02-26-2008, 10:48 AM
1977 29' Ambassador
Latrobe
, Pennsylvania
What? A 7 round plug??
We're going to look at a 1977 29' Ambassador this weekend and we're going with tow gear hoping to buy it. This would be our first camper outside of a pop up and our first AS. It's for sale at an RV dealer. They told us on the phone that AS used a weird 7 round plug and they don't know how you plug it into your car (currently have a 7 flat plug on our car).
Could someone here enlighten me? Do I have to rewire the AS plug to a modern 7 flat? Is there an adapter to go from an AS 7 round to a modern 7 flat? If so, where do I get it?
I need something to tow it home 2.5 hours this weekend (hopefully)
Advice, suggestions, etc all welcome! Thanks!
02-26-2008, 10:53 AM
Trailerite
1971 23' Safari
Riverton
, Missouri
You have to rewire the plug to the new flat 7 prong plug. It needs the wires changed from the old standard to the new standard, too.
Michael.
02-26-2008, 11:51 AM
1977 29' Ambassador
Latrobe
, Pennsylvania
The dealer just emailed me a pic of the plug and now I'm really confused. It's just a plug with pins in it in the wall of the AS. There's no cable. What am I not understanding here?
1979 23' Safari
1954 29' Liner
Orange
The round plug is not wierd, it was the standard in the 1970's. It is still used on 18 wheelers and can be purchased at truck stops. Since you have the flat plug on your tow vehicle, you can either change the tow vehicle or the trailer. You will need a wiring diagram of the old plug as it is different from the current standard.
There are some who believe that the round plug works better and does not fail from corrosion as easy as the flat type.
bill
Just my personal opinion
https://billbethsblog.blogspot.com/
02-26-2008, 11:56 AM
1979 23' Safari
1954 29' Liner
Orange
You need a cable with plugs on both ends, common in the boating world. Like this but with seven pin plugs on both ends: Trailer Parts Superstore - 4-Pin Coiled Nite-Glow Extension Harness #47045
Bill
02-26-2008, 12:28 PM
1977 29' Ambassador
Latrobe
, Pennsylvania
OK we're thinking if we buy an umbilical cord and put a 7 round on one end and a 7 flat on the other then we can use the cord as an adapter. Everyone agree this is a doable plan? If so, then I need to find out where I buy an umbilical cord and the plugs. Thoughts? Oh and I need it here in like 2 days
Thanks again, you guys are the best!
02-26-2008, 12:39 PM
1979 23' Safari
1954 29' Liner
Orange
Yes, you can do that, it will make it more difficult for someone to "borrow" your trailer since the borrower will not have any trailer lights or brakes.
The cable is available at RV supply stores, such as Camping World as is the flat plug for the round plug you will need a truck stop or perhaps a well stocked auto parts house.
Bill
02-26-2008, 12:50 PM
1979 23' Safari
1954 29' Liner
Orange
This is what I was looking for earlier. Unfortunately, it come with the flat plug only: Jet Connex
Bill
02-26-2008, 01:59 PM
1971 27' Overlander
Central
, Ohio
Advance Auto Parts at Mission and Lincoln has 4 7 pin round plugs in stock. You'll need that and a cable with a 7 pin flat that you can get from an rv dealer - Advance may have those also. That cable will have bare wires on the other end to wire your round plug to.
02-26-2008, 02:08 PM
2001 19' Bambi
Falmouth
, Massachusetts
Breiz,
Be sure to follow the very important suggestion from Bill above, and CONFIRM the wiring of your existing trailer connection.
I use the 7-circuit, round-pin, round body Pollack connectors on my tow vehicle and my Bambi. I have found these more reliable and less prone to corrosion than the original 7-circuit flat-pin Bargman connectors. But the flat-pins have been used very successfully by millions, and, as all connectors, are generally quite reliable when maintained.
A good place to start is: How to Wire your Car or Truck for Trailer Lights, which shows a wide variety of connectors and provides suggestions on installation and testing.
Tekonsha has a page describing 7-conductor flat-pin connectors and wiring on the site: http://www.tekonsha.com/files/wiringdiag.jpg
One website with diagrams of 'standard' wiring of 'round-pin' round body trailer connectors can be found at: trailer_wiring_diagram.
Also see, for example, sites showing 7-circuit connector wiring diagrams for various tow vehicles; for example: Marksrv.com 7 way wiring diagram page .
It is also critical that you not assume that wire color-codes inside multi-conductor cables are standardized. Always use an ohmmeter to trace each wire to the associated pin of the connector.
When you can confirm the circuitry of your trailer connector, then you can decide to change connectors or make a custom cable.
Post any questions on the site and you'll have plenty of good suggestions.
Regards, Marshall
Marshall Swartz
2001 19-ft Bambi
2013 Honda Ridgeline RTL
02-26-2008, 02:44 PM
1977 29' Ambassador
Latrobe
, Pennsylvania
OK new info:
The dealer just emailed me and said she does have the cable for the AS, however BOTH ends on the cable are 7 round male ends. Why would they both be male? Looking at the pic she sent me of the 7 round receptacle on the AS body, it looks male to me.
02-26-2008, 02:50 PM
2001 19' Bambi
Falmouth
, Massachusetts
Breitz,
I see you're in Latrobe. I grew up in Greensburg, where I got my Bambi.
Ten miles from your home you can contact Carl and Alex, who used to be at Turner Airstream (until it closed) and are now at Airstream of Western PA (Ranger Trailer) in Greensburg, near the old ITE transformer plant in Southwest. Give them a call at (724) 837-2753 to discuss your needs and they may have a suggestion.
Also, on the etrailer site you'll find: Adapter 7 Way (Blade) to 7 Way (Round Pin) 37595 : Trailer hitch bike rack and trailer hitches - etrailer.com
Good luck,
Marshall
Marshall Swartz
2001 19-ft Bambi
02-26-2008, 02:58 PM
1969 25' Tradewind
Irmo
, South Carolina
I use the old 7-round. My father's trailers all have them, so it made it easy for me if I needed to borrow one of his big utility trailers or the car hauler to have the plug already installed on the truck. I keep a supply of adapters in my truck toolbox for hitching up to other things, just in case.
02-26-2008, 03:03 PM
2001 19' Bambi
Falmouth
, Massachusetts
Also see this thread on the forum which discusses a special 7-circuit plug on a late-60's era Airstream:
http://www.airforums.com/forums/f37/...pin-17761.html
Marshall Swartz
2001 19-ft Bambi
02-26-2008, 07:30 PM
2005 25' International CCD
1960 18' "Footer"
Riverside
I am confused by something that Breiz said at the beginning of this thread; hooking a old 7 pin connector to a modern "flat" 7 pin connector. I have not seen a 7 pin flat connector on any modern tow vehicle, Dodge, Ford, Chevy, Toyota, etc. The only flat connectors I am aware of are four pin for lights only; brake, running and turn signal but no electric brake control. Our Dodge has both connectors but the four pin is just for light utility trailers, the 7 pin is a "modern" connector for heavy trailers with brakes.
Did I miss something or is there another style connector
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
SNU #157
FCU #004
02-26-2008, 07:38 PM
Area 63 Productions
1958 22' Flying Cloud
1963 19' Globetrotter
Orange
Both connectors are round, but the one in question here has round pins inside a round plug. The commonly used, low amperage RV one has 7 flat pins inside the round plug.
02-26-2008, 07:40 PM
1984 34' International
1977 Argosy 24
Central
, Georgia
The plug itself is round. The flat connectors are in reference to the actual contact points built into the plug. RV plugs have flat contact points. Commerical 7 pin plugs have round pins for connection.
Travelers by aluminum roadships, loyalists to one species,
masters of convenience, herdsmen steeped in maintenance and restoration.
02-26-2008, 07:41 PM
Area 63 Productions
Orange
This should shed some light on things.
Airstream, Inc :: FAQ
The 7-round plug is indeed a better quality connection. If it were me, and if I did not have to pull other trailers, I would convert the truck end to a 7-pin round and make the umbilical cord with 2 of the same round plugs. They are self cleaning, and provide a better electrical connection than the flat terminal RV plugs. There is a reason the professional drivers use these in their 18 wheelers. I have used the 7-pin rounf metal truck end on both my Suburbans, and foud them to be a very positive and safe connection.
However, the standard is still the 7-pin flat.
02-26-2008, 11:07 PM
1978 31' Excella 500
Venice
Another point of confusion. The overall shape of the plug on the AS umbilical cord is round male, BUT, the actual connectors are female. The pins are in the TV and trailer, the sockets are in the umbilical. Clear as mud, huh?
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
02-27-2008, 02:37 PM
1977 29' Ambassador
Latrobe
, Pennsylvania
Yes, my suburban connector is round in shape, I meant the pins were flat. So today I went to murray's auto Electric and bought an $8 connector that has one end where the umbilical will go in and another end that will plug into my 7 pin fla t on my Suburban. So the current plan is to use their umbilical, plug one end into the AS, hack off the other end and attempt to wire it to the newly purchased 7 pin flat connector. If that works, the I'llend up with an umbilical that has a 7 round on one end and a 7 flat on the other. Then, in theory we can plug into the Suburban and go (if only it is that simple). We're going to attempt this in the rv dealer's parking lot, did I mention that? Wish us luck!
The main problem I can see (aside from the ridiculous weather here in PA) is that we could wire it correctly only to not have any lights function. Then we'll be wondering did we wire it wrong or were the lights non-functioning already.
