennsylvania
Hi
If you are trying to heat the trailer ( not sure what you have since it's not on your profile ... hint .... hint ... hint ... ) you likely will use more that a little propane. Running out while you are in motion is not a lot of fun ( fridge ...). I'd factor tank refills into your travel plans.
The only practical way to do this is to dry camp. No water in the trailer, none of the plumbing in use. That way the 10F (or less) temperatures aren't going to nuke you right off the bat. It also eliminates the need for dump stations (which are closed ...) or water hookups (which are shut off ...).
We now get to the basic question - why bring the trailer?
Assuming there is a good reason, salt is very much your enemy. You can wash the obvious stuff off. The bigger issue is the stuff that gets back in someplace. That is very hard to wash off. Once it gets going, you have a rust issue where you really can't see or get at it. About the only answer is to wash down several times a week and hope that's good enough.
One of the neat things about Airstreams is the way the rubber in the suspension works. That's great at normal temperatures. Get really cold and you have a bit more shake rattle and roll. Run down a road in the winter and it likely is a bit rougher than normal. The combo means that you need to be more careful about things coming loose / staying tied down in your vehicle. Again - part of this assumes a trailer ...
Lots of fun !
Old 10-16-2018, 09:18 PM   #7
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
winter towing
I was wondering this to. But, in my case I would leave Cleveland, OH in January for Florida. And retuning in February or March. But, it would could still be freezing in Cleveland.
The salt is the real issue for me. Also the brine some city’s use.
I was warned about the truck washes. They use acid in the wash process.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 10-17-2018, 05:03 AM   #8
2018 28' International
Fayetteville , Georgia
Don’t do it. Or your trailer will match your name...
brick
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 10-18-2018, 07:02 AM   #9
Half a Rivet Short
Hi
On a practical basis:
When you pull the trailer down to Florida, it will be winterized. Once you get past a "safe" point, you will de-winterize it. Before you head back, it will have to be winterized again. Two months later when it is camping time, you will de-winterize it yet again.
If this all involves anti-freeze and compressed air, that's a lot of work to winterize. If it takes two days to flush lines, that's a bit of work as well.
Travel wise, you can go a lot further / faster flying than towing a trailer. Even driving, you can cover more miles if you are not towing. There will be days added to travel time if you pull the trailer. (We tow for about 4 hours a day. If we were driving it would be 10 hours).
Once you get to Florida, it's February. Where will you be staying? How much will that cost? .... hmmm.... all booked up here .... all booked up there .... costs how much over at that place ... YIKES !!!
Lots to think through.
Old 10-18-2018, 12:47 PM   #10
Blue Beacon, which I have used, does not use acid wash except at the driver’s request. They also have an anti salt undercarriage treatment.
Ray B.
Old 10-20-2018, 09:34 AM   #11
Hi
Huh? Two days to flush the lines?
Old 10-20-2018, 09:40 AM   #12
Half a Rivet Short
Hi
Yup, that's what the full drain fresh water tank / blowout process can take on a big trailer .....
Old 10-20-2018, 10:50 AM   #13
dznf0g's Avatar
Oswego , Illinois
Hi
I'm in the "huh" camp too. Last week, about 1.5 to 2 hours to blow out lines ,bypass water heater and filter, and install antifreeze. On a 30 classic. Spring drain flush and make ready, takes maybe 2 hours.
-Rich-
Old 10-20-2018, 11:51 AM   #14
Half a Rivet Short
Hi
Pop open the drain on the fresh water and it's still dripping 18 hours later. Blow out the lines and you get them completely dry. Come back after they have settled for an hour and you get water once again. Let it settle for another couple hours, blow out for 15 to 30 minutes and they are totally dry. Settle again and you get water .... keep up the step and repeat ....
Winter towing tips hshovic Towing, Tow Vehicles & Hitches 6 07-06-2009 07:23 PM
winter driving/towing codybear Winter Living 8 11-13-2006 06:55 PM
Winter? What winter??? Pahaska Off Topic Forum 21 01-06-2006 09:17 AM
Winter Towing - NJ to Florida tlake On The Road... 16 10-06-2004 10:18 PM
Winter Towing dmac Towing, Tow Vehicles & Hitches 15 10-25-2003 06:04 PM
