Old 04-09-2016, 04:15 PM   #15
Longboard6's Avatar
2015 23' FB Flying Cloud
Sacramento , California
We have the EXACT same issue to include a trip to the dealer for the measurements. I have dragged the bars on so many minor dips that I bent the U bolts holding the chains on. BO replaced the bolts, but the problem remains. I will be replacing the dealer installed hitch asap. Let us know how you fix it. I am having my replacement done by a trusted shop.
When does it start being fun?
Longboard6 is offline   Reply With Quote
Old 04-09-2016, 04:16 PM   #16
2016 25' Flying Cloud
Holly Springs , Mississippi
Nick,
This is the hitch of choice by Andy Thomson of CanAm RV, a real pro at WDH set ups. The only difference is Andy recommends 1400 lb. torsion bars if you've pulling with a truck like an F-150, because the wheelbase is so long that strength bars are needed to transfer appropriate weight to the front wheels. He also suggests combining the Eaz-Lift with Husky friction sway bars. I believe him...
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 04-11-2016, 06:29 AM   #17
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
I contacted the dealer who sold me the Airstream and WD system. They recommended hooking the truck and trailer together. Then, raising the trailer so that there is a "slight" pitch between it and the truck. Then, install the WD bars. It worked fine when I did that. After lowering the two, they measured at level and the round part of the bars are now 9 inches off of the ground.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 04-11-2016, 08:08 AM   #18
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Am I understanding correctly?.....
You did NOT have your bars under tension originally?
The dealer suggestion is the best way to set the bars with very little effort.....raise the tongue, set the bars and lower.
PFC
"Tahawus"
RLC
Step aside Starbucks, this is a job for alcohol.
Old 04-11-2016, 09:17 AM   #19
2016 30' Classic
Erie , Colorado
Steve how about posting some photos of your setup?
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 04-11-2016, 01:39 PM   #20
I originally had them under tension correctly. The dealer had to remind me that they showed me the procedure I outlined above when I was there in February buying the Airstream. I traveled from Arizona back to Colorado that way. Unfortunately, I did not take the Airstream out again until last week and had forgotten raising the truck and trailer together. Once they reminded me, it worked fine. I am so thankful that's what it took to solve the problem.
Old 04-11-2016, 01:42 PM   #21
Hopefully this pic uploads....here is my set up.
Old 04-11-2016, 02:45 PM   #22
Thumbs up
Yep....looks like very little bend/flex in the WD bars. The bars need to bend to transfer weight and raise the rear of the TV.
[U]Thats where measurements[/U] and/or CAT scale numbers will help with determining how much weight needs to be moved.
PFC
"Tahawus"
RLC
Old 04-11-2016, 02:49 PM   #23
Thanks Bob!
I am really enjoying learning about this. I definitely will be doing more measuring and finding CAT scales for weighing. There was so much going on the day I bought the Airstream and I needed to get back to Colorado...I just forgot what they had shown me regarding the steps to hooking up the WD bars etc...
Old 04-11-2016, 03:44 PM   #24
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
It'll all come together. That's what I like about this forum: lots of people willing to help!
The only reason I knew what to do with our Avion was due to lots of experience I had growing up. We went a LOT of places with various travel trailers, including Airstream and Avion. I not only had the pleasure of watching what Dad did, but he also let me do the hitching and setup ( under his watchful, verifying eye! )
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
"I don't mean to sound degrading but with a face like that you got nothing to laugh about"
Whats good for me may not be good for the weak minded.
1987 Avion 34W
PaulnGina is offline   Reply With Quote
Old 04-11-2016, 03:59 PM   #25
LakeState's Avatar
2006 25' Safari
Howell , Michigan
there must be an epidemic out there. Accept no substitutes.
https://www.youtube.com/results?sear...ey+arrow+hitch
LakeState is offline   Reply With Quote
"Weight Carrying" vs "Weight Distribution" PasoArt Towing, Tow Vehicles & Hitches 2 01-11-2016 08:04 PM
Weight Distribution and Tongue Weight AldeanFan Hitches, Couplers & Balls 28 01-27-2013 10:28 PM
Help! with Weight Distribution Jwestman Towing, Tow Vehicles & Hitches 14 10-20-2012 07:50 PM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 12:11 PM
Refined TV weight numbers = required weight distribution? flyfishfred Hitches, Couplers & Balls 4 01-12-2008 08:13 PM
