Old 06-08-2016, 03:05 PM   #1
MollyMac
2017 25' Flying Cloud
Hoover , Alabama
Which Hitch
Hey, All:
Getting Ready to purchase an Airstream 27FB Twin. will be towing with a Toyota Tundra 5.7 V8.
Dealer is telling me to do the Blue Ox Sway Pro...that is sufficient. I have done a lot of research on the Hensley Arrow. Looks like totally different systems. What is your recommendation. Should I spend the extra $$?
Any data out there? I am new to towing.
Molly
MollyMac is offline   Reply With Quote
Old 06-08-2016, 03:34 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you are going to do all of your camping on graded site and want that sense of security you might consider the HaHA. If you plan to camp off level terrain think before buying the HaHa. i have seen camper take over an hour attempting to line them up. anything out of the norm and it is not a 1 man job. If you do not have mechanical aptitude it is a challenge.
2004 Excursion 4x4
Old 06-08-2016, 03:43 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have only used two brands, the Andersen and the Blue Ox. Can with clear conscious recommend either one for your application. Data? You can find thousands of post here all recommending one brand or another. Good luck sorting out the facts from fantasy and questionable motives.
MICHAEL
Old 06-08-2016, 04:08 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Go with the Blue Ox. It works for me.
Old 06-08-2016, 04:44 PM   #5
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
I've had an equalizer, Reece dual cam, and now the blue ox sway pro. They all work good, however the blue ox is much, much more quiet and easier to adjust and keep dialed in. I'm very happy with it.
Hiho Silver is offline   Reply With Quote
Old 06-08-2016, 04:58 PM   #6
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We have used Equal-I-Zer, the inadequate troublesome Andersen contraption, and now ProPride, an updated Hensley design. The Equal-I-Zer had good weight distribution with some sway control, the Andersen was an expensive slightly effective sway control device with little weight distribution capability, the Hensley/ProPride provides complete weight distribution and eliminates any possibility of sway, and you will not be pushed around by side wind and semi bow wave, exceptional towing comfort in all conditions.
The Hensley/Propride design costs less if you buy it as your first hitch, trust me.
Doug and Cheryl
Old 06-08-2016, 05:26 PM   #7
Tincampers's Avatar
Sneedville , Tennessee
Get the Blue Ox. I have been towing for a year now full time and have NEVER experienced one bit of sway and have seen it all as far as road conditions and traffic. Save the extra money for beer or other essentials.
Tincampers is offline   Reply With Quote
Old 06-08-2016, 06:51 PM   #8
1994 34' Excella
Warren , Manitoba
Very happy with my Husky Centerline. No sway and reasonably easy to set up and hook up. Everybody here has their preference, and until you have a bad experience you should be happy with what you purchase. The most important thing with any hitch is to have it set up correctly. Just my thoughts.
WBCCI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 06-08-2016, 07:03 PM   #9
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Had a Hensley Arrow on our 2013 25FB which we kept when we traded for our 2014 31' Classic. We put a ProPride on the Classic. We installed the old Hensley on our 2015 23D.
Never had a sway issue with either hitch. Not a major connection issue with either one.
Old 06-08-2016, 07:08 PM   #10
1991 25' Excella
Stanfield , Oregon
Im very happy with my Anderson wd hitch and found it provides plently of weight transfer.
SpletKay06 is offline   Reply With Quote
Old 06-08-2016, 08:05 PM   #11
Tincampers's Avatar
If I was pulling a 28 or greater I would probably go with a PP as well. That is a lot of trailer.
Old 06-08-2016, 11:43 PM   #12
SailorSam205's Avatar
Northville , Michigan
I'll just say that Sean at ProPride seems to be EXTREMELY attentive to his customers. One question I sent via e-mail was answered in about 3 minutes. When I put in my order, there was a mistake on the submission. Sean was on the phone with me, again in about 2 minutes, to straighten out the mistake I made.
Also, I suggest you read thru the ProPride threads. I did come across a video demonstration of how the PP or HAHA hitches work. Guy uses lego's but it gets the point across. U-Tube video at: http://www.bing.com/videos/search?q=...C0B8&FORM=VIRE
SailorSam205 is offline   Reply With Quote
Old 06-09-2016, 01:46 PM   #13
K.C. , Missouri
I don't even tow one of those fancy silver trailers..... just a plain old evil white box camper. And it tows like a dream hitched with the BlueOx.
BlueOx is "clean" in that it does not have to have grease applied on the external parts like some other brands do, it is quiet in operation, and it's east to connect and disconnect.
It's also effective at weight distribution and sway control. Worth every dollar.
my badge of honor here:
"a genius nanny boy that drools in public"
....this according to a "slow-moving" poster here on the forum.... ( thanks )
gmw photos is offline   Reply With Quote
Old 06-15-2016, 09:51 PM   #14
2015 27' Flying Cloud
Washington , Washington, D.C.
I have the trailer you're ordering. Have been fulltiming since late last October and have covered 30K miles, mostly in the west. I went ahead and spent the money on a ProPride and have not regretted it. With that trailer and your tow vehicle you'll want lots of weight re-distribution. I have a GMC Sierra 1500 with the max trailer tow package which has a rated payload of 1940 lbs.
There is a learning curve with the PP, but once you get it down, it's a one-person job to hitch up, assuming you have a back-up camera. (You should have a back up camera in any event.)
I suggest a professional installation ( the folks at Colonial Airstream, from whom I bought my trailer, did mine). The amount of WD tension you can determine experimentally.
I've had semis pass me doing 80, while I'm doing 60 and there's no sway, although you can feel the whole rig being sucked towards the semi as it approaches. In considering comments from others, bear in mind that the typical 3/4 ton truck weighs between 1,000 and 1,500 lbs more than a half ton truck like yours and may feel more stable with a less elaborate anti sway hitch than the ProPride or Hensley. Also, the 3/4 ton probably has a longer wheelbase than your truck, which adds to stability. So, look for hitch recommendations from people towing your trailer with a half-ton truck.
DC Bruce is offline   Reply With Quote
Univolt internals - which fuse is which? barts Batteries, Univolts, Converters & Inverters 9 08-13-2017 09:18 AM
Heating and Air Cond. - Which wires are which? trekerboy Electrical - Systems, Generators, Batteries & Solar 12 08-09-2015 08:37 AM
Dump Valves Which is back and which is grey? clicker187 Waste Systems, Tanks & Totes 7 01-16-2013 08:15 PM
Which tank is which? dejahardy13 Fresh Water Systems 8 09-24-2010 09:23 PM
Which switch is which or what 74Sovereign Electrical - Systems, Generators, Batteries & Solar 6 09-10-2002 08:55 AM
