Old 07-16-2017, 07:05 PM   #1
2010 30' Flying Cloud
De Pere , Wisconsin
Which spring bars for Blue Ox sway pro, Flying cloud 30 and F350
We just picked up a 2010 Flying cloud 30RB and have a 2017 Ford F350 crew cab short bed diesel truck.
When towing the trailer home we just dropped the trailer on the ball and drove home. I was really concentrating on being careful but honestly besides looking in the mirrors and knowing I had a whole lot more cash out lay riding behind me the rig towed beautifully. We will tow 5-8K miles annually and we are new to this so I know we should have some sway control.
The FC 30 has a GVWR of 8800 lbs and that puts the tongue weight and potentially a little over 1000 lbs I would assume - maybe even a little more?
Anyone towing a 30 footer with the BOSP and what spring bars are you using? I would rather not bump up to the 1500's as they seem like overkill in my mind. My main reason for the hitch is to control unexpected sway as the trailer honestly doesn't seem to need weight distribution. It actually rides better with the Airstream on just the ball than it does empty!
2wiresdave is offline   Reply With Quote
Old 07-16-2017, 07:15 PM   #2
Frederica , Delaware
I had SOB that was 32' 8800 lbs. I was using 1500 lbs bars after switching from 1000 lbs bars. For me it was a much better performance. TV was '16 F250. Those 1500 bars are for sale.
Overloaded is offline   Reply With Quote
Old 07-16-2017, 08:33 PM   #3
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Blue Ox tech support will tell you to use bars that match the tongue weight. A 1000 lb tongue weight should use 1000 lb bars. Part of the analysis might be to start with 1000 lb bars and see if you can transfer enough weight to return the OEM weight to the front axle. Since you have an F350, I suspect the 1000's will work, but if you are not happy, you know where to go for a set of 1500's.
Good luck with your rig setup. Pat
PKI is online now   Reply With Quote
Old 07-17-2017, 05:57 AM   #4
2016 30' Classic
Little River , South Carolina
I have a 2016 Classic and 2017 Ram 2500 Cummins Diesel with air suspension rear springs and blue ox hitch. I honestly cannot tell any difference in towing with my 1000 lb bars hooked up or towing without the bars. I have tried this in all kinds of conditions, passing trucks, up and down mountains, back roads, four lane highways. I usually tow at 70 miles per hour or less. Now i just drop tongue on the ball and go. Never a problem.
Wilbur McLamb
Wilbur McLamb is offline   Reply With Quote
Old 07-17-2017, 06:51 AM   #5
De Pere , Wisconsin
I feel as though I have to have sway control just "because"....however Ford specs on my truck say nothing needed. I certainly don't need weight distribution as the Airstream dropped on the ball just slightly compressed the truck. Drove some very bumpy concrete slab highway and had zero porpoising. Truck ride better actually with the Airstream behind it.
The BOSP seems like a simple safety net for the sway control and I don't want or need any, or at least very little weight distribution.
Leaning towards the 1000 lb bars at this point.
Old 07-17-2017, 12:56 PM   #6
Sonoma Co. , California
Ford says you don't need added sway control because your newer truck has built in electronic sway control (ESC) thru the onboard computer. ESC started out years ago as an option on luxury cars. Since then it has progressively improved and proven to be so effective that it has become a standard feature on every vehicle. As you've seen yourself, your TV/trailer behaves perfectly well with the ESC technology...no need for anything else.
USAtraveler is offline   Reply With Quote
Old 07-17-2017, 02:04 PM   #7
Anna Maria , Florida
On 3/4 and 1 ton trucks you don't need to worry about WD. As it was noted earlier don't use any heavier bars than necessary. The stiffer the bar the harder the ride on the Air stream. That is another benefit of towing with a heavier truck. The WD hitch is mainly needed for helping with sway control.
franklyfrank is offline   Reply With Quote
Old 07-17-2017, 02:23 PM   #8
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The only way to know if you need w.d. is take the truck and trailer to a CAT scale, loaded for travel. Weigh the truck alone and then with the trailer. Then ask if you need w.d.
The only way to know if you need sway control is when something different than going straight down the highway happens. Someone forces you into a quick lane change while applying brakes on a steep downhill grade. Then you will know if you need sway control. And you may not need to look into the mirrors to see if it's there when it's alongside of you.
Doug and Cheryl
Old 07-17-2017, 03:05 PM   #9
Cary , North Carolina
Blue Ox Sway Bars
I just ordered the 1500 pound bars to use with our new 26U that has a spec' tongue weight if 900#. I wanted a little bit of margin. That said I'll be selling my 1000# sway bars that we used for our 23FB.
How does $175.00 sound?
Lil Bear is offline   Reply With Quote
Old 07-17-2017, 04:32 PM   #10
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
I have 1,000# bars on my BO set to the 8th link from the bitter end in the jaws. Tried 7th and 9th, but 8th provides much smoother ride for the AS. My Classic 30A tongue weight is about 765# compared to my former Serenity 25FB at 833#.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 07-17-2017, 04:45 PM   #11
Senior Member
sheriff1's Avatar
2014 30' Flying Cloud
Sparks , Nevada
I think I'd keep the 1000 lb set for a while, I suspect you will be happier with them than the 1500s
sheriff1 is offline   Reply With Quote
Old 07-17-2017, 04:46 PM   #12
Muscle Shoals , Alabama
Dave,
My TV is a Tundra which tends to have softer springs. With that in mind I ordered the 1000 pound bars for my 30' Classic. 1000 pound bars are rated for 800-1000 TW when ideally using the recommended 9th link on the adjustment chains. This did not work for me so I upgraded to the 1500 pound bars using the 8th chain link (1100-1500 pounds). The blue ox sway pro works great now. But the one issue I have is with the rotating latch mechanism for the chains. If you go with the 1000 pound bars you may find yourself using the 9th or 10th chain link which will require you to jack your trailer up high to relieve the tension on the bars enough to rotate the latch. If you don't relieve the tension it could hurt you or damage the trailer when the latch is released. With the 1500 pound bars using the 8th chain link handles the load and is easier to rotate the latch mechanism.
mschneid is offline   Reply With Quote
Old 07-17-2017, 04:47 PM   #13
De Pere , Wisconsin
I haven't even bought a hitch yet, but I appreciate the offer.
Old 07-17-2017, 05:56 PM   #14
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Still working through this...
Originally Posted by mschneid View Post
Dave,
I have been working through this discussion in another post with several folks saying the 1000lb bars should be fine...I got the 1500 lb bars with my 28' few weeks back. BO recommended these over the 1000lb bars, as my tongue weight is at least 1000lbs verified by dealer weighing, unfortunately he only had 1000lb scale, so I still need to weigh the rig at cat scales later this week. I did notice a little proposing at first along with some sway in heavy winds. I have since tightened to 4.5 links showing, and that seems to have settled down. I think I need a few more miles to be convinced that 1500 are ok. (Canada later this week)
As for the loading and unloading; I got a 20" 3/4" drive Craftsman breaker bar along with a 1" 3/4 drive socket on Amazon. It works great and feels much more solid when loading the chain bars on the rotating locks. I still use the power jack to max out prior to hitching up also.
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Blue ox sway pro Sjcjr Hitches, Couplers & Balls 31 08-02-2017 03:11 PM
Blue Ox Sway Pro W/D System Ganglin Towing, Tow Vehicles & Hitches 46 01-07-2017 09:17 PM
Equal-i-zer Sway Control Hitch vs Blue Ox Sway Pro airstreampek Hitches, Couplers & Balls 31 06-18-2014 11:56 PM
Sway bars and sway control phibbs Towing, Tow Vehicles & Hitches 1 09-03-2012 06:48 AM
