Old 04-08-2014, 08:39 PM   #1
willapus's Avatar
Memphis , Tennessee
What did I do right?
I have made a few seemingly minor adjustments to my set up but have noticed a huge difference while towing as far as sway is concerned. I am curious to know from you guys what you think made the biggest difference. The hitch and sway bar are exactly the same. To the camper, I added 6 gallons of water to the hot water tank which is just behind the driver's side tires. I also had the front of the trailer about 3" higher than the back because I didn't have time to lower the ball to the next set of holes before our trip to the keys. I have since made that adjustment, but haven't towed for any distance. For the TV, I just upgraded my 2002 Toyota Sequoia with 201k to a 2005 Toyota Sequoia with 97k. They are almost practically the same truck with the same wb. The 2002 had LT 245/75 R 16, 80psi, max. and the 2005 has P265/65 R17, 45psi max, tires. The body is the same, but the track went from 76" to 79". Also the newer truck has the addition of factory rear airbags. The whole set up seems much more secure and stable. With the old set up I was comfortable at 60 and occasionally at 65, but terrified at 70. The the new set up I was able to comfortably drive at 70 for long days, 8+ hrs and even one 16hr day, a personal record. A couple of times I was surprised to see 75! For the record, I'm not looking to go any faster and in fact like going slower so that I don't have to pass anyone. Tire ratio, track, airbags, 100k less miles or extra weight of hot water? I do seem to think that the 2005 truck by itself doesn't get blown around as much at highway speeds. I'm discounting the high mileage because the wind was always noticeable in the 2002 when it was blowing hard and I was cruising down the highway. Thanks.
Will
'67 29' Streamline Empress
'05 Toyota Sequoia 4x4
'65 Buick Electra 225 convt.
willapus is offline   Reply With Quote
Old 04-09-2014, 07:38 AM   #2
dznf0g's Avatar
Oswego , Illinois
I would think lowering the front of the trailer had the biggest affect on your improvement.
-Rich-
Old 04-09-2014, 08:56 AM   #3
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I think it's hard to tell. A few parameters have changed but the most significant that I can see at a quick look is the 3" track change = more stability. Whatever the reasons, enjoy the improvements. See ya on the road sometime.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 04-09-2014, 09:13 AM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Leveling the trailer effectively shifts weight away from the back to the front, always a stabilizing factor. Less wind working the trailer's lower and more streamlined profile.
The newer truck is more stable, a huge difference. The wider track. Lower profile tires do not have the lateral movement (you could actually improve this with stiffer sidewall XL rated tires). The lower mileage probably gives a less worn, tighter suspension laterally, very significant.
Doug and Cheryl
Old 04-09-2014, 09:23 AM   #5
willapus's Avatar
Memphis , Tennessee
The trailer nose was actually higher with the 2005. I have since gotten it lower and level again by lowering the hitch head.
Will
Old 04-09-2014, 09:38 AM   #6
dkottum's Avatar
Think about over 65 mph with the high profile, short wheelbase, solid rear axle Sequoia makes me nervous though. Never know when something comes in front of you or pushes you into a sudden lane change.
Doug and Cheryl
Old 04-21-2014, 01:39 PM   #7
willapus's Avatar
Memphis , Tennessee
Little update. Just towed the Streamline with the hitch head 1.5" lower than last time. It now trails level, however, I didn't notice a significant change sway.
Will
Old 05-02-2014, 03:17 PM   #8
1965 mustang's Avatar
Stoughton , Wisconsin
How big is your trailer and what are you getting for mpg?
1965 mustang is offline   Reply With Quote
Old 05-02-2014, 04:31 PM   #9
willapus's Avatar
Memphis , Tennessee
I have a 28' streamline trailer that weighs just less than 6k lbs total packed. I tow with od off and get between 9&12mpg depending on speed, wind, and grade. I average it out to about 10 going 65/70.
Will
Old 05-03-2014, 12:01 PM   #10
We have a
Old 05-03-2014, 12:23 PM   #11
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Why are you in such a hurry? 70-75 mph, 16 hour days...
Poppy
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 05-03-2014, 12:38 PM   #12
We have a 2005 tundra double cab 4x4 and just picked up a 05 safari 25'. So far I have only towed it home from Minnesota to Wisconsin. Our trucks are basically the same, so I was wondering how your truck pulls and if you feel you have a big enough truck.
Old 05-03-2014, 10:45 PM   #13
willapus's Avatar
Memphis , Tennessee
Poppy
Well usually 65/70 and 8/10hrs a day until I get to the mountains or near my destinations and then I cut those in at least half. This past trip I was particularly motivated by wife, kids, work, and weather. Plus, I generally love the open road and find it relaxing.
Short answer is yes. This is my second sequoia and I love it. I looked for a double cab tundra and a Denali xl too. I couldn't find the double cab locally and the sequoia fits my needs better anyway. I watch my weight because I'm near capacity as I'm sure you will be too. I have changed my driving habits and expectations. I tend to drive slower than everyone else now and just let them deal with me. I also give myself a lot of braking room until someone cuts in front of me and then I give myself more room. I try to give a lot warning and indications that I'm merging or changing lanes. I try to make easy transitions. As far as towing with the truck, it handles and pulls and stops just fine. The temp gauge is in the same position for when the truck is towing with the ac on full driving across ok in triple digit heat or pulling a long grade like monarchs pass or just running around town with the kids w/o the trailer. I tow with the od off and with the rpms in the 3-4k range all day long, uphill, downhill, or flats. I tend to keep the rpms in the low 3ks though and downshift to keep in the power band. I also use a brake controller, wd hitch, and sway bar. I air up the tires to max. psi. Feel free to send a pm with any questions. Happy trailering and congrats on the new rig.
Will
Old 05-25-2014, 06:40 PM   #14
Name:	ImageUploadedByAirstream Forums1401064840.745867.jpg
I did look I really did bennu36 Sprinter and B-van Forum 11 08-12-2013 01:01 PM
Right Rear Tire Wearing on Outside & Right wheels Closser together than left wheels Tnsawdust General Repair Forum 7 04-10-2009 07:49 PM
The right acid works with the right applic got polish Cleaning, Stripping & Polishing 1 07-17-2008 08:50 PM
Choosing the Right Model Airstream MH grassgd Airstream Motorhome Forums 13 01-06-2003 09:59 PM
