05-09-2016, 06:38 PM
2006 19' International CCD
Lafayette
Weight distribution brackets and the Propane gas line along the
Hi folks! This is my first actual post, so please bear with me if I'm not doing something about this correctly.
My issue is that my weight distribution hitch bracket for the trailer tongue (which I believe the previous owner used) won't go on because of the gas line. I have read about people bending the line after removing the clips that hold it in place, but I want to make sure that is "ok" to do. Any suggestions would be great.
Thanks in advance!
05-09-2016, 07:59 PM
1993 34' Excella
Estancia
, New Mexico
Photos?
05-09-2016, 09:03 PM
Lafayette
I will post some pictures tomorrow morning.
05-09-2016, 09:18 PM
1993 34' Excella
Estancia
, New Mexico
Bending a propane line slightly should be OK as long as you don't kink it. What brand of hitch do you have? Where exactly is your gas line? Is it pipe or tubing?
05-10-2016, 10:35 AM
2013 30' Classic
Greenwood
, Mississippi
I don't have a photo, but...
The gas line on mine is bent to allow the weight distribution brackets to mount to the trailer tongue.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
05-10-2016, 01:26 PM
2012 30' International
Livingston
Thanks in advance!
My Signature had the same problem when I bought it used. The gas line runs under the frame where the Equilizer bracket is mounted. Whoever mounted the bracket, installed the lower bolt below the gas line instead of mounting it against the underside of the frame. So the gas line hasn't been disturbed but the Equilizer bracket seems to be secure. Good to see someone else brought up the problem. I thought it was just mine but I can see where that gas line could be a problem for rveryone with an Equalizer.
05-10-2016, 01:45 PM
I'm In
, Kentucky
My Equalizer hitch is mounted so the gas line doesn't interfere with it. It's in storage so I can't offer a picture, but I recall noticing that the line is near the brackets. Either a PO or probably the dealership set it up. The hitch is solid and the gas pipe isn't kinked.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
05-10-2016, 01:49 PM
Wise Elder
2010 30' Classic
South of the river
I found it necessary to move the propane line slightly on my trailer to install some of the hitch components.
05-10-2016, 02:09 PM
2013 30' Classic
Greenwood
, Mississippi
I will take a picture after work.
The Equal-i-zer hitch was installed by the dealer.
The slightly bent gas line hasn't affected anything.
Everything still works.
TAC #MS-10
Airforums #70955
05-10-2016, 02:19 PM
Walnut Creek
OB - what brand hitch? The local AS dealer in Fairfield installs/sells Equilizer and Blue Ox hitches and can likely help you with a quick call if the hitch is either of those brands. A slight relocation of the LPG line may well be required, but kinking the line is a bad idea. Not getting firm and solid contact on the hitch brackets is also a problem, so get it right.
Welcome to the forum. Lots of info here and quite a bit of experience with all the hitch brands. Post your pictures and you should get some good feedback on how to resolve the problem.
Travel safe. Pat
05-10-2016, 02:46 PM
2013 30' Classic
Greenwood
, Mississippi
The propane line on my trailer is not kinked, but gently bent.
TAC #MS-10
Airforums #70955
05-10-2016, 03:58 PM
Lafayette
So helpful everyone! Thank you for the warm welcome. I'm working on it right now, and it seems like Glenrms had the same or similar issue. I took some pics but I'm not sure about uploading them?
05-10-2016, 06:44 PM
2013 30' Classic
Greenwood
, Mississippi
TAC #MS-10
Airforums #70955
05-10-2016, 07:59 PM
Lafayette
I figured it out! Thank you for the pictures and all the advice! There was a screw that I removed to remove one bracket in the gas line, slight bend, and I'm good to go.
05-11-2016, 09:09 AM
Walnut Creek
And "GO" is what it's all about. Go safe. Make some smiles out there! Pat
05-11-2016, 09:17 AM
2004 30' Classic Slideout
Fenton
, Missouri
This issue came up several years ago and it was found that many Equil-i-zer hitch installations done by many dealers (mine included) were incorrectly done on Airstreams due to the position of the gas line. Many dealers did not mount the bolt in the hole below the frame, and the only way to do it right was to put a bend in the gas line. Equal-i-zer confirmed that skipping the hole due to the gas line could cause a problem which might cause the bracket to shift on the A frame. I did point this out to my dealer who was not aware that Equail-i-zer did not approve the "hole below" installation and offered to remount my bracket correctly at no charge.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
05-11-2016, 11:37 AM
2013 30' Classic
Greenwood
, Mississippi
Originally Posted by m.hony
The dealer didn't do very much right, but this one thing they did.
TAC #MS-10
Airforums #70955
