Old 12-07-2015, 10:14 PM   #43
Caroyl's Avatar
1964 26' Overlander
Warner Robins , Georgia
Originally Posted by HowieE View Post
More than likely not one of the newer cheaper couplers. To be sure, if you can not read the numbers on the top of the coupler, post a picture with the latch in the open position and a close to the coupler as you can.
Since mine was the first or second trailer to have a problem with the coupler and call it to Andersen attention I think I can comment on the cause. The failure of the shark fin on the newer couplers is effected by road conditions. The poor the road the sooner the failure. New Jersey has some real poor roads and the other trailer came from Long Island which has even poorer roads.
My daughters trailer uses the Andersen and I have not seen a problem yet. The original Reese used on the trailer left lot to be desired with respect to steering control.
I'll look more closely next time I see the trailer. This is the only picture I have now.
Caroyl is offline   Reply With Quote
All access panel locks damaged... can I drill them to open them? flaagan Exterior Storage Compartments & Access Doors 13 05-19-2015 03:42 PM
Sway bars and sway control phibbs Towing, Tow Vehicles & Hitches 1 09-03-2012 05:48 AM
Keep them or send them back? JimW Tires 11 05-04-2010 01:01 PM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 08:28 AM
Do I need sway control, weight bars and a good tow vehicle? Silvertwinkie Hitches, Couplers & Balls 28 07-19-2004 07:42 AM
