Old 06-19-2016, 05:51 AM   #1
2016 23' Flying Cloud
spring lake , New Jersey
what's that noise?
So I'm ready to hit the road. I hitched up my AS (23' flying cloud), and pulled away and down he road. there is a clunking noise (from what I guess is the anti-sway bars) when I turn cormers. I wasn't concerned with that. Later in the day it seemed to get worse. Then I heard a loud noise like the iron bars were twisting or something, followed by a hissing noise and a whining noise as I turned corners and it continued a little ways down the road. I was only going a mile or two an hour when this happened and it stopped when i straighten out the trailer. What the heck is going on? Help!! Thanks, Nicole:
nicole.b is offline   Reply With Quote
Old 06-19-2016, 05:54 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Depending on what brand and type of WD you are using, the snap up brackets could have worked loose, and are sliding back and forth on the A frame when you turn.
Old 06-19-2016, 07:05 AM   #3
SailorSam205's Avatar
Northville , Michigan
Take a look at post 10 in "White knuckle newbie question" by that was just posted, may be what you are talking about.
SailorSam205 is offline   Reply With Quote
Motor noise vs fan noise vs overdrive question SebasSF Mechanics Corner - Engines, Transmission & More... 25 12-15-2013 11:18 AM
"Whirring" Noise in the Driveline at Speed swebster Airstream Motorhome Forums 20 08-15-2003 05:57 AM
Noise dry camping ChrisAich 2002 - 2005 International 24 07-28-2003 06:58 AM
Univolt Low Buzzing Noise rjones1138 Electrical - Systems, Generators, Batteries & Solar 23 07-16-2003 06:23 AM
Strange noise?? Univolt?? Brakes?? rroessler General Repair Forum 2 06-22-2002 04:41 PM
