Closed Thread
Old 04-14-2012, 08:23 AM   #225
phbarnhart's Avatar
2012 25' FB Eddie Bauer
Eugene , Oregon
Images: 14
Originally Posted by REDNAX
Then why isn't U-HAUL out of business?
My guess is that they have great insurance and that they require that the person actually driving the vehicle assumes responsibility in the case of any accident.
phbarnhart is offline
Old 04-16-2012, 07:01 AM   #226
SARGE/AF's Avatar
1996 34' Limited
1976 31' Sovereign
1983 31' Excella
Greeneville , Tennessee
They are not out of business because they will not let you use one of their vehicles for towing more than is intended. This is why they ask; what do you or are you going to haul? they are not suppose to rent anything towable to you if you are hauling something that is over the recomended weight of the tow vehicle. Also if you look in the fine print it also says that you have been told of the towing/cargo weights and if you exceed that you are responsible. This includes all of the rental vehilcle companies.
Might want to read your contract.
Sarge
Sarge USAF
WBCCI- none
Good Sam Life Mem
NRA, DAV, PGR, DRA
SARGE/AF is offline
Old 04-16-2012, 07:04 AM   #227
SARGE/AF's Avatar
1996 34' Limited
1976 31' Sovereign
1983 31' Excella
You know this thread has been gone over again and again and it comes down to its up to the owner of how much risk he/she wishes to place thier family and others in when towing with a underated vehicle, and that is all there is too it.
What I would like to know is what the insurance companies say about someone who is towing with an underated vehicle? or do you not tell the insurance companies?
Sarge
Sarge USAF
WBCCI- none
Good Sam Life Mem
NRA, DAV, PGR, DRA
SARGE/AF is offline
Old 04-16-2012, 09:29 AM   #228
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
It very much depends on how you define "under rated tow vehicle".
If you mean that the tire, axle and gross vehicle weight ratings are exceeded then yes, an under rated tow vehicle will not be safe.
If you mean that the weight of the towed vehicle exceeds that which is recommended by the manufacturer then that tow vehicle may not be under rated at all; it will depend on how the manufacturer has arrived at his recommendation.
If the manufacturer can show you, definitively, that his recommendation was built on the vehicle's actual specification and show you that to exceed it will break something, then fine. But most tow ratings, as we've said many times before, are decided by the marketing department, what the customer wants and what the competition is doing. I've already put the Truck Trend article up, the one that quotes named industry sources, that confirms this is indeed the case.
So, if the tow rating doesn't actually refer to the capabilities of the vehicle, how can one claim that there is some undefined risk of towing in excess of the manufacturer's recommendation? The risk is as undefined as the tow rating itself.
If we're talking about risk, though, how do we, and our insurance companies, treat folk who tell us that they regularly tow at speeds way in excess of the trailer's tire speed rating? That they regularly tow in excess of the posted speed limit? That they don't bother with extended mirrors? How about not employing any sway control? Or weight distribution? I'd suggest that these things are far more risky, and more quantifiable, than exceeding the manufacturer's poorly established tow rating, and yet they seem to be exempt from censure.
This debate can, and will, go on; debate is good and it behooves us all to see what others are saying and experiencing. Personally I don't mind what trailer people tow behind what vehicle. I will assume that they have done their homework and made sure that tire, axle and gross vehicle weight ratings have not been exceeded. I'd love to think that they'll also be keeping within some of the other, better defined, towing parameters like speed limits, but then that's the risk that some people take, I guess.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline
Old 04-16-2012, 03:19 PM   #229
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Sarge
Sarge, you have an opinion, but can't define the words used to express it. Based on ignorance (the kinder choice in interpretation), and from which you might well choose to educate yourself from any of a variety of angles.
I've spent I don't know how many thousands of miles driving a one-ton pickup with a trailer behind that, combined, was at least 10,000-lbs past "rated GCWR". From truck weigh stations to LEO's doing Level 1, 2 or 3 roadside inspections there isn't a problem. If the tires are up to the load and if the axle rating has been respected the law doesn't address it.
The insurance companies are happy to write $1-million dollar liability policies against it, and the oil & gas companies continue their patronage of the service. As one of thousands of others doing the very same thing, day in and out. In conditions in which you would never leave the house. From the Arctic to the tropics.
You flat don't know what you're talking about.
Do you honestly think GM or Dodge denies warranty work on those same pickups used in the same manner to every farmer, rancher, trucker, contractor and small businessman in the country? They do not. They actively seek these users of light duty pickups as they are the largest group of buyers of the heavier light-duty trucks.
And since you aren't old enough to remember what was done in the 1960s and 1970's to properly set up and tow a travel trailer with family cars -- with less power, worse brakes, etc -- you might sit up and pay attention to the details of how it is done. The information is out there, learn to use it. You might could wind up with a decent rig.
slowmover is offline
Old 04-16-2012, 03:53 PM   #230
Gainesville , Florida
They do not tell the ins co. in my opinion or it would be questioned. My opionion. jim
xrvr is offline
Old 04-16-2012, 04:49 PM   #231
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
"They" do not tell? The insurance companies are well aware of the risk level, the loss & prevention specialists from those companies cut their teeth on this kind of operation (oilfield hotshot). There is nothing secret about it. The level of documentation is broad and deep. The company I ran under has over 2,000 trucks with over 6000 loads run weekly.
Not all are these little boy trucks, plenty of big and some plain weird. Off onto roads that aren't roads, where bulldozers chain up to your rig and drag you the last 100-feet. Mud deep enough you crawl in and out the window until unloaded and the dozer drags you back to the road. Really ugly, in other words.
And the trucks keep on doing it for about 5-years or 300k miles. (Well, the Fords don't and no one buys GM's. But that may change.).
Old 04-16-2012, 05:09 PM   #232
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Rednax
So is what you are saying is that from a liability standpoint, we must not exceed the tire ratings and the axle ratings? What about the GVWR for the TV?
I am really bothered that folks tend to only look at the max towable rating for the TV. My Tundra has a max trailer rating of about 10,500 lbs. The only way you can tow this kind of a trailer load is if you are a 98 lb weakling, traveling by yourself with nothing in the truck bed. When I load up my truck with all my gear and hitch up my 4,500 lb Tradewind I am only about 300 lbs below the rear axle rating.
Thanks for all your knowledge and practical commercial towing experiance.
Dan
TouringDan is offline
Old 04-16-2012, 05:26 PM   #233
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
Wink
Not all are these little boy trucks, plenty of big and some plain weird. Off onto roads that aren't roads, where bulldozers chain up to your rig and drag you the last 100-feet. Mud deep enough you crawl in and out the window.
Now your talking my kind of world my TV runs in every day.. Great come back Rednax.. Heck when I drop the AS onto the ball hitch,, its a vacation FOR MY PU to just pull it around on pavement!
Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline
Old 04-16-2012, 06:54 PM   #234
Exceeding a one ton trucks capabilities is a lot less dangerous than exceeding the abilities of a passenger car. jim
xrvr is offline
Old 04-16-2012, 07:36 PM   #235
ewaegeman's Avatar
1970 31' Sovereign
1978 31' Sovereign
1978 31' Sovereign
pinkenba , QLD
Hi,
Just here in Australia, we can't get the big Americantrucks, we can ... but they costs a few hundreds of thousands of $. So I am looking at Landrover Defender 90, what does the forum think about that? The capacity is OK, the allowed tow capacity is OK, upgraded suspension, brilliant diesel engine .... and affordable. Our roads here in Australia are not so good as US, smaller, ruff, and the caravan parks are VERY tiny .... so that's why I thought a small defender 90 (if affordable) and easier to get the trailer parked (most people put a tow bar at the front for easy parking) .... maybe I'm wrong ....
Cheers.
Erik
ewaegeman is offline
Old 04-17-2012, 06:27 AM   #236
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
Originally Posted by ewaegeman View Post
Hi,
Cheers.
Erik
Too empirical.....
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
ROBERT CROSS is offline
Old 04-17-2012, 09:14 AM   #237
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
There are treatises on liability, negligence, contracts, warranty and all the legal questions regarding who is at fault. To determine the answer to these questions takes a lot of explanation and comparison to the facts of each situation. If you have a reasonably valid claim, then you have to deal with arbitration clauses and limits on liability in contracts as well. To make statements about these questions in a general way is pointless unless they are only (uninformed?) generalities and understood as such. A person or company is generally responsible for their actions, but proving it is another issue.
A discussion of what is safe and what tow vehicle can do what can be useful. Most posts are anecdotal and should be taken as such. In the end, you have to assess whether the person posting knows what they are talking about and then make your own decision. Facts are elusive.
For example, I think our Tundra has handled towing without problems. But I haven't taken the engine, transmission and other components apart to see what wear is on them—and if I did, I wouldn't know what I was looking at (I might not be able to put it together again either).
Gene
Gene is offline
Old 04-17-2012, 09:27 AM   #238
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
So why do we waste so very, very much time on legal crap when the op specifically asks what to tow with, not how much trouble with the law will I be in if I tow with a . . . ?
(And I don't really want anybody to answer this, it's just a statement.)
doug k
dkottum is offline
Closed Thread
Truck & Trailer Weights nickmeloy Towing, Tow Vehicles & Hitches 6 04-02-2014 10:02 AM
What do you carry in your truck and how do you organize them? Airperson Boondocking 45 11-07-2011 11:42 PM
Snap Size '65 Tradewind? P&A Upholstery, Blinds, Walls & Interior Finishes 2 07-16-2011 03:27 PM
Tires and tire size KyMoonshine Tires 5 03-08-2011 04:28 PM
How do you cover the back of your truck? aname4me Tow Vehicles 34 03-01-2011 12:36 AM
