02-22-2012, 11:20 AM
#81
2008 19' Safari SE
Denver
Originally Posted by Aspirations
I am glad the above members & combos have traveled safely, but I'm loathe to think what would happen if those set-ups were the majority & traversing the country highways, diverse terrains & hazards!
We'd all be driving slower?
Seriously, I drive this combo because it's safe. I can't travel as fast nor go up hills as fast, and forget trying to moose out of sandbanks or snowdrifts, i don't have the clearance and it's a front wheel drive, but I am safer in my Jetta than in the majority of pickup/trailer rigs out there. That's according to my VW mechs, not just Andy Thomson.
"If you can't be a good example, then you'll just have to be a horrible warning." - Catherine Aird
Blog: 300 Miles or 3:00
02-22-2012, 11:43 AM
#82
2009 19' Flying Cloud
Orlando
I swear, Airstreams should come with a big warning sticker explaining that choosing a tow vehicle is a bloody nightmare. Hubby and I are in the same position as the OP, having recently bought a new (and bigger) AS and now trying to decide on a new (and bigger) TV. Reading threads like this is helpful to a point, but with so many strongly held and strongly diverging opinions, they also cause insomnia!
That said, I'm sure the pain of decision-making will eventually be forgotten, and we'll love the new setup once we figure it out. (Right?!) At one point hubby suggested we just bail on Airstreams and get a Class A RV and tow a small car. To which I replied that in that case he'd have to trade in not only his truck but his wife....
02-22-2012, 12:16 PM
#83
Common Sense
Really wanted to stay out of this no-win situation, but I must say I find it extreemly interesting that when someone proposes towing a late model 25' or slightly bigger with a 1/2 ton pickup, here comes the screams of warnings about going over the GVW of the truck.
However, let a person from North of the border come up with a 34' towed with a Ford Flex, or a 31' towed with a FWD minivan, no one even mentions the GVW rating of those vehicles.
Is it just because they are setup in Canada that all rules of weight go overlooked?
02-22-2012, 12:23 PM
#84
2008 19' Safari SE
Denver
I think perhaps you're overlooking that the two kinds of comments come from two different groups of people. For those of us who got our setups at CanAm or following Andy Thomson's formulas of figuring it out, weight is only one of six different areas of concern.
02-22-2012, 12:25 PM
#85
Weldon Spring
, Missouri
Good for you, jen! (post #82)
02-22-2012, 12:28 PM
#86
Master of Universe
2008 25' Safari FB SE
Grand Junction
Marina,
I haven't read this thread, but there are many like it, and I know that the previous posts say:
1. You can tow a 25 or 28' with a 1/2 ton truck.
2. You can tow a 25', but not a 28', with a 1/2 ton truck.
3. You can (or can't) tow either or both with a 1/2 ton SUV.
4. You need a diesel.
5. You need a 3/4 or 1 ton truck.
6. You need big honking brakes.
7. You need (don't need) a ProPride or Hensley hitch to go with that truck.
8. You can go to CanAm in Canada and tow with a car.
9. You need a Ford or a Chevy or a Dodge or a Tundra or a Nissan or a Ridgeline or a Freightliner, ad infinitum.
10 Gas engines are so big now you can tow anything with them.
11. Buy the trailer first because that'll last a lot longer and then see what truck fits it.
The answer is: my truck and trailer are the best combination for anyone, but should you not be willing to accept that wisdom, ignore the posts that say or imply that is where the person is coming from and look at the facts.
Good luck.
Gene
02-22-2012, 12:40 PM
#87
2011 28' International
Chatham
, Ontario
I have no problem with people towing Airstreams with trucks; tens of thousands of people do it and it clearly works for them. Where I do get a bit bent out of shape is with the widely held misconception that not using a truck is somehow unsafe.
If you take, for example, Zlee's Jetta. It's a pretty nice car, strong, low slung and unhitched will outperform any truck in acceleration, braking and through a slalom without difficulty. Indeed, if you were trying to roll a vehicle, which would be easier, truck or Jetta? Trucks are actually dinosaurs in design and build when compared to a Jetta. So why does hanging a trailer on the back make the Jetta unsafe and a truck safe? Sure, you can't just have the factory fit a hitch and hang the trailer on it; you have to make sure the hitch is strong enough, and mounted correctly in order for the weight distribution system to transfer an appropriate amount of weight forward. You also need a good brake controller to make sure the trailer brakes are working with the car and you need to ensure the transmission is sufficiently cooled for the load. But do that, hitch up your trailer, and you still have a car that has excellent handling and braking characteristics, still better than the truck that you've now hitched your trailer to without the modifications. The only things different will be the speed at which it can accelerate and the overall stopping distance, but the truck will have to deal with those things, too, of course. No, the safety argument is specious.
Of course trucks have their advantages. They can carry more load and, with some of the huge HP and torque they can produce, they can, and often do, tow Airstreams at great speed and with great ease. But then we're back to safety; how is it safer to tow an Airstream at 75-85mph (exceeding the speed limit AND most trailer tire ratings) with your powerful truck than it is to tow at 60mph with your Jetta?
As I said, trucks work for a lot of Airstreamers and that's fine. There are alternatives, though, that are usually safer and always more economical. I just think that when deciding on a tow vehicle, people need to look beyond the automatic assumption that a truck is the only solution.
02-22-2012, 01:01 PM
#88
Oswego
For me, it's not about brand or vehicle configuration, or whether CanAm does a good job at what they do...it is strictly about specs and ratings.
Professionally, I know, without doubt, that exceeding manufacturers ratings (significantly) will, at a minimum reduce the longevity of MANY components of the vehicle.
Secondarily, you must be willing to accept the possibility of the words in the following article. (there are others out there, google "liability in towing overloaded" or your favorite phrase.)
TRAILER TOWING ILLEGALLY
-Rich-
02-22-2012, 01:08 PM
#89
2008 19' Safari SE
Denver
That depends on whether the manufacturer's ratings were made correctly in the first place. Many seem to have been made because that's what someone else did (and that comes from the horse's mouths in many cases).
As for liability, in that case we're all liable for a great many things. As soon as you add a non OEM tire, for instance. And that comes from several different insurance professionals I've spoken to. Legality is an interesting subject, isn't it?
02-22-2012, 01:13 PM
#90
Connellsville
, Pennsylvania
As an interesting side note, I am wondering if anyone that is using one of the more non-traditional tow vehicles mentioned here, has been through a DOT safety inspection either at a checkpoint or roadside stop. Being an RV, it is unlikely since they are usually intersted in commercial hauling, but I have seen it a few times over the years.
02-22-2012, 01:19 PM
#91
Oswego
Zlee, I am afraid those are consoling words commonly shared among those who wish to believe that it's is OK to exceed manufacturers ratings. I do have first hand knowledge of the durability testing which at least one manufacturer performs. They are not numbers just pulled out of the air. The discrepancies that you may refer to come from the fact that there is not one industry wide (yet, it's coming) set of parameters under which ALL manufacturers perform their testing. That is, however "performance" testing....not durability testing....two very different animals. The proposed common "performance ratings" will keep some manufacturers from OVERSTATING their tow ratings, not understating them.
-Rich-
02-22-2012, 01:22 PM
#92
2008 19' Safari SE
Denver
That'd be interesting to find out--I suppose if states continue to need to make more money, they might decide more trailers beside commercial would be liable for a DOT inspection. Since this might mean that many people who tow RVs would probably not be able to pass a DOT physical and the paperwork would be immense, I tend to doubt it would happen, though.
02-22-2012, 01:23 PM
#93
2008 19' Safari SE
Denver
Actually, from what several auto and truck engineers have told me, they are. So who's right?
02-22-2012, 01:31 PM
#94
Oswego
I guess you would have to spend some time at the proving grounds. I work daily with commercial accounts who load, modify, and tow things that we RVers can't even imagine. Because of this, I do have to interface with engineering often to try and keep and sell my product over brand X.
I'm not here to try and convince you, just tell the truth.
The ratings, obviously have to default to the least common denominator whether they be brakes, frame, engine, transmission.....etc. Thus there is some compromise in all overall vehicle ratings...but that's a far cry from just making up numbers. In addition does it really make sense in a competitive market to publish numbers inferior to you competitor???
"My truck is better than your truck because it has less HP"
"My truck is better than your truck because it has less towing capacity"
It's a counter-intuitive position.
-Rich-
02-22-2012, 01:35 PM
#95
2008 19' Safari SE
Denver
I think where you're going wrong is thinking that I'm saying my tow vehicle is better than a truck, or even as good as a truck. I'm just saying it's sufficient to be safe.
02-22-2012, 01:36 PM
#96
Connellsville
, Pennsylvania
That'd be interesting to find out--I suppose if states continue to need to make more money, they might decide more trailers beside commercial would be liable for a DOT inspection. Since this would mean that many people who tow RVs would probably not be able to pass a DOT physical and the paperwork would be immense, I tend to doubt it would happen, though.
The reason I ask is, I have witnessed what appeared to be a full on DOT inspection on RV trailers twice in the last year or so. The first one was here in PA at the Donegal interchange on PA turnpike. DOT officer had a gentleman with a Rapter toy hauler towed by an F-250 pulled over and was giving it an inspection. The rig didn't look to a commercial so I sort of caught me by surprise. The one thing that I do know that PA has been cracking down on is combination plate registration, and that may very well have been the case.
The other was at the first weigh station as you enter Florida on I-95 south. There, a DOT officer had a family with a Subaru Outback pulling a ~22' travel trailer pulled off and was giving them the full deal. No guess as to why they were picked, but again it caught my attention.
02-22-2012, 01:39 PM
#97
2008 19' Safari SE
Denver
The toy hauler is interesting; perhaps the DOT thought maybe he was a competitor? (Because those are considered commercial, from what I understand, right?)
I wonder now...if you run a business out of your trailer (as full-timers often do), does that make you commercial and therefore liable to needing a DOT license?
02-22-2012, 01:46 PM
#98
Oswego
No, I do know what you're saying...I'm just saying that loading or towing over the manufacturers ratings are, at best, going to reduce the longevity of TV componentry....and at worst could open up some other potential non-product issues.
I am not proposing that a truck is better than a car either. I believe, rather vehemently, from (again) professional training and experience that matching loads and trailers to the properly rated vehicle is the correct thing to do from an economic, durability, and safety standpoint. I don't believe in over-spec'ing either. (although the risks are less)
-Rich-
02-22-2012, 01:59 PM
#99
2008 19' Safari SE
Denver
But I think that "properly rated vehicle" is a rather fluffy term, in actuality. To go through the entire process of rating a specific vehicle on six different areas of concern is far better than just saying "you can tow this much weight." The manufacturers don't do this, and to be fair, they can't afford to do so, there's too many possible factors to weigh. I think each combination should be weighed on its own merits and factors involved. Even wear was covered in my particular scenario; I can't speak to anyone else's.
Not the least because towing an Airstream is not the same as towing an Elements trailer or any other kind of trailer. It's a game-changer in a whole lot of ways. I was definitely warned to stay under a certain length and to look at only two makes of RVs, due to stability and safety issues.
Would I like to have a more powerful (and taller!) vehicle capable of hauling me out of sandpits and over snowbanks? Sure! However, ten more years of saving up for a new TV (20 more like, given what I'd want to buy) and however much the AS I wanted would be in ten more years? Nah. I'll go for safe now with all factors weighed into my decision, including the 42 mpg I get when not towing. I'd rather have thirty more years of twilight traveling than ten because I couldn't afford both an AS trailer and a vehicle.
Unless, of course, if any of you fine people would like to donate about $50k to the cause. That Touareg TDI I saw in the lot last week would be a lot of fun...
02-22-2012, 02:05 PM
#100
Connellsville
, Pennsylvania
By the book, I think that if a person is receiving compensation for an activity based out of that toy hauler (competitive MX racer for example), then the trailer would be considered commercial. Not 100% sure though. If that would be the case, then the driver would need a medical card and commercial insurance at a minimum and a CDL if the GCWR is over 26,000#.
I'm not sure about running a business out of a trailer.
