Old 03-12-2019, 08:06 AM   #29
2019 28' Flying Cloud
2014 22' FB Sport
Davie , FL
Originally Posted by ROBERT CROSS View Post
Weights don't lie...read 'em & rationalize as you will.🤔
1st TV
2nd rig no WD
3rd rig WD set
It seems like what you are truing to do is restore the unloaded axle load to the front axle. I believe you should instead try to aim for a 50/50 distribution. A pick-up truck is inherently unbalanced when unloaded because it is designed to operate optimally with a payload. Adding load evens out the axle and tire loads and makes for a happier truck.
out of sight is online now   Reply With Quote
Old 03-12-2019, 09:08 AM   #30
"Hey, I know you!"
Boog's Avatar
2012 23' Flying Cloud
Irmo , South Carolina
Here are my weights (2001 2500HD Chevy regular cab long bed pulling a 2012 23D) without a weight distribution hitch.
I'm not at 50/50, but I haven't lost any weight off of the front axle (added 100 lbs). I get this result by how I load my truck.
https://thisoldcamper.com/
Boog is offline   Reply With Quote
Old 03-12-2019, 09:30 AM   #31
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Your main problem was that you were running crappy tires on the trailer.
The front tires of the truck did not blow out. Go overkill and put really good tires on the trailer. Lightly loaded crappy tires are still crappy tires. When was the last time you had a massive tire failure on the truck?
Old 03-12-2019, 09:41 AM   #32
2014 22' FB Sport
Davie , FL
Yes. those tires were bad. It scares me to think I dragged that trailer thru the Yukon with those tires. Fortunately I didn't have an incident until I got back to civilization. Unfortunately one of those required changing the tire at 9 degrees fahrenheit. Bummer.
My new Airstream has GY Endurance class E's. Hope this problem is solved.
Old 03-12-2019, 10:46 AM   #33
2014 22' FB Sport
Davie , FL
It's interesting to note the unloaded truck weight distributions presented so far:
GMC 2500: 56/44
F250: 56/44
Ram 2500: 62/38
Old 03-12-2019, 11:10 AM   #34
fwjumper's Avatar
1998 34' Limited
Lawrenceville , Georgia
[QUOTE=out of sight;2218910]No WDH for me. That would unbalance my tow vehicle and I would be riding down the street with overloaded front tires and underloaded rear tires. Not a good idea. Not to mention putting unnecessary load on the trailer tires.
The beauty of WD hitches, is that they are ADJUSTABLE, therefore can be tweaked to optimal settings, as defined by you. Sometimes these settings change, due to differences in loading of the trailer, holding tank levels, etc. Trying to optimize weight on the TV by adjusting tongue weight, is unrealistic over time. Congrats on the new rig with dual axles and GYE tires. You'll relax more.
fwjumper is offline   Reply With Quote
Old 03-12-2019, 11:18 AM   #35
AirMiles's Avatar
2017 25' Flying Cloud
Apollo Beach , Florida
GMC 2500: 56/44
F250: 56/44
Ram 2500: 62/38
I tried to find an actual Ram 2500 Scale ticket to verify that a 2500 Ram would be so front heavy. I found this one from a 2012 Ram 2500 Diesel: http://www.airforums.com/forums/f464...ml#post1285714
First my vehicle specs are (2012 Dodge Ran 2500 Diesel): GVWR 9600 lbs
Front Axle - 5500 lbs
Rear Axle - 6010 lbs
Combined weight - 1961
Scale Readings;
Truck Only - Steer Axle - 4780 lbs
Drive Axle - 3880 lbs
Gross Weight - 8660 lbs
Truck and Trailer - Steer Axle - 4860 lbs
Drive Axle - 4800 lbs
Trailer Axle - 8860 lbs
Gross Weight - 18,520 lbs
This puts a Dodge Ram 2500 Diesel at 55/45, the same ballpark as Ford and GM.
2017 Flying Cloud 25FB (Miles) 234 nights 31,732 miles
400W Solar, 230AH 6V Batteries, PD4655 Converter, Champion DualFuel Generator, ProPride 1400# Hitch, 16" Michelin's
2019 F250, 6.7 Power Stroke, 4x4, 1.5" Leveled (Sully)
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is online now   Reply With Quote
Old 03-12-2019, 11:21 AM   #36
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
[QUOTE=fwjumper;2219189]
Again, you should consider a WDH for that size AS, and don't go by the published specs on either AS or your TV; weigh your rig with and without the AS....just saying. We all want you to be safe on the road...a WDH will help adjust the weight properly on your TV for steering/controlling while in tow, and it will also provide more stability with winds and semi unstable air surges, when dialed in... The old saying, "pay me now or pay me later comes to mind"...don't risk your trip/TV/AS on mfg. written specs for a vehicle...verify. Oh, and tires/proper pressures are also important also...
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 03-12-2019, 11:55 AM   #37
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
🤔 Determining your WD with someone else numbers....now we ARE off track. 😂
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 03-12-2019, 11:57 AM   #38
2014 22' FB Sport
Davie , FL
Scale Readings;
It's possible that he weighed the truck with a load in the bed. Per the following chart my truck configuration is 4700 front and 2918 rear.
https://www.ramtrucks.com/content/da...Ram%202500.pdf
Old 03-12-2019, 02:05 PM   #39
2007 27' International CCD FB
San Diego , California
I thought I'd look at weight distribution in a different way by looking at tire loading rather than vehicle loading. It turns out that the most heavily loaded tires, measured as a load percent of the tire load rating, are the front tires of my tow vehicle. What this means is that if I use a weight distribution hitch I will make the problem worse. With the trailer attached on the hitch ball, without a weight distribution hitch, the front tire loading is reduced to approximately equal to the rear TV tire loads. The % of each tire load to the max loading rating of the tires then comes out to:
trailer tires 56%
front TV tires 65%
rear TV tires 65%
The only way to further equalize the tire loading percentages would be to take cargo weight from the TV and put it over the axles of the trailer.
While an interesting concept, my opinion is that this is not really a significant parameter to be concerned about in adjusting weight distribution.
It's understood that there's significant margin in tire capacity generally.
The major balance of concerns for the amount of WD to be applied is stability gained vs. maintaining sufficient articulation in the hitch. That's to say that too much WD applied is not necessarily a good thing as it greatly stresses major structural elements. Aligned to your point, unnecessarily puts too much load on the front axle, potentially causing risk in dynamic performance in an emergency (e.g. oversteer).
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i
Rear Bumper Hitch
pteck is offline   Reply With Quote
Old 03-12-2019, 02:22 PM   #40
jcl
Vancouver , British Columbia
I wouldn't put stock in the 62/38 number until the vehicle was weighed, and so included all options and installed equipment.
Then, I would consider whether the truck will ever be driven solo. If so, I would be concerned about the poor weight balance of the truck itself, and so would install a topper, or ballast in the bed, for both safety and driving comfort. Having done that, I would be unlikely to remove the ballast or topper when towing, so that corrected weight balance would be what I would work with as I started to consider how much FALR would be appropriate.
jcl is online now   Reply With Quote
Old 03-12-2019, 02:54 PM   #41
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
If the front axle is not overloaded to start, WD will not overload it since the goal of WD (used by some) is to restore 50%-100% of the weight lifted off of the axle when the trailer was hooked up without WD. The most one would see on the front axle would be the original weight.
I get it about 50/50 loading. I'm going to try that when I can get a good methodology of tuning the hitch real time.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 03-12-2019, 02:55 PM   #42
AirMiles's Avatar
�� Determining your WD with someone else numbers....now we ARE off track. ��
Just trying to show that the glossy brochure numbers are not real life. The OP needs to weigh the truck and post the scale tickets. Without scale tickets, it didn't happen. We're all wasting our time here.
Also, the truck needs to be packed for camping, all passengers, loaded bed . . . Who cares what a bare truck weighs.
"Weight Carrying" vs "Weight Distribution" PasoArt Towing, Tow Vehicles & Hitches 2 01-11-2016 08:04 PM
Weight Distribution and Tongue Weight AldeanFan Hitches, Couplers & Balls 28 01-27-2013 10:28 PM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 12:11 PM
Refined TV weight numbers = required weight distribution? flyfishfred Hitches, Couplers & Balls 4 01-12-2008 08:13 PM
Reducing Tongue Weight by Loading Rear of AS FranzB Towing, Tow Vehicles & Hitches 20 11-11-2006 12:37 PM
