Old 02-15-2014, 07:38 AM   #1
Pat Cassity's Avatar
2015 27' FB International
Montgomery , Texas
Weights - What's it all mean?
So Yesterday, I decided to take my Suburban and 27' International to the nearest CAT scale. I came away with some numbers but I believe I need some help determining what they mean. Also, I realized when I left that I did not separate front and rear axel weights. Here is what is on the printout:
1st weight
Suburban only (unhitched) - 5780lbs ( gross weight)
2nd weight
steer axle - 6860 lbs
Drive axle - 5480 lbs
Gross weight - 12340
The Suburbans GVWR is 7200lbs. The 'curb weight' is 5846 lbs
It would appear that I am ok as far as not exceeding my TV's GVWR but what confuses me is the trailer weight of 5480 lbs. Airstream states that the unloaded weight of the 2014 27' International to be 5600lbs. I have added approximately 150 lbs ( if not less) into the trailer and all water and holding tanks are empty. Is this the result of the WD hitch?
Your thoughts?
Retirement! Every day's a Saturday and Monday's no longer exist!
Pat Cassity is offline   Reply With Quote
Old 02-15-2014, 07:54 AM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Hi. Good start but I think you need some additional info to really see what's going on. Here's a link to a CAT scale "how to": http://catscale.com/how-to-weigh
Can you post pics of your tickets? You need one where the front (steer) and rear (drive) axles if the tow vehicle are on their own (unhitched) so you know what you start with on each axle. Then when you connect the trailer you weigh again (preferable without applying weight distribution) to see the impact on the tow vehicle. This is where you'll see (probably) a few hundred pounds get lifted off the steer axle and a few hundred loaded on to your drive axle. Then you can apply weight distribution to dial in what you need to restore the front axle to whatever the desired restoration is (for some it's 50% for some it's 100% - your tow vehicle's documentation will provide a recommendation). Don't worry if the trailer seems light - those published weights are max. Mine cants exceed 7200 but weighs in at 5880 loaded for camping.
Also, it's best to do all those weights with a full tank of fuel in your tow vehicle, and full propane and fresh water tanks on your trailer (full black tanks would be ideal for max load - no pun intended). If you travel with people, pets, luggage and gear, have that with you too. You're trying to set a baseline fully loaded for camping.
See if that link helps any. It might take a few trips to the scales at first (I think I went 6 times with several weigh ins each time) before I understood what I needed to see. Odds are you'll get it faster than me! :-)
Good luck!!
Old 02-15-2014, 08:22 AM   #3
Montgomery , Texas
Name:	ImageUploadedByAirstream Forums1392474086.285651.jpg
ID:	205621Click image for larger version
Name:	ImageUploadedByAirstream Forums1392474099.995089.jpg
Here are pictures of the Cat Tickets
Old 02-15-2014, 08:39 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
It appears you were not placed correctly on the scales. I say this because of the excessive weight of the steering axle during the loaded weight.
A cat scale has 3 plates designed to weigh the steering axle, dive axle, and trailer individually while the combination is on he scale.
I would go back and before driving on the scale study the plates and position your truck on the 2 smaller plates so the steering and drive axles are on individual plates. The hitch up and return with the trailer. The 3 sets of axles should be on 3 different plates for this weigh for this weight.
It is not necessary to get weights while loaded with your WD hitch loaded and unloaded.
2004 Excursion 4x4
Old 02-15-2014, 08:40 AM   #5
Montgomery , Texas
Based on the Cat link I didn't position my vehicles correctly. When weighing the TT and TV hitched together I position the Suburban entirely on scale number 1 and the trailer entirely on scale number 2. I then unhitched and weighed the suburban. The Suburbans unhitched weight is 340lbs less than the first weight due to my wife and I not being in the vehicle.
Old 02-15-2014, 09:53 AM   #6
K.C. , Missouri
Pat,
If you want to know all of your numbers, including how much weight is being "restored" to your steer axle by the action of your weight distributing hitch, you need three passes:
Truck only
Truck and trailer with weight bars engaged
Truck and trailer with weight bars not engaged
And, as has been stated, the steer axle goes on platform one, drive axle on platform two, and trailer axles on platform three.
PM me if you would like some more details.
gmw photos is offline   Reply With Quote
Old 02-15-2014, 10:12 AM   #7
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Actually the way you pulled on the scale tells quite a lot when taken in account with the suburban only weight.
What this means is that in the act of hooking the trailer, the tongue weight plus the "weight" of the WD hitch, you transferred 1080 lbs from the trailer to the Suburban.
An additional ticket might tell you more about weight transferred to the front axle of the Suburban if you were to weigh both axles of the Suburban on separate platforms both hooked to the trailer and unhooked.
Old 02-15-2014, 10:21 AM   #8
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I think that the most important thing is to see how the combination drives at this point, with adjustments to meet the end of having the unit handle as best as possible.
In my minds eye, the 1100 lb transfer seems pretty close to ballpark right.
Old 02-15-2014, 12:23 PM   #9
Montgomery , Texas
Although, I didn't position the vehicles correctly to establish axle weight, it would appear from the weights that I obtained that I am well within the limits of both my TV and trailer. I am perfectly happy with the way the two handle on the road. I do plan to return and re-weigh based on your recommendations. What I really needed to establish was that my current setup is safe. I have been in the market for a different tow vehicle but it would seem at this point that the only advantages that may give me is the ability to 'get off the line' a little faster.
Old 02-15-2014, 01:48 PM   #10
W , New England
Yup! I think you're looking for 2 pieces of information and have one already (you're not overtaxing your axles). I think the other piece of safety info you want is how to dial in the weight distribution correctly so your front/steer axle is properly "reloaded" based on your tow vehicle manufacturer's recommendation. A rule of thumb is fender measurements (e.g., if your front wheel well is 40" from the ground without the trailer and 42" with the trailer attached, you want it back to 40" with WD applied). But it's best to see the exact impact on the scales to know for sure.
Old 02-15-2014, 10:38 PM   #11
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I think your Suburban will do fine. My 08 5.3 equipped pulls my heavier than average 31 footer just fine, I passed very near the highest point in Texas on Tuesday at speed limit .
Old 02-15-2014, 11:40 PM   #12
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Additionally I would speculate that the tongue weight of the trailer is about 600 lbs, then it might be assumed that the the WD hitch is throwing another 500 lbs on the tow vehicle, which by virtue of geometry is going to push much of this 1,100 lbs forward onto the steer axle.
Old 02-16-2014, 07:21 AM   #13
Livingston , Texas
2nd weight
---When weighing the TT and TV hitched together I position the Suburban entirely on scale number 1 and the trailer entirely on scale number 2. I then unhitched and weighed the suburban. The Suburbans unhitched weight is 340lbs less than the first weight due to my wife and I not being in the vehicle.
If you were not in the Suburban when the first weighing was done,
the unhitched weight should have been 5780+340 = 6120#.
The trailer's weight would be 12340-6120 = 6220#.
The load added to the TV when hitched with WD applied would be 6860-6120 = 740#.
Assuming the WDH causes a load equal to 15-25% of TW to be transferred to the trailer's axles,
the TW would be in the range of 870 to 990#.
Ron
Ron Gratz is offline   Reply With Quote
Truck & Trailer Weights nickmeloy Towing, Tow Vehicles & Hitches 6 04-02-2014 11:02 AM
Bed and couch weights? whitney Cabinets, Counter Tops & Furnishings 4 01-01-2012 10:07 PM
Curious about my weights and their distribution kry226 Hitches, Couplers & Balls 5 03-26-2011 03:12 PM
Axle weights limits vs. combined weight - What am I missing? Section8 Towing, Tow Vehicles & Hitches 25 02-15-2011 08:46 PM
1978 Caravanner 25 Weights Donald 1975 - 1978 Caravanner 1 05-22-2006 12:13 PM
