Old 05-11-2016, 09:09 AM   #15
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Originally Posted by Otterbrawten View Post
I figured it out! Thank you for the pictures and all the advice! There was a screw that I removed to remove one bracket in the gas line, slight bend, and I'm good to go.
And "GO" is what it's all about. Go safe. Make some smiles out there! Pat
Old 05-11-2016, 09:17 AM   #16
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
This issue came up several years ago and it was found that many Equil-i-zer hitch installations done by many dealers (mine included) were incorrectly done on Airstreams due to the position of the gas line. Many dealers did not mount the bolt in the hole below the frame, and the only way to do it right was to put a bend in the gas line. Equal-i-zer confirmed that skipping the hole due to the gas line could cause a problem which might cause the bracket to shift on the A frame. I did point this out to my dealer who was not aware that Equail-i-zer did not approve the "hole below" installation and offered to remount my bracket correctly at no charge.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-11-2016, 11:37 AM   #17
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Originally Posted by m.hony View Post
Attachment 262297
The dealer didn't do very much right, but this one thing they did.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
"Weight Carrying" vs "Weight Distribution" PasoArt Towing, Tow Vehicles & Hitches 2 01-11-2016 08:04 PM
retro pet trailer line - no weight distribution required Wayward The Pet Forum 4 09-09-2014 10:36 PM
Weight Distribution and Tongue Weight AldeanFan Hitches, Couplers & Balls 28 01-27-2013 10:28 PM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 12:11 PM
Refined TV weight numbers = required weight distribution? flyfishfred Hitches, Couplers & Balls 4 01-12-2008 08:13 PM
