Old 03-02-2019, 12:53 PM   #1
2018 27' Globetrotter
Mooresville , North Carolina
Which TV Trailer Brake Fuse – 2018 GMC 2500 TV
My vehicle has a 30 amp trailer brake fuse. It is not the standard 2 blade fuse I am used to. It is rectangle shaped, see the pink fuse in the center of the attached picture. I have read that some GM products have this fuse to blow and then your trailer brakes can’t activate. I wanted to be proactive and carry a spare.
The owner’s manual does not give a part # for this. I went on Amazon and there are various options to choose from. There are low profile, standard / tall profile. They can be;
ATR – single circuit protection
ATL – dual circuit protection
FMM – newest and smallest fusible link
I saw a Bussman FMM-30 Maxi Fuse (slow blow Micro Female) that looked promising and reviews said if worked the Chevy Silverado. However, a message popped up for this item that said it wouldn’t fit my vehicle.
Which one do you purchase?
Name:	Trailer Brake Fuse.jpg
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Hitch
"Roadrunner"
GOUSC is online now   Reply With Quote
Old 03-02-2019, 01:27 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I believe that fuse is for 12v hot power to charge your travel trailer batteries.
I have lithium, and due to the voltage requirements that differ from the GM alternator I actually pulled that fuse so as not to mix voltages. Brakes work fine and are powered by a different lead. I have a 2017 2500 HD, same truck.
wulfraat is online now   Reply With Quote
Old 03-02-2019, 03:32 PM   #3
I've attached a copy of the fuse diagram from my owners manual. If I'm reading it right, (and it's possible I'm not), It appears to me the 30amp fuse I'm referring to is fuse #1 for the trailer brake. Fuse #2 is for the trailer batteries and is a little further away. It is not in my original picture but would be below fuse #63, the trailer parking lamps fuse.
Name:	GMC Fuse Diagram.jpg
Equal-I-zer Hitch
"Roadrunner"
Old 03-02-2019, 09:03 PM   #4
wulfraat's Avatar
Looks like you are correct (sorry was going from memory). The battery fuse looks to be the same format (30A). That could certainly act as your spare in a pinch (remove battery fuse and use for trailer brakes).
Old 03-03-2019, 09:39 AM   #5
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 86
That is likely not a fuse. It is probably a circuit breaker. Your truck should have the built in trailer brake controller, a trailer brake power control module, and there may be more than one involved.
Only replace it with the proper type!
If you cannot get to an auto parts store, and you say it looks like a MaxiFuse, see if it matches a Bussmann CB1921-30 Type II MAXI style breaker, or it may be the smaller Bussmann CB222-30 Silver-Colored Type II ATC style breaker.
The key is which circuit breaker type GM uses in that position, given the brake controller circuits.
Type 1 - Automatic Reset: This type of breaker will recycle on-off continuously when overcurrent does occur.
Type 2 - Modified Reset: the breaker will remain in the tripped position as long as there is power to the circuit. Once you remove power, the circuit breaker resets.
Type 3 - Manual Reset: the breaker stays tripped until you reset it, usually with a button or lever.
Within our Airstream, there is a type II breaker in the breakaway switch circuit.
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2017 Infiniti QX80 Limited
ProPride 3P/Prodigy P3
gklott is offline   Reply With Quote
Old 03-03-2019, 10:10 AM   #6
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
GOUSE....Just stop at any GMC or Chevrolet dealer and they can match you up with the proper part.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 03-03-2019, 10:32 AM   #7
All good advice. I had read on a boat forum I follow where people have had issues finding these fuses at dealerships and auto parts stores when on the road.
I'll start with my local dealer / also ask them the suggested questions and go from there. Thanks to everyone for the suggestions.
Equal-I-zer Hitch
"Roadrunner"
Old 03-04-2019, 12:54 PM   #8
Just for closure on this item. The dealership did not have this fuse in stock, nor could they supply a correct part # for it. They suggested NAPA. NAPA did not have it in stock and they could not provide a part #. Auto Zone had it in stock. Attached is a picture of the fuse packaging in case anyone needs this in the future.
Name:	GMC Trailer Fuse_30amp.JPG
Equal-I-zer Hitch
"Roadrunner"
2018 Classic 33 Which AC is Which? jrkott 2016 - Current Classic (all lengths) 15 11-10-2018 08:53 AM
Trade in 2015 Ram 2500 for 2018 GMC 3500? Rgentum Tow Vehicles 28 11-18-2017 10:38 AM
Univolt internals - which fuse is which? barts Batteries, Univolts, Converters & Inverters 9 08-13-2017 09:18 AM
What size drop down for GMC Sierra GMC 2500hd? JJ1 Tow Vehicles 4 11-15-2016 04:50 PM
2015 Chevy 2500 LTZ HD vs GMC 2500 Denali HD Roadtech Tow Vehicles 2 10-21-2014 05:47 PM
