Old 01-23-2019, 04:44 AM   #15
2010 25' FB Flying Cloud
Tulsa , Oklahoma
Excellent ideas. Thank you to everyone for the suggestions. I'll update in a few weeks to let you know how it went.
rlhendren is offline   Reply With Quote
Old 01-23-2019, 06:13 AM   #16
1999 30' Excella 1000
small town , Maryland
It should be 17* tomorrow morning for you. A good time to try again. At my uncles house I ran a load of tree branches into the woods, unloaded the pickup and was stuck in the clay on a slight incline. He had a sandbox for the grand kids to play in, so I placed sand in front of the drive wheels plus 10' and drove the 2 wheel drive out of the woods. Sprinkle a sack of sand along the rout and go slow. In the mud it can get ugly quick. If this doesn't work ULTRA15's idea with the 100' rope to the hitch area would be next. Good luck my friend
streaminwild is offline   Reply With Quote
Old 01-23-2019, 07:46 AM   #17
2018 28' International
Fayetteville , Georgia
I would not attempt to pull the trailer out with straps. Put plywood sheets under the TV wheels and trailer wheels.
brick
2018 International Serenity
Cute wife...
brick1 is online now   Reply With Quote
Old 01-23-2019, 07:50 AM   #18
Mollysdad's Avatar
Originally Posted by gypsydad View Post
...they usually have a wench...
I've been doing it wrong!
Old 01-23-2019, 10:02 AM   #19
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Originally Posted by OTRA15 View Post
Like these: https://www.amazon.com/Smittybilt-CC.../dp/B001CF4UXU
. . . and attach them per Rich -- but only in these two exact locations:
This would be an excellent alternative to the single "hawser" solution in Post #10, but the hard part is going to be attaching the straps to the axle mounting plates. Maybe the hooks on the ends of the straps can find an edge of the steel plates to hook to, or holes at the yellow arrows in the attached photo?
Good luck,
Peter
PS -- Possible attachment points for straps at axle mounting plates at the yellow arrows IMO:
...no way...you may end up with a frame not parallel..trapezoidal...not strong enough to pull pickup..this has up and down strength...hook to pickup hitch..
Old 01-23-2019, 10:40 AM   #20
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Google "anti slip for tires"
You'll get something like this and plenty to choose from
https://www.google.com/search?q=anti...w=1261&bih=679
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 01-23-2019, 10:44 AM   #21
Long Island , New York
If the pull is done carefully, with the main tow vehicle getting good traction going backwards, this would be safe, assuming equal tension on the two new recovery straps rigged to the axle mounting plates IMO. Requires good judgment and skill from both drivers and all riggers.
Preferred method is still Post #10 with one single hawser rigged to the primary tow vehicle's hitch IMO.
Bowing out of further discussion . . . in view of the OP's recent post:
OTRA15 is online now   Reply With Quote
Old 01-23-2019, 11:10 AM   #22
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
A good hawser and bowlin knot has never failed this old Sailor. Start with a spinach salad.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 01-23-2019, 11:13 AM   #23
2016 28' Pendleton
Marshall , Virginia
Don't over think
Buy a set of snow chains. You may have to jack uo the rear of truck to get chains on.
Bill2535 is offline   Reply With Quote
Old 01-23-2019, 11:33 AM   #24
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
I read my post twice more after seeing this post and still did not understand...it was supposed to be a "winch" not a "wench"...you were probably doing it right the first time! But, if the tow guy has the right "wench", that might do it too!
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 01-23-2019, 11:36 AM   #25
2007 22' International CCD
Assuming a large enough, strong enough 'wench' with a long reach.....
Old 01-23-2019, 11:57 AM   #26
2015 30' International
FREDERICK , Maryland
Invest in some recovery tracks
I personally would be very hesitant to winch or tow even from the frame from the rear - the cable or tow strap would most likely put a lot of stress on the rear bumper if pulling straight back.
I would invest in some recovery tracks, something like these:
https://www.mainlineoverland.com/products/maxtrax-mkii
https://www.quadratec.com/products/9...saAoN1EALw_wcB
I keep these in the back of my truck as I usually do some fourwheeling in pretty remote areas and setting up the Airstream as a basecamp. They are pricey, but would help you now in getting traction for your truck to pull out your trailer (when the ground is frozen), then they could potentially be of assistance in the future if your get stuck again. Good luck
Doc Foster is offline   Reply With Quote
Old 01-23-2019, 02:03 PM   #27
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
http://www.okieweb.com/tulsa4wheelers/home.htm
You might contact these folks. They seem friendly and at least in the past, their hard core members spent a lot of time getting stuck in the mud and pulling each other out. They used to spend the winter snow storms helping people recover from captive ditches. Might just have a rigger in the group or they may have lost the touch. Worth talking to them and you might make a new friend.
Go slow - rigging requires force management - keep it safe. Pat
Old 01-24-2019, 05:59 AM   #28
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Second the ideas for Frozen ground overnight, plywood rather than 2 x 8 and don't forget to use 4 WD LOW setting presuming that your truck has 4 WD. (always surprises me to find people who have never used theirs or don't even know where the control is located.)
Queen Mattress from 25FC FB Bilbo Airstream Classifieds 0 11-08-2017 12:25 PM
2017 25FC FB water pump circuit The Colonel Water Heaters, Filters & Pumps 11 02-24-2017 07:47 AM
Husky Brute fit for 2017 25FC FB The Colonel Jacks, Stabilizers, Lifting and Leveling 1 09-04-2016 02:17 PM
Started Day w/ 25FC, ended with 27EB jayseejay Eddie Bauer - All Models 19 05-26-2015 11:46 AM
Additions to new 25FC NWGreyhound Stoves, Ovens & Microwaves 4 06-07-2010 05:36 PM
