Old 01-24-2019, 06:43 AM   #29
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Good article on 'Mud Recovery'. Off-road drivers often let down the air pressure in the tires for better traction.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is online now   Reply With Quote
Old 01-25-2019, 09:52 PM   #30
1988 32' Excella
Robbinsville , New Jersey
Originally Posted by Foiled Again View Post
Second the ideas for Frozen ground overnight, plywood rather than 2 x 8 and don't forget to use 4 WD LOW setting presuming that your truck has 4 WD. (always surprises me to find people who have never used theirs or don't even know where the control is located.)
I know what you mean. Years ago in the parking area for a drag race a guy in a Ford Explorer got stuck and his driving looked way to dangerous to trust getting close enough to help. When he asked for more help my brother asked why he didn't have it in 4 WD and he claimed it didn't have 4 WD. After he got out we could clearly see the front and rear differentials when he crested a hill.
Old 01-26-2019, 05:26 AM   #31
2010 25' FB Flying Cloud
Tulsa , Oklahoma
OK, so frozen ground idea didn't work. It was 17 degrees yesterday morning and the ground was solid as I walked on it. I decided to unhook the trailer and see if I could just drive the truck forward a few feet and then do a 15-point turn to get it out (it's sort of trapped between the AS and a fence in front, with about 5 feet of room between the front bumper and the fence). But the truck wouldn't budge.
I've decided to take everybody's advice and not pull on the trailer from the rear.
So my next attempt will be either the 2x4's strapped to the tires, waiting for the ground to dry out some more AND for freezing temps OR to jack it up and put wood under all 4 drive tires, again on a day with freezing temps.
After I get the truck out, I'll reposition and hook up the trailer and try to get it out.
This has been frustrating to say the least. I knew my back yard was soft, but I've only lived here for 1 year. I had no idea that there would be months-long stretches of wet ground.
rlhendren is offline   Reply With Quote
Old 01-26-2019, 06:33 AM   #32
Long Island , New York
Thanks for the update.
Originally Posted by rlhendren View Post
So my next attempt will be either the 2x4's strapped to the tires . . .
Maybe experienced off-roaders get away with that solution, but unless it is done absolutely perfectly, it might create more new problems IMO. [See Post #12]
What about the long hawser under the trailer suggestion in Post #10? Pretty simple if you can rig it up. Worth a try, especially if the second tow vehicle on the paved pad is 4WD and gets good traction IMO.
Good luck,
Peter
OTRA15 is online now   Reply With Quote
Old 01-27-2019, 06:55 AM   #33
Tulsa , Oklahoma
Good luck,
Peter
The 2x4's strapped to the wheels worked like a charm. You do need to be really careful and pay attention to what obstructions there are as the wheel turns, but it's pretty simple to keep everything out of the way so that it doesn't do damage. But it did work really well. It took about 5 minutes to get the boards strapped up to just the rear wheels. Then with the truck in 4-low, I just drove right out of the holes. The truck is now sitting on top of the ground. The trailer is unhooked but behind the truck still. The front of the truck is about 4 feet from the fence. And the rest of the yard is still too soft and wet to get either the truck or the trailer all the way out. But for now, the truck is unstuck.
Thanks everyone for your help.
Old 01-27-2019, 12:00 PM   #34
Thanks for the update -- good to know that trick.
I guess your tow vehicle wheels have voids in the casting, so that you can run the ratchet cinch through the voids? What if your wheels were old-fashioned solid steel wheels?
Peter
Old 01-28-2019, 01:20 PM   #35
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Egyptian Pharaoh Method
Mothership tour showed me that Airstreams are moved down the production line by two or three people. Of course they arent loaded with 1000 lbs of your stuff and the floor is level concrete.
A review of "The Ten Commandments" shows the big stones being pushed as well as pulled... so get much beer and a roasted pig, 8 to 10 hefty men (skip the loincloths in February, brr), and 4 to 6 sheets of plywood, 3 2x4 studs and one 2x6 by 10 ft. Tie the 2x6 to the tongue after removing the.propane tanks, wedge the 2x4s behind the wheels, digging down if needed to create an upslope for the tires to get on the plywood. Put plywood behind the trailer tires and at the front of the trailer so the crew can get traction. Have someone lead the oh-eeh-oh.chant and start pushing using the 2x6. Stop to move the plywood as needed until you get the trailer on gravel. Celebrate by eating roast pig, drinking beer and making rude digestive noises.
Once the trailer is safely out of the way, move the truck.
Old 01-28-2019, 03:47 PM   #36
That seems like a complicated solution, Foiled. [IMO]
Not sure why the single large hawser suggestion [Post #10] hasn't sparked any interest, except for James Mileur's Post #22 quoted below.
The "second truck" described in the original post would have tons of pulling power in 4WD, and could pull the AS and TV out easily! [with some minimal power from the first TV, and other details in Post #10]
. . . I'm certain that another truck pulling the AS backward would be sufficient to get us out. The second truck would be on the gravel parking pad, so sinking isn't an issue there.
Originally Posted by james.mileur View Post
A good hawser and bowlin knot has never failed this old Sailor.
"Given a long enough stick, and a place to rest it, we can move the world!"
Old 01-28-2019, 04:57 PM   #37
2007 22' International CCD
-----------------snip-----------------
Also better known as a fulcrum, or in my case, a "Full Krum" makes it possible to get faster movement after a nice meal...
rmkrum is online now   Reply With Quote
Old 01-28-2019, 07:07 PM   #38
Grew up in Amish country. Barn raisings are beautiful things. More for the fellowship even than for the barn. Aging has trained me to see that having help keeps me from injuring myself and making the initial problem worse than it was in the first place... and truthfully I just have a keen sense of the ridiculous. I'd love to see a YouTube video of the great mud rescue.
Or how about tying a big come along to the tongue, seciring the other end to a phone pole 200 ft. Away in the front yard and going for it one ratchet at a time. Which will give, the chain, the trailer or the phone pole? Larry, Curly and Moe please report for duty.
Old 01-30-2019, 11:47 AM   #39
Bbelk's Avatar
2010 27' FB Classic
I agree with OTRA15's first post. Use a long, stout rope and tie to the hitch on the stuck tow vehicle. I would run it under the axles to help it clear the plumbing underneath the trailer. The upwards force on the axles will be a much lower force than if you tried pulling on them directly. If there is any side to side issues with the tow, use a short rope with a loop tied in the middle of it and tie it to the axle plates shown in OTRA15's second post. Run the tow rope through the loop, but not attached to the loop. The short rope should only have side to side tension and little or no front to back.
I had to rescue a boat on a trailer this way once.
2010 27FB Classic
1989 190 Class B (Sold)
1977 29 Ambassador Land Yacht (Sold)
Bbelk is offline   Reply With Quote
Old 01-30-2019, 02:47 PM   #40
Thanks Bbelk, I was wondering if anyone other than James Mileur saw the elegant simplicity of the hawser solution!
Peter
Old 01-30-2019, 03:12 PM   #41
2018 30' Classic
Jacksonville , Florida
I use plywood. A 24" wide piece usually works. Overlap other pieces. Drive real slow.
Overstreet is offline   Reply With Quote
Old 01-30-2019, 03:52 PM   #42
vintageracer's Avatar
1977 Argosy Minuet 6.0 Metre
Nashville , Tennessee
MAXTRAX!
Expensive as Hell however they work GREAT for vehicle recovery from most any "STUCK" situation.
The industry standard for vehicle recovery in the Overlanding community in which I participate!
https://us.maxtrax.com.au/
Mike
Remember "Drive Fast, Turn Heads, Break Hearts"
vintageracer is offline   Reply With Quote
Queen Mattress from 25FC FB Bilbo Airstream Classifieds 0 11-08-2017 12:25 PM
2017 25FC FB water pump circuit The Colonel Water Heaters, Filters & Pumps 11 02-24-2017 07:47 AM
Husky Brute fit for 2017 25FC FB The Colonel Jacks, Stabilizers, Lifting and Leveling 1 09-04-2016 02:17 PM
Started Day w/ 25FC, ended with 27EB jayseejay Eddie Bauer - All Models 19 05-26-2015 11:46 AM
Additions to new 25FC NWGreyhound Stoves, Ovens & Microwaves 4 06-07-2010 05:36 PM
