Old 07-04-2014, 02:08 PM   #1
2014 25' International
corte madera , California
What kind of towing assembly is best?
I'm curious to know what most Airstream users prefer to to use for towing.
I have an E2 Equalizer with round bars between the Airstream hitch and the vehicle. I know it's supposed to spread the weight distribution.
My Airstream dealer recommends them.
It sure seems like an extra layer of complication though and I have seen some articles online that question it's value.
My Airstream is 25 ft long.
What do the experienced Airstreamers favor?
thanks
Phil
philian is offline   Reply With Quote
Old 07-04-2014, 05:41 PM   #2
2020 Classic 33 on order
Box Elder , South Dakota
Phil most dealers like what they sell. I like ProPride and the dealer did the install. ProPride only sells direct. I bought the ProPride based on all of the comments and information here on the forum. Do a search for ProPride in the forum section on hitches. There is a complete ProPride section.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 07-04-2014, 05:54 PM   #3
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
thanks
Phil
Welcome. And you've asked an impossible question :-)
There are (too) many threads in the forum addressing this type of question. It's a little like asking - what's the best ice cream? I go back and forth with pistachio and frozen pudding. Some actually prefer vanilla. We're all happy with our choice (usually).
There are lots of choices based on your objectives. You mentioned the EQ seems to have an extra layer of complication. For ease of setup, maybe Andersen is right or you. I don't recall seeing what your tow vehicle is, but if it only requires 50% of the front axle weight to be restored, the Andersen could be for you.
The ProPride mentioned earlier is more complicated and more expensive (about $2K to Andersen's $500). Once set up and practiced, hitching is easy. This hitch and it's predecessor the Hensley Arrow are unique in that they project the pivot point forward and literally prevent away from happening (other hitches react to it).
That's just 2 of many examples.
What's of interest to you in terms of:
Weight distribution
Cost
Sway prevention vs sway reaction
Ease of installation
Ease of hookup
That can help in which one is best for you. :-)
Good luck!
Old 07-04-2014, 05:56 PM   #4
1974 Argosy 20
Kooskia , Idaho
And I love my Andersen hitch (ducks), simple and works very well for me.
You will find someone who loves each and every hitch made and will argue tooth and nail for it as the best one ever. The fact is that each one has different positive and negative aspects and no one hitch will satisfy everyone, depending on their needs and tolerance for the negative aspects they all have.
I towed for many years with a Reese, which I still have and always worked well for me. Then an EZ lift and still own that one too. Both did the job.
The simple answer to your original question is that there is no simple answer.
Old 07-04-2014, 06:29 PM   #5
jcl
Vancouver , British Columbia
"What kind of towing assembly is best?"
The one that is properly installed and set up. Everything else is up for debate.
Lots to choose from. Recommend you use weight distribution with that size trailer.
From an engineering design perspective, the hitches that project the pivot point (Hensley, Propride) forward to a point near the rear axle have an advantage. They also cost more.
Jeff
jcl is online now   Reply With Quote
Old 07-04-2014, 06:58 PM   #6
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Boy oh boy, I bet that each hitch type is represented on this forum. But I WILL say that the two, in my opinion, when I was digging on this forum, talked about setups were Hensley Arrow and Pro Pride. Of course they are the pricey ones. The Hensley is a time honored hitch (the arrow I believe) search on here for it and you will uncover loads of info. The second one, a newer design from the same guy is the pro pride. Sean, the marketer of ProPride is on this forum and works one on one with you if need be. Search and you will find!
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 07-04-2014, 08:13 PM   #7
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Everyone loves what they have, until they get something different.
We had Equal-I-Zer, Andersen, and now ProPride. I loved the first two until I used them for awhile. After extended use of the ProPride in all towing conditions, it's the best money we spent on our Airstream.
Doug and Cheryl
Roadmaster Falcon 2 towing assembly Support Admin Airstream Classifieds 0 09-20-2013 08:05 AM
vintage towing, "kind of" fourcatos Tow Vehicles 0 04-27-2012 07:08 AM
Best towing with 1 or 2 axles? Big Bad H Tow Vehicles 24 10-29-2007 10:57 PM
Best towing bet for a new 27 stowaways Tow Vehicles 29 10-09-2007 02:56 PM
Best towing vehicle wayneh Off Topic Forum 23 05-19-2006 05:58 PM
