Old 06-17-2016, 08:22 AM   #15
aphrodite's Avatar
2014 27' FB International
Denver , Colorado
I made the dive into the ProPride hitch and have been entirely satisfied. As someone else mentioned, Sean is amazing and seemingly always available. When on a trip 2 weeks ago, something odd was going on with the hitch (turns out due to a repair guy who messed with it). I emailed Sean pictures of it and had an answer back from him within an hour. He described what to do and we were off and running again.
Joe
Colorado Mountains
International Sterling 27FB
2015 GMC Denali 2500 Duramax & Allison
aphrodite is offline   Reply With Quote
Old 06-17-2016, 10:16 AM   #16
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The Hensley/ProPride are great products hampered only by internet myths. One is you must park truck and trailer on level ground, or straight in to disconnect or connect to the hitch. That's not true.
The hitch can be easily tilted by adjusted one or the other weight distribution jacks to perfectly align the hitch box with the truck on a different plane than the trailer. The hitch can also be moved left or right to align the hitch box with the truck at a different angle to the trailer.
The weight distribution jacks are totally adjustable by simply turning the screw jack holding one or the other, or both. This also enables the weight distribution system to be simply adjusted to minor or major changes of load in the truck or Airstream.
Doug and Cheryl
Univolt internals - which fuse is which? barts Batteries, Univolts, Converters & Inverters 9 08-13-2017 09:18 AM
Heating and Air Cond. - Which wires are which? trekerboy Electrical - Systems, Generators, Batteries & Solar 12 08-09-2015 08:37 AM
Dump Valves Which is back and which is grey? clicker187 Waste Systems, Tanks & Totes 7 01-16-2013 08:15 PM
Which tank is which? dejahardy13 Fresh Water Systems 8 09-24-2010 09:23 PM
Which switch is which or what 74Sovereign Electrical - Systems, Generators, Batteries & Solar 6 09-10-2002 08:55 AM
