Old 04-10-2019, 04:40 AM   #99
2010 25' FB Flying Cloud
Tulsa , Oklahoma
Originally Posted by my3sonsdad View Post
What are the dimensions of your gravel pad & shelter.
Did you build it from a kit or have it installed?
I dug one out of my grade in a corner of my lot and have considered a similar type of shelter.
The gravel is 60 x 24. The cover is 32 x 24 x 12
rlhendren is offline   Reply With Quote
Old 04-10-2019, 07:21 PM   #100
my3sonsdad's Avatar
1975 Argosy 26
1979 30' Argosy
Vienna , VIRGINIA
Thanks!
1975 Argosy 26
1979 Argosy 30
2015 Jeep GC Summit EcoDiesel w/Hensley
my3sonsdad is offline   Reply With Quote
Old 04-12-2019, 06:52 AM   #101
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Timely thread.
Since replacing my 4x4 tow vehicle with a 2WD van, I'm having the same issue this spring.
Funny how I almost never used four wheel drive, but then when you need it...
Kicking around the idea of a winch mounted via my front receiver and mounting plate.
I like the idea of being removable.
WARN makes a hulking 12k winch, but I'm thinking that would be overkill since actual rolling pull weight would be much less (don't plan on winching the rig up rock hills). Harbor Freight sells a 9k for about 1/4 the cost.
Hook it up with some 1/0 AWG cables and a plugin connector like this and it's ready to go.
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 04-13-2019, 04:07 AM   #102
Tulsa , Oklahoma
I thought about a portable winch as well. Have you considered come-alongs? A cheaper option if you don't plan on using a winch very often. Not the particular set in the attached picture, but maybe something a little more heavy duty.
Queen Mattress from 25FC FB Bilbo Airstream Classifieds 0 11-08-2017 12:25 PM
2017 25FC FB water pump circuit The Colonel Water Heaters, Filters & Pumps 11 02-24-2017 07:47 AM
Husky Brute fit for 2017 25FC FB The Colonel Jacks, Stabilizers, Lifting and Leveling 1 09-04-2016 02:17 PM
Started Day w/ 25FC, ended with 27EB jayseejay Eddie Bauer - All Models 19 05-26-2015 11:46 AM
Additions to new 25FC NWGreyhound Stoves, Ovens & Microwaves 4 06-07-2010 05:36 PM
