Old 03-04-2017, 06:17 PM   #43
Gainesville , Florida
Originally Posted by waninae39 View Post
I spoke to the service mgr at the dealer. He stated that it was AS that insisted that "equalizer hitch with 2 or 4 way sway " be the only add on hitch for WD and Sway control that can be used on an AS. All other trailers they sell can use any brand. They stated that they would "allow me to use any other leading brand".
thus i am now leaning on either the
reese pro series 750 lb with WD and Sway control -sku 49902 -$688 installed
or
eaz-lift elite 600 lb with sway control -sku 48056-$install cost unknown yet
any pros/cons on either of these selections
i concur that the straight square tubs are inflexible
Equilizer brand hitch or generic equilizer type hitch? What is four way sway?
Old 03-04-2017, 07:37 PM   #44
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Originally Posted by Pat.Mann View Post
Our Equalizer hitch on Sequoia towing 27FB failed within 1 year with major weld breaks - didn't drop anything, but we felt (dealer concurred) we had to replace it because it looked like it was likely to physically come apart. Not aware of anything that would have caused the failure, no warning, just happened to inspect the hitch during hitch-up and notice the weld breaks. Discovered over Xmas-New Years when factory was closed and no interaction possible, had to replace entire assembly at dealer instead of just the main linkage part, over $1,000 to replace including labor to get back on the road.
Have not communicated with factory or sent hitch back for warranty yet because we are on the road and won't be back at base until mid-April.
Our torque wrench tops at 150 ft-lbs, so we don't have capability to check the high torque on some of the hitch bolts (>300 ft-lbs) so can't do that ourselves. Hitch has seemed to work well, replacement is fine so far; don't know why this occurred.
Don't know about the welds breaking, but a bolt can fail from a fatigue break if not tightened properly. (Once had a Husky weld fail on me, warranty replaced.)
If the required bolt torque, is higher than your wrench's range, use a lubricant on both the threads and the face of the nut, and reduce the torque by amounts as below:
-oil, reduce by 20%.
-bearing grease, 30-35%
-Extreme pressure lube such as C-5 colloidal copper, 'Never Seize' or similar, reduce torque by 40%
This will give you about the same bolt tension as dry-torqueing. Why?
(I like the C-5, myself.)
Only 10% of the applied torque is used to actually tighten the bolt; the rest is to overcome friction; 40% on the nut face, 50% on the threads..
BTW Do NOT use dry torques on lubricated bolts; you will pull the thing apart, or strip the threads.
(Source: Premier Fastener Corp. I was once an agent there, in Canada)
One good place to use this information is in tightening the ball on the head.
Many 2-5/8" balls, have 1-1/4" shanks that call for 450 ft. lbs.
My torque wrench only goes to 250, well short of it. So.........
I calculated that 40% of 450=270 ft. lbs., a tad short of the requirement; but at that figure, that ball 'ain't' going nowhere.
(I needed to sit on the ground, with my foot against the rear bumper, to react against me sliding under the Ford, when I pulled that high a torque.)
MelGoddard is offline   Reply With Quote
Old 03-04-2017, 08:33 PM   #45
waninae39's Avatar
2017 22' Sport
NCR , Ontario
Originally Posted by dkottum View Post
.... Ask them why they don't use Equal-I-Zer brand hitches, and what they recommend.
CAN-AM in London is a 7 hours drive from where i live
I have spoken to CAN-AM. They and another dealer told me to avoid the straight bars as per the comments i made earlier about them. CAN-AM uses the EAZ-lift . it looks similar to the Reese pro model.
so i think that either is good to go with
The service guy that recommends the equal-i-zer drive a 6.2L dually and pulls a triple axle trailer. Thus he told me that he never notices the symptom that others do
my Q5 3L is no match to his TV. Then again my sport 22 is no match to his monster size trailer
that is why i was ask for people to comment so that i can get a better feel with a TV and trailer closer to my size.
waninae39 is offline   Reply With Quote
Old 03-04-2017, 09:33 PM   #46
waninae39's Avatar
2017 22' Sport
NCR , Ontario
how to install reece pro hitch sku 49902
this video walks you through the install steps
and this is review of all the parts
Old 03-06-2017, 12:54 PM   #47
On my laptop these videos haven been 'disabled' by U-tube! Phooey!
Old 03-14-2017, 10:28 PM   #48
waninae39's Avatar
2017 22' Sport
NCR , Ontario
i too get "disabled by utube poster" owner. what gives?
Weight distribution hitch and/or sway control chaeha Towing, Tow Vehicles & Hitches 14 10-11-2018 04:52 PM
Which is better? A sway control hitch or a vehicle with sway-control? Lucky Strike Tow Vehicles 27 08-13-2015 05:34 AM
Weight Distribution & Sway Control, Simple answers please... JimHoek Hitches, Couplers & Balls 52 08-24-2010 10:46 PM
sway control and weight distribution for 22' safari? JeffVH Hitches, Couplers & Balls 12 01-29-2009 05:21 PM
I need sway control AND weight distribution? TBKP's Overlander Hitches, Couplers & Balls 19 07-03-2003 08:54 AM
