Old 06-07-2013, 06:09 AM   #15
SteveH's Avatar
Common Sense , Texas
Mercury7,
If you must go with an Andersen hitch, and you may be able to use it OK with a '59 24 footer, I would advise that you weld the brackets to the tongue, or at least what I did, weld some stops to the tongue to prevent the brackets from sliding. Other than the coupler problem, this seems to be the biggest problem with the Andersen.
Regards,
Steve
Old 06-07-2013, 10:41 AM   #16
mercury7's Avatar
1959 24' Tradewind
easley , South Carolina
Thanks Steve, new rig though ,72 sovereign towed by 2000 excursion
Anticipate approx 6000lbs loaded 600 tongue weight
mercury7 is offline   Reply With Quote
Old 06-07-2013, 03:50 PM   #17
1988 32' Excella
Robbinsville , New Jersey
Originally Posted by AirHeadsRus View Post
What do you think the cut off for the low tongue weight would be?
It varies by vehicle but, I have seen on some 1/2 tons 500 lbs as the max weight without WD.
Old 06-07-2013, 03:56 PM   #18
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question What kind of hitch is this....
.....a very rusty 54 year old that probably should be replaced.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
