Old 07-15-2018, 08:00 AM   #1
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
What is wrong with this?
Speechless.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 07-15-2018, 08:02 AM   #2
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
Oops.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
Caffeinated is offline   Reply With Quote
Old 07-15-2018, 08:06 AM   #3
2018 27' Globetrotter
Tulare , California
Trailer electrical cord
HDsteel is offline   Reply With Quote
Old 07-15-2018, 08:07 AM   #4
Reads a lot
Titusville , Florida
Oh my!
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
Old 07-15-2018, 08:14 AM   #5
JayleNBob's Avatar
2015 27' FB Eddie Bauer
Silvis , Illinois
The safety chains should be under the hitch, not on top. The idea here is that when properly installed, the safety chains would "catch" the trailer tongue if it ever disengages from the hitch ball.
JayleNBob is offline   Reply With Quote
Old 07-15-2018, 08:20 AM   #6
AlinCal's Avatar
1991 25' Excella
See anything else?
Will Rogers
Alan
Old 07-15-2018, 08:29 AM   #7
JayleNBob's Avatar
Silvis , Illinois
A coupe of things: I don't see the cable from the emergency brake switch attached anywhere; I would recommend putting a pin or a lock in your hitch lever for safety and/or security.
Old 07-15-2018, 08:30 AM   #8
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
How are the chains connected to the snap-up brackets?
Old 07-15-2018, 08:54 AM   #9
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
Looks like they are from my state too....it's not me
Steve "Centennial Man"
centennialman is online now   Reply With Quote
Old 07-15-2018, 09:03 AM   #10
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
It doesn’t look like the WD chain bracket is lifted and snapped in to place (but it is hard to tell from the picture.)
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 07-15-2018, 09:15 AM   #11
AlinCal's Avatar
1991 25' Excella
Other side
Will Rogers
Alan
Old 07-15-2018, 09:24 AM   #12
2018 30' Flying Cloud
Gig Harbor , Washington
It could be the camera angle, but it looks like the neck of the trailer hitch is angled upwards almost bent. And hard to tell if the brake cable is connected.
hoagy_007 is offline   Reply With Quote
Old 07-15-2018, 10:46 AM   #13
HowieE's Avatar
Princeton , New Jersey
Images: 12
In the second picture some things are more evident.
The brake away cable is there but it looks like the excess length is gathered up on top of the hitch. That cable should be cut to a length that the brakes would be activated before the safety chains reach full extension. This insures the brakes are fully on while the trailer remains behind the TV.
The tension chain on the drivers side appears to be hooked on the leverage point of the hanger rather than the Hook provided for it. If the chain is not connected correctly the natural toggling effect of the hanger, that keeps the chain from popping off the hanger, is lost.
I like to route the umbilical cord and the brake away cable across the top of the cup of the hitch. This ensures they can not get caught in the system and actuated accidentally. Your coupler lacks the point of attachment, common to older couplers, that makes this possible. But you could make something to provide this function.
Yes the safety chains should be under the hitch and crossed to prevent binding when turning. Unfortunately many trailer manufactures have no idea of what the chains are for and thus no longer mount the correctly to the trailer tongue. Then tend to mount them to a single point centered on the tongue. If crossed the chains provide a cradle to catch the trailer tongue if it disconnects from the ball. The chains should be cut as short as possible to form this cradle while not allowing any binding with the bottom of the hitch when turning.
2004 Excursion 4x4
Old 07-15-2018, 11:27 AM   #14
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
The guy next door did not pay his water bill and has stopped watering his grass and it has turned to red dust?
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
***Support Airstream Forum***
turk123 is offline   Reply With Quote
Refrigerator thermostat readout - wrong wrong wrong BoldAdventure Refrigerators 12 09-18-2015 05:02 PM
Buck rivets look wrong?using wrong air hammer bit? shadeemry Ribs, Skins & Rivets 11 06-07-2014 07:42 PM
HELP with Brakes- Wrong TV? Wrong AS? Flying Gypsies Brakes & Brake Controllers 7 07-24-2011 07:04 AM
Polishing ...Help, I'm doing it wrong Safari Tim Cleaning, Stripping & Polishing 38 09-04-2003 07:17 PM
wrong rally adress Perry Forum Rallies & Meet Ups 0 03-02-2003 02:36 PM
