Old 09-15-2019, 05:09 PM   #81
2007 27' International CCD FB
San Diego , California
HD trucks are potentially a false sense of security when it comes to dynamic handling. Ballast does not help in that situation...
70-0 braking distance
F250 Diesel 4x4 - 202ft
F150 EB 4x4 - 175ft
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i - Rear Hitch - Underbelly Storage - Blizzard NXT w/ EasyStart - 3" Lift - 6" Fan Controller
pteck is offline   Reply With Quote
Old 09-15-2019, 05:24 PM   #82
2019 28' Flying Cloud
2014 22' FB Sport
Davie , FL
It would be interesting to see braking distance tests between those two while pulling a trailer.
out of sight is offline   Reply With Quote
Old 09-15-2019, 08:04 PM   #83
jcl
Vancouver , British Columbia
No, it wouldn’t. Nothing about hooking up the same trailer to each truck improves the F250 braking distance compared to the F150. This is just basic physics.
What may come into play is the fade resistance. So, an unskilled driver, descending too quickly for their rig, overusing the truck brakes, and not utilizing the trailer brakes properly, could have more safety margin with the heavier truck, until the brakes eventually fade. As they will.
Or, they could drive properly.
jcl is online now   Reply With Quote
Old 09-16-2019, 08:33 AM   #84
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
"No, it wouldn’t. Nothing about hooking up the same trailer to each truck improves the F250 braking distance compared to the F150. This is just basic physics."
I think this statement is just plain incorrect.
The 250, by virtue of its extra weight on the tires, will provide more braking for the combined rig than the lighter 150.
Old 09-16-2019, 09:01 AM   #85
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
The Ferrari SF15-T weighing in at about 1,400 lbs stops from 70 mph in less than 50 feet. It's all about mass.
If the heaviest thing stopped the fastest, then cement trucks would be kings of the road.
kscherzi is online now   Reply With Quote
Old 09-16-2019, 09:27 AM   #86
1986 31' Sovereign
Miami , Florida
No, the extra weight on the wheels of the F250 is more than offset by the increased mass. You have four relatively small tire patches on the road...
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 09-16-2019, 09:37 AM   #87
1988 25' Excella
1987 32' Excella
No, the heaviest thing does not stop the quickest. In fact, when you do the math for stopping the weight is in both sides of the equation and cancels out. Stopping distance is related only to tire traction and of course if you have enough braking power to use the traction.
But...when you hook up a trailer the numbers shift. Say a 6000 lb trailer with 1000 of that tongue weight. The 1000 lbs tongue weight adds that much down force to the TV for braking and cancels out. But the remaining 5000 lbs weight drives the rig foward without adding any braking force. You are essentially doubling the force forward without adding any down force for braking. So when you are pulling a trailer the TV weight does matter and more is better. If you have enough braking force to use it.
Now, if you really believe the TV stops the TV and the trailer brakes stop the trailer then, yes, the weights are irrelevant and the total rig stops in the same distance as the TV alone. I have 10 inch electric drum brakes on my trailer. They do not do the job alone. The wiring comes loose. They overheat and fade. You could stop a trailer fine with the Ferrari if the trailer has hydraulic disc brakes that work as well as the car. But with my trailer the Ferrari just might end up sliding along in front of the trailer for a spell.
On a side note, there is no such thing as "simple" physics.
Old 09-16-2019, 10:06 AM   #88
Ray Eklund's Avatar
2019 27' International
2014 25' International
Boulder City , Nevada
Bill M. must have read the Dexter Brakes Not Working on One Side of a 25 foot International.
Towing is one matter. Anything that has a 2 inch hitch probably can pull a trailer. It is the stopping that is an issue. When your tow vehicle's tires are locked up and leaving tire rubber at the intersections (although ABS rules today)... it is WORSE. Try some snow on the road, braking with trailer in tow.
We are all helpless in ice and snow. Even a wet newly asphalted highway can give you goosebumps.
You will have braking power and the rear end... dragging power. Works for you, great. I am not a mathematical genius... although having good judgment is a better trait of living longer and with less stress.
Many prefer to fill the fuel tank to full. But if your setup is overweight, do you only fill the tank 50%?
I am not convinced that I should give up my F350 Diesel Rivet Popper just yet. At may age longevity is my current plan of attack to save on Estate Taxes. Not because I am towing with a beast, but my biological clock is at 80% used up. So, what the hell... if I keep my F350 and exercise it and myself... I may beat the odds.
I do not guarantee anything I post. I am old, mostly senile and developing a crabbier point of opinion. So... we are leaving for our FREE Casino breakfast in ten minutes. I will feel better... if the food is as good as they claim.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 09-16-2019, 10:28 AM   #89
1988 25' Excella
1987 32' Excella
"Bill M. must have read the Dexter Brakes Not Working on One Side of a 25 foot International."
Did not read it. Did crawl under my trailer 2 weeks ago in Nebraska as we were headed home and found both brakes with broken wires on the curb side. I had noted diminished braking power and a slight pull to the left when braking.
Old 09-17-2019, 11:06 AM   #90
Half a Rivet Short
Carlisle , Pennsylvania
The highest speed limit in the US is in West Texas at 85 MPH. Trailers, though are limited to 80 MPH. An Airstream can safely travel 87 MPH (the speed rating of the tires) if you have an adequate tow vehicle.
Hi
Indeed some Airstream tires are rated to a lot more than 87 MPH ....
I very much doubt that the *brakes* an any Airstream are going to make it down from 87+ MPH without a bit of fade.
Old 09-17-2019, 12:07 PM   #91
2014 22' FB Sport
Davie , FL
I never had a brake failure in my life, but since I've owned Airstreams I've had two of them. One occurred when I lost a tire. The tire debris damaged a wheel well and severed the brake wire. The other was a failure of the Tekonsha brake controller. Make sure your tow vehicle has good brakes that can step in when needed.
Trailer tires are indeed important. Your tow vehicle's tires, the rears especially, are probably more important. Keep them inflated to the maximum. Also get a TPMS for all your tires.
Old 09-17-2019, 12:19 PM   #92
1988 25' Excella
1987 32' Excella
When all said and done I still think a well set up F150 will stop and pull a Airstream just fine. But I also think that a F250 will do it better and last longer while doing so. The trade off is between driving empty and actually pulling. Gas or diesel. Personal choice. I pull with a 2500 diesel.
Old 09-17-2019, 01:54 PM   #93
bono's Avatar
Mountain View , California
This is what AS President has to say about tow vehicles.
https://youtu.be/6Vi37dKPCrg?t=426
BMW X5
SOB 33 ft trailer
Propride 1400
bono is offline   Reply With Quote
Old 09-17-2019, 03:39 PM   #94
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Jay suggested a 250. Bob said yeah - or the F150 which is a favorite for his customers. He also said the weight of that LandYacht was about 6200# (that’s surely dry, not loaded) and since an F150 doesn’t weigh 9300# (1.5x6200) I’m not seeing where AS is possibly making a recommendation of 1.5X the weight of the trailer. Maybe there’s a 1.5 ratio somewhere but not between trailer and TV weight as far as I can see.
Old 09-17-2019, 05:31 PM   #95
2014 22' FB Sport
Davie , FL
One has to wonder how many trailers Airstream would be selling if they only sold them to customers with properly sized tow vehicles instead of anybody with a small vehicle and a weight distribution hitch.
Old 09-17-2019, 06:57 PM   #96
bono's Avatar
Fortunately, at AS there are people who understand how towing works and apply a "proper" logic to their business.
BMW X5
SOB 33 ft trailer
Propride 1400
Old 09-18-2019, 10:20 AM   #97
Peter B's Avatar
1994 25' Excella
Calgary , Alberta
Tow Vehical
The Ford F-150 eco boost. is more than enough to tow and it has the new backing up assist. It handles over 11000 lbs tow capacity and is great on fuel. I have the 2011 and it pulls my 25’ excella with water and as much as my wife can think to pack. And I can barely tell it’s behind me.
Happy trails.
Peter B is offline   Reply With Quote
Old 09-18-2019, 10:24 AM   #98
2014 27' FB Classic
Cassopolis , Michigan
We use a Ford Expedition Max to tow our 27 FB Classic.
We got rid of our ‘16 F250; wecouldn’t stand the bouncy, punishing ride when empty.
The Expedition is so much more comfortable, and tows just fine with its EcoBoost engine, even in the mountains. Mileage without the trailer is 17-20, with trailer around 8 mpg. And the Expedition is easy to park and back up the trailer, as opposed to the long turning radius of the F250.
biyak269 is offline   Reply With Quote
Old 09-18-2019, 10:50 AM   #99
Renassiance man
2012 25' FB Eddie Bauer
Simi valley , California
Originally Posted by stef0597 View Post
My husband is way too excited about getting a truck to tow our new Airstream. We are considering a 27fb Flying Cloud. He says we need more tow capacity than 8500. Is that true?
You should pay attention to the axle ratio!!!! A 410 is way overkill for a lighter trailer and will cost a lot more in fuel and wear and tear on the engine, I tow for a living and have a 373 rear end which allows me to really get up and cruise on the highway and I can maintain my rpms up almost any grade by locking out my overdrive for the relatively few miles I m climbing a grade
Brentsdeal is offline   Reply With Quote
Old 09-18-2019, 10:51 AM   #100
2017 25' Flying Cloud
Manchester , New Hampshire
I think Stef just bought a Pup Tent.
Steven62 is offline   Reply With Quote
Need a Tow Vehicle for a 27FB Flying Cloud chuckkubly Tow Vehicles 40 04-30-2015 12:47 AM
2011 Airstream 27FB Serenity LIKE NEW!!! S2011 Airstream 27FB Serenity LIKE NEW!!! eBay Watch Airstreams on eBay 0 08-19-2011 03:00 PM
2011 Airstream 27FB Serenity LIKE NEW!!! S2011 Airstream 27FB Serenity LIKE NEW!!! eBay Watch Airstreams on eBay 0 08-12-2011 02:50 PM
2011 Airstream 27FB Serenity LIKE NEW!!! S2011 Airstream 27FB Serenity LIKE NEW!!! eBay Watch Airstreams on eBay 0 08-05-2011 10:50 AM
2011 Airstream 27FB Serenity LIKE NEW!!! S2011 Airstream 27FB Serenity LIKE NEW!!! eBay Watch Airstreams on eBay 0 07-29-2011 10:40 AM
