Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 04-08-2016, 03:30 PM   #1
centennialman's Avatar
2016 23' International
Centennial , Colorado
Weight Distribution - Help??
I bought my 2016 Flying Cloud 20 in February. I had a different truck then and the WD system was just fine. I have since upgraded to a newer truck and now the round bars are within an inch of the road.
I took it in to the dealer here in Colorado this week and they adjusted the height of the hitch, measured the truck and trailer together and said everything is fine. Problem is that I am still within an inch of the road and even dragged one of the bars at a cross street.
Any ideas on how I can remedy this? Thanks for your assistance!!
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 04-08-2016, 03:59 PM   #2
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Something is radically wrong. The bars that close to the ground is a hazard, I don't have an answer for you except to say that dealer is negligent in saying it's fine. What about your tongue weight? What is your truck & are springs & shocks ok?
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 04-08-2016, 04:19 PM   #3
The tongue weight is fine. Once the trailer and truck are hooked up with the weight distribution system everything is level and measures fine and level....just the bars too close to the ground.
Old 04-08-2016, 04:23 PM   #4
Mrjkq's Avatar
Venice , Florida
How were the bars with your former truck?
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
Old 04-08-2016, 04:31 PM   #5
"Cloudsplitter"
Some photo's would help a lot...close-up of the hitch & distant of the rig...on LEVEL ground.
Weight tickets and/or wheelhouse measurements along with TV receiver & tongue height un-hitched would also help.
Old 04-08-2016, 04:32 PM   #6
The bars were fine with the former truck.
Old 04-08-2016, 04:33 PM   #7
I will get out this weekend and hook everything up and take some photos....this is perplexing.
Old 04-09-2016, 08:20 AM   #8
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I'm guessing that the head of the hitch is angled back towards the trailer too much.
What WD system do you have?
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 04-09-2016, 09:05 AM   #9
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Yes! Photos + the brand/model of the hitch and your truck will help us in helping you.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 04-09-2016, 09:54 AM   #10
batman's Avatar
1964 22' Safari
modesto , California
Interesting problem.
Sounds like the receiver is positioned lower on the new truck.
What is the distance from the ground to the bottom of the receiver on the new truck vs the old?
Taller tires can help raise the receiver. Extreme example, 16" vs 33" diameter tires will raise the receiver several inches. However will cause other issues, speedometer will need re-calibrating, side wall profile flex, etc.
In my opinion you should not have to do this.
What is the make and model of old truck, new truck?
Photo's, yes photo's! Old and new is you have them.
-Dennis
batman is offline   Reply With Quote
Old 04-09-2016, 10:50 AM   #11
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Get your ball height to around 18 1/2 to 19 1/2, and check the "tilt" of the ball...if it's angled back (away) from the rear of the truck that's one example of why the bars are so close to the pavement...
For whatever it's worth.
Larry
Larry C is offline   Reply With Quote
Old 04-09-2016, 11:16 AM   #12
nickclifford's Avatar
1972 31' Sovereign
felton , California
sway hitch advice
i'm in the market for a sway hitch device, any thoughts on this one? #1 rated on Amazon ... Thanks
http://www.amazon.com/Eaz-Lift-48058...A7H5JWAH4KHHP8
nickclifford is offline   Reply With Quote
Old 04-09-2016, 11:43 AM   #13
1986 31' Sovereign
Miami , Florida
Been around forever. Safe and effective when installed and set-up properly.
Certainly not as effective regarding sway as a Hensley or ProPride but roughly 15% of the cost and a third of the weight.
Mike
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 04-09-2016, 04:02 PM   #14
PaulnGina's Avatar
Good Ol' , USA
Basically the same thing I have from Curt Mfg., except mine is the next level up in capacity. I like it very much. Works very well on our 34' Avion.
1987 Avion 34W
Old 04-09-2016, 04:15 PM   #15
Longboard6's Avatar
2015 23' FB Flying Cloud
Sacramento , California
We have the EXACT same issue to include a trip to the dealer for the measurements. I have dragged the bars on so many minor dips that I bent the U bolts holding the chains on. BO replaced the bolts, but the problem remains. I will be replacing the dealer installed hitch asap. Let us know how you fix it. I am having my replacement done by a trusted shop.
When does it start being fun?
Longboard6 is offline   Reply With Quote
Old 04-09-2016, 04:16 PM   #16
Holly Springs , Mississippi
Nick,
This is the hitch of choice by Andy Thomson of CanAm RV, a real pro at WDH set ups. The only difference is Andy recommends 1400 lb. torsion bars if you've pulling with a truck like an F-150, because the wheelbase is so long that strength bars are needed to transfer appropriate weight to the front wheels. He also suggests combining the Eaz-Lift with Husky friction sway bars. I believe him...
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 04-11-2016, 06:29 AM   #17
I contacted the dealer who sold me the Airstream and WD system. They recommended hooking the truck and trailer together. Then, raising the trailer so that there is a "slight" pitch between it and the truck. Then, install the WD bars. It worked fine when I did that. After lowering the two, they measured at level and the round part of the bars are now 9 inches off of the ground.
Old 04-11-2016, 08:08 AM   #18
"Cloudsplitter"
Thumbs up
Am I understanding correctly?.....
You did NOT have your bars under tension originally?
The dealer suggestion is the best way to set the bars with very little effort.....raise the tongue, set the bars and lower.
Old 04-11-2016, 09:17 AM   #19
2020 Classic 33
Box Elder , South Dakota
Steve how about posting some photos of your setup?
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 04-11-2016, 01:39 PM   #20
I originally had them under tension correctly. The dealer had to remind me that they showed me the procedure I outlined above when I was there in February buying the Airstream. I traveled from Arizona back to Colorado that way. Unfortunately, I did not take the Airstream out again until last week and had forgotten raising the truck and trailer together. Once they reminded me, it worked fine. I am so thankful that's what it took to solve the problem.
"Weight Carrying" vs "Weight Distribution" PasoArt Towing, Tow Vehicles & Hitches 2 01-11-2016 08:04 PM
Weight Distribution and Tongue Weight AldeanFan Hitches, Couplers & Balls 28 01-27-2013 10:28 PM
Help! with Weight Distribution Jwestman Towing, Tow Vehicles & Hitches 14 10-20-2012 07:50 PM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 12:11 PM
Refined TV weight numbers = required weight distribution? flyfishfred Hitches, Couplers & Balls 4 01-12-2008 08:13 PM
