01-27-2006, 07:42 PM
#21
1978 31' Sovereign
Texas Airstream Harbor
, Zavalla, in the Deep East Texas Piney Woods on Lake Sam Rayburn
re: Tires and Brakes - TV or Trailer???
Originally Posted by crsdawg
wow, thanks for all the replies......so far here's my plan if i go through with the purchase:
check brakes
new tires
trans cooler
wd hitch
brake controller
new fluids
did i miss anything? to be honest half this stuff i need to do anyway...
I would clarify here - check both the TV AND the trailer brakes and tires.....
There is a good chance the tires (and rims) on the trailer are - shall we say - on the vintage side. Most of the consensus here within the Forums is not to take a chance if the tires are more than 7 years old - check the trailer brakes and repack the bearings while you have the rims off for the tires - don't forget a premium wheel balance after the new tires are mounted...
Luck - please let us know what you do and how it turns out -
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
01-27-2006, 08:37 PM
#22
2002 34' Classic
Kingwood
All we can say is that we wouldn't tow a 31 footer with a Safari w/ V6. Too short of wheel base and no power to control it if you need to. I can't believe anyone who has towed any length of time would go along with this.
01-27-2006, 09:59 PM
#23
2003 19' Bambi
Lincoln City
, Oregon
Anythings possible; maybe?
First impression about doing this with the van is "If there is a safer way please do it"
Some folks here say yes it can be done but with these precausions...... Others "Not a good idea"
I say hey if your lucky you can probbably make it. But what if your not lucky. What if that trailer over- powers you in an emergancy stop situation. The term tail waggin the dog was used. Think about grabbing a dog and waggin it with its tail... Not a pretty picture.
Imagine a 300 pound person running into the back of you while you are waiting at the bus stop and you get pushed off the curb into the street.
Or how about an 18 wheeler flying by you because your too slow in the right hand lane and the wind sucks the trailer and then your tow vehicle toward it.  This is what it can feel like in this kind of towing situation.
Ok I am off the soap box. Please consider a rental truck, or have a freind haul it for you. Yes money is a little important, but your personal safety is priceless, do this trip knowing you have the odds in your favor.
"No good dent goes unpunished."
01-28-2006, 12:42 AM
#24
2002 34' Classic
Kingwood
Campcollector. I couldn't have said it better!! But take it from someone who has been there. Try a 31 foot behind a full size big Dodge station wagon in the hills in California and you get hit by wind sheer from behind. We were out if control for 1/2 mile and took up all four lanes. The trailer was laid on both sides. It ain't fun.....
01-28-2006, 01:04 AM
#25
give tvtransport a call they are good people!!
01-28-2006, 01:39 AM
#26
Naysayer
1968 24' Tradewind
Louisville
, earth
[quote=campcollector
I say hey if your lucky you can probbably make it. But what if your not lucky. What if that trailer over- powers you in an emergancy stop situation. r favor.[/quote]
But what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not luckyBut what if your not lucky......you get the idea....
01-28-2006, 06:28 AM
#27
1968 24' Tradewind
Rural, blink and you'll miss it
, Missouri
Just because it "can" be done doesn't mean that it "should". Please be careful!
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
01-28-2006, 09:33 AM
#28
Elgin
I think everyone agrees that this is a true roll of the dice, either way. However, I think since we are talking about a one-shot deal, one-way, the odds are in your favor. It would however, be the "acme of foolishness" to try to do anything more than to use it to bring the trailer straight home. I can tell you with a reasonable degree of certainty that no one here would advocate using this van as a regular tow vehicle. That said, Airstreams tow beautifully, but do not let that lull you into thinking that it's okay to run the posted speed limit in all cases with this setup. I'd propose running at least 10 mph under the posted speed limit in virtually all cases, do your utmost to avoid congested driving conditions wherever possible (meaning plan your route very carefully, in terms of times of day, as well), and by all means, keep an eye on the weather. There will definitely be some driver fatigue, so take as many rest breaks as you can, to keep your skills as sharp as possible. In short, take your time.
01-28-2006, 10:30 AM
#29
1996 30' Excella
Bowmanville
, Ontario
I have to put my 2 cents in, consider that the brakes on the trailer may not be up to par. If the trailer has been sitting a long time or the previous owner hasn't maintained the trailer brakes, brake springs rust and fall apart leaving your trailer brakes useless and then it will put more strain on your TV brakes. When I drove 2500 miles to pick up my 8 yr old trailer I heard a swish swish sound coming from the wheels, brake parts rolling around inside the wheel. Consider insurance liability if in a worse case scenario, you couldn't stop in time and had a fender bender, this could cost you more than you ever thought. The rent or borrow a TV sounds like the best bet. Maybe alot cheeper to see if someone from this forum has the time to help you with this little adventure.
Hensley Hitch, Jordan controller
01-28-2006, 02:43 PM
#30
1970 31' Sovereign
Portland
, OR
Are you sure you don't know anybody with a trailer who might have a tow vehicle? In-laws, out-laws, bored snow birds, Craig's List? Maybe your buddy with the truck would like to get away for an adventure? By the time you install a brake controller, trans. cooler, etc., etc, it will be easy to drop $1,000, and if you're not going to use it again to tow, that's money you could spend on a rental, if you could find one with a brake control. I used to have to tow a trailer that was too heavy, with no brakes, twice a year, 60 miles. You can NEVER fully relax. 1,500 miles is a long way.
01-28-2006, 03:00 PM
#31
_
hi crsdawg and others
welcome to airstreamin'
i think there is another forum somewhere for 'accidents waiting to happen'
my approach would be to find someone who has one,
or rent a flatbed truck. load it and tow it home.
then you can replace tires and service brakes, bearing, suspension, hitch, lights AND figure out mods for the van in the comfort and leisure of home.....
why spend on these items just to tow it home?
you might end up wasting money on the t.v. only to trade it.
might get a better deal on trailer tires and so on......once it's home.
if you are pinching pennies to get it home you will likely "inspect" the safety issues with a bias toward 'maybe i can make it one time' and the base t.v. is just the tip of towing cost issues.
how much does it cost you to really look around for a flatbed towing option? that would me my mode de travel......
cheers and happy travels
2air'
01-28-2006, 04:27 PM
#32
418
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley
Not good!
I recently towed a 70's Excella 500 for about 300 or so miles with my Suburban.
It was not a light or easy to handle trailer, with bad axles and cheap tires. It towed very poorly. It also felt much heavier than it's advertised weight, even though it was empty of water and propane.
In it's defense, i did not spend a whole lot of time setting up the weight distribution, nor did I adjust brakes or bearings etc. Everything was supposed to be recently done by the PO.
In retrospect, I would have used a heavier tow vehicle to drag this old trailer home.
I can not recommend using an Astro Van to tow a 31ft trailer like this in questionable/unknown mechanical condition.
01-28-2006, 05:01 PM
#33
2003 25' Safari
Eden Prairie
Where is the trailer located? Perhaps someone on the list would go look it over for you... to ensure the "bargain" trailer is a good one.
I also recommend renting a truck. It may cost about the same as outfitting your van.
Dan
01-28-2006, 09:27 PM
#34
2002 34' Classic
Kingwood
I am so glad to see that others agree that it isn't smart to tow a 31' with a Safari. Safety is ALL that matters when towing, don't just think of yourself but of the ones you might take with you if you loose control. Our 79 Excella 500 weighed in at 6080 pounds empty. We had to have it weighed so we took out anything that would add weight, mattresses, food, water, etc. The book said dry weight was 5858. So if you are only supposed to tow 5500, you will be over weight and with what you are towing with, that's not smart. Can't you find something closer, surely there is an Airstream closer to you for sale and maybe the seller would deliver it to you? ou might pay alittle more but you'll be safer and in the long run, cost alot less.
01-28-2006, 11:16 PM
#35
N/A
, Missouri
i wanted to tell everyone that i've decided to hold off on this particular trailer.
i look at the numbers and my van will pretty much at it's limit. i think i'd be ok for a short trip, but after looking at mapquest and doing the math, i'd be towing for 3 1/2 days. that's just to big of a window for something to go wrong. the AS is sweet(dent free, great int, everything working, new tires....)and it's a good deal and all, but my gut(along with many posters) keeps telling me to pass. if it was a shorter trip i don't think i'd be so hesitant. i wish using another tow vehicle was an option, but it's not. the $'s just don't add up. by this time i'm sure the rig has been sold, so it's probably a moot point anyway.
i've decided to be patient and try to find something closer to home. anyone know of a reasonably priced 31 footer somewhere near southwest MO?
thanks again for all the advice, this forum is great.
01-28-2006, 11:39 PM
#36
2002 34' Classic
Kingwood
CRSGAWG, I think you made a wise choice. Better safe than sorry. I know you had your heart set on this one but something better will come your way. I can tell you from experience that totaling an Airstream just makes you sick, totaling 2 of them makes you even sicker but certainly more careful. Good luck on finding the right one for you, it's out there .
02-01-2006, 09:05 PM
#37
Grand Rapids
, Michigan
hiya guys, great site. i hope that asking for answers on a first post isn't looked down upon, but i'm getting very close to pulling the trigger on a '70's excella 500 and i'm worried about getting it home. the trailer is pretty much going to be my stop gap living quarters for awhile. i want to go with airstream because they hold their value, and are just plain cool. i figure if i'm going to become trailer trash, i might as well have some style while i'm at it.
anyway, here's what's bothering me, my tow vehicle is a gmc safari, and the AS i'm looking at is about 1500 miles away. i've looked at the #'s and it's kinda close. the excella weighs in at 4800 lbs, and my truck has a towing capacity of 5500 lbs. the trailer will be dry and i'm just going from A to B. i realize this is not the actual tow weight of the trailer and that's what's worrying me the most.
my question, is this going to work?
getting this trailer would really help me out and it's a bargain(why i'm willing to go so far for it), but i sure don't want to destroy my van getting it here. i've actually seen a couple guys mention they've towed 31' AS's with an astro/safari, but everyone else seems to have v8 suburbans or 3/4 tons. is my van going to be ok for the one long trip? once i'm back home i will probably not move it much.
i'll be on interstates almost the whole way and will only have one area of moderately sized moutains to cross, not i-70 corridor type stuff by any means. after that i'll be going through the northern plain states and then south through MO for the rest of the way home. while i've never towed anything this long before, i'm very experienced with shorter trailers, so driver skill shouldn't be a major factor.
i've thought about adding a trans cooler, beefier shocks,and a wieght distribution hitch, to help out. would those changes make any difference?
any input would be appreciated.
Sorry for my ignorance, but what size is an excella 500? 50 feet? I also am planning to pick up my new (2004) 19' Bambi in Tampa and haul to Michigan. I have a 2000 Astro van and was planning on hauling it that. As I speak, I have a 2002 Yukon Denali in my driveway- brought it home from the dealership tonight to test drive. I think I'm going to buy it and feel REALLY good about hauling that silver honey box home. I know this isn't any help for you- I'm just excited and wanted to share!  I was nervous just with the 19' so I understand your consternation over this. Good luck!
02-02-2006, 10:13 AM
#38
Elgin
The Excella in this particular thread is a 31' I believe.
Buy the Yukon and use that to tow your Bambi home. Congrats on your new Airstream!
