Old 11-28-2015, 11:21 PM   #15
gecko's Avatar
2009 28' International
Pacific Palisades , California
In our 2010 28' International, the reefer, shower, stove/cooktop, furnace, converter charger, water tank and half or not if our interior main cabin storage are on the service side (port side.) Then we also have our second pair of batteries under the L of the gaucho with the converter and hot water heater on the same side. Our tongue weight is also 1190, loaded for camping with 1/4 tank of fresh.
We'll be replacing our four 70 lb AGM 6 volts with a lithium bank weighing 84 lbs. unfortunately, this will remain in the port side, but it should take off almost 200 lbs of tongue weight almost 90 lbs if it from the overloaded port side.
We do the best we can to put heavier objects in the forward storage opposite the heavy side, but most likely not enough.
All tire problems we've had have been tread separation of the left forward tire. Once we lighten up a bit and since we also just upgraded to 16's and Michelin Ribs, I hope that'll take care of it.
Pretty clear that our heavier side is the service side, away from the curb.
gecko is offline   Reply With Quote
Old 11-29-2015, 07:53 AM   #16
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I think the numbers for the Classic's wheels are fairly close:
front...2034=====2042
rear....1921=====2062
This weighing is after replacing the standard six gallon water heater with a Truma 'AquaGo comfort' instant on water heater unit (which is right behind the street side rear wheel). That removed 50 pounds of water weight in that location and the new heater was 34 pounds lighter than the removed tank system.
Old 11-29-2015, 10:34 AM   #17
dznf0g's Avatar
Oswego , Illinois
switz, which is curbside and which is streetside?
-Rich-
Old 11-29-2015, 11:21 AM   #18
mandolindave's Avatar
I'm surprised
I would have thought Airstream would have bent over backwards to balance side to side, and take into consideration food and beer in the fridge, maybe even pots and pans on one side and clothes on the other.
From my experience, things are ALWAYS heavier on the side that I am lifting.
mandolindave is offline   Reply With Quote
Old 11-29-2015, 11:32 AM   #19
2011 23' Flying Cloud
Durango , Colorado
Weights for our FC23FB:
Tongue785
Right Front 1260
Left Front1332
Front Axle2592
Right Rear1187
Left Rear1109
Rear Axle2296
Total Trailer5673
% Tongue Weight14%
Equalizer Hitch Assembly91
“Hitch Weight” on Receiver876
Normal Towing Loads
Full Fresh Tank
Empty Waste Tanks
Full Propane Tanks
Digital Scales (4)
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Old 11-29-2015, 04:46 PM   #20
Vintage Kin
Fort Worth , Texas
Thanks for the numbers, guys. Don't have access to my scale tickets at present.
Where to store all the canned goods on the kitchen floor available storage is about as far as any of this goes. Keep it away from the heaviest side.
Really, it's keeping the heavy stuff (appliances, etc) within a foot or two from outside of the axle/tire contact patch boundaries -- more or less -- that matters. Don't change the stem to stern balance.
Side to side has room to play with.
But it's the scale that tells the numbers. WDH engaged. How far off the torsional twist is well applied is what makes the WDH dis-engaged readings of interest. (Where cheap factory hitch receivers of today lacking the longitudinal bracing of yesteryear disclose inherent defects). It's possible to disclose a larger than expected change port or starboard.
Old 11-30-2015, 07:11 AM   #21
switz's Avatar
2014 31' Classic
Images: 8
In the US, curb side has the entrance door on the right when looking at the trailer from the rear. The UK models I see have the entrance door on the other side.
Old 12-03-2015, 01:27 AM   #22
3wd67rg's Avatar
1988 32.5' Airstream 325
WhereIam , Left Coast Proud
How would one know for certain?
We have the water tanks on the street side.
Most of our outside storage and both closets are on the curb side.
All of our kitchen cabinets and the stove are on the street side.
The batteries are on the curb side, so is the fridge.
The tools are on the curb side outside storage. Perhaps 500lbs worth? I'm guessing, there are at least six full tool boxes I think.
Sure hope the water tanks are heavy enough!
3wd67rg is offline   Reply With Quote
Old 12-03-2015, 10:16 AM   #23
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Individual wheel weights. If you have time for that stuff. D
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 05-31-2016, 09:11 PM   #24
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Another set of actual numbers
Originally Posted by SSquared View Post
I can't find the post, but I did see someone mention that they had gotten side-to-side weights done at JC. Their trailer was a 25FB or 27FB as I recall. They got it weighed when they brought it to JC for some service, and JC also pulled up records from when it was manufactured. Both sets of numbers were heavier on the street side.
Finally got wheel-by-wheel weights on my 2013 25FB. These numbers are with weight distribution applied. Trailer was loaded, in the middle of a four month trip.
Street side: Front 1640, Rear 1360, total 3000
Curb side: Front 1600, Rear 1420, total 3020
Axle totals: Front 3240, Rear 2780.
Seems pretty even side-to-side, but the difference between the axles seems like a lot--the front is 16% heavier. Or you could say the front carries 54% of the 6020 pound total, which doesn't sound so bad.
SSquared is offline   Reply With Quote
Old 06-01-2016, 06:16 PM   #25
Vintage Kin
Fort Worth , Texas
Carries even more of the braking.
Re-Weigh with WD set. Load percentage may not change between axles (I think it will), but transfer may show different side imbalance.
Both vehicles loaded as of for a trip. Full propane and fresh water.
Old 06-03-2016, 10:09 PM   #26
SSquared's Avatar
Longmont , Colorado
The numbers in my post are with WD (I did not get numbers without WD, but it would be interesting to compare).
Old 06-04-2016, 02:27 AM   #27
Vintage Kin
Fort Worth , Texas
The front axle of the pair endures the heaviest braking load. Don't know how much effect it being "heavier" has as a toll, but worth noting differences (if any) during service. Same for bearings.
What do you typically do with the sagging vinyl walls? Jesann21 Upholstery, Blinds, Walls & Interior Finishes 12 03-19-2013 07:36 AM
How long do electric brakes typically last? Hummer Brakes & Brake Controllers 12 08-28-2012 05:50 PM
Side-to-Side Flooring Replacement in Classic MH jeffbolst Repairing/Replacing Floor &/or Frame 12 11-03-2006 01:08 PM
Weight Distribution, side to side JimC Towing, Tow Vehicles & Hitches 8 08-13-2003 03:19 PM
Which switch is which or what 74Sovereign Electrical - Systems, Generators, Batteries & Solar 6 09-10-2002 08:55 AM
