Old 05-31-2017, 12:21 PM   #15
AlanMcD's Avatar
Cincinnati , Ohio
Originally Posted by MWBishop View Post
2017 F250 has max tongue weight 1500#s with 2 1/2" receiver.
According to the sticker on the hitch from the factory this 1500 lbs is correct and it is the same with or without WD. WD is not necessary with the new '17 Super Duties.
-Alan
AlanMcD is offline   Reply With Quote
Old 05-31-2017, 01:01 PM   #16
Anna Maria , Florida
Originally Posted by kaosinacan View Post
We have ordered a International Signature 30 and will tow it with a 2017 Ford F250, and was wondering what is the best weight distribution hitch and anti sway bracket to use?
I have had a similar combination of TV and Trailer. Experimented with three different hitches and the best considering initial investment and overall performance was the Blue Ox by far.
Trunion Bar WD hitches are less expensive and perform well however they give the trailer a very rough ride. I found out the hard way.
And pulling with an F-250 you don't need to spend thousands on a hitch, you have plenty of heft giving you substantial margin of safety.
franklyfrank is offline   Reply With Quote
Old 05-31-2017, 01:07 PM   #17
Dropping right on the ball our 2017 26U only raises the front of our 2017 F250 3/8s inch and only squats the rear 1 3/8s inch, therefore no WD needed. Drove 800 miles home in storms, heavy wind, and high traffic with no sway issues (of course there will be a little buffeting from time to time, but not unreasonable and expected). So while anti-sway would be an added safety feature, decided it would be overkill as well. Therefore for time being we are just going to drop on the ball and go. The AS tows like a rock behind our F250. So may want to first try without WDH, but it's personal choice of course.
A 30' Airstream has different dynamics than a 26'. It will wag the dog so I would say don't experiment use a WD hitch.
Old 05-31-2017, 01:19 PM   #18
Sonoma Co. , California
Your trailer and TV are well matched for GCWR, so there is no need for WDH. The slight change in pitch can easily be corrected with airbags if it bothers you at all. Also, your late model TV has enhanced electronic stability control, so additional sway control would be self defeating. In your situation, I would not be thinking of adding the hassle and potential downside of a WDH & sway bar either. The OP with a larger, heavier trailer may not have the choice, tho. As others have warned, getting the set-up done correctly is absolutely essential.
USAtraveler is offline   Reply With Quote
Old 05-31-2017, 04:55 PM   #19
Renton , Washington
Equalizer/Anti-sway hitch
The best (and only except for Hensley) Anti-sway hitch is the ProPride 3P Hitch. Blue Ox, etc. are NOT anti-sway. Reason: you still have the ball hitch swivel point; therefore, the trailer can initiate movement side to side, which you want to eliminate. Only your tow vehicle should initiate movement, e.g., for a turn or when backing up. The equalizer bars will create some stability if adjusted properly, but they will not eliminate sway. You get a strong enough side force and it will sway and possibly fishtail. I tow a 30' Classic with a 3500 Duramax Silverado with zero issues no matter what the side force is.
Dashwa is offline   Reply With Quote
Old 05-31-2017, 06:20 PM   #20
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
2015 2500HD, 2015 30' Bunk, ProPride. Been there done that with most of the others mentioned including without. Worth every penny and hassle for a relaxing, rock solid and ultimate safe towing in even the most sever conditions.
2015 30' FC Bunk, Dual A/C, Full Awning, RV550, Sleep Number, ProPride, Nokian Rotiiva AT 15" Tires
2015 Chevrolet 2500HD 4WD Duramax/Allison LTZ Crew Cab Short Bed, Huper Optik, Bull Dog Spray In, Roll-N-Lock, Full Amsoil, Denali SoundBomb, Yakima
2012FB is offline   Reply With Quote
Old 05-31-2017, 06:24 PM   #21
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The only people I know who had their Airstream 28 go into a rapidly increasing sway and the whole thing rolled down the side grade were towing with an F-250. Traveling downhill in AZ, on a curve around a mountain, sudden extreme sidewind, the trailer quickly increased oscillations widely and they lost control. She had severe injuries. They did have a w.d. hitch.
"Heft", high center of gravity, vague steering, and solid axle suspension only means it will be harder to control when things go out of control. Put the chances on your side, get a high quality w.d hitch with sway control device or Hensley/ProPride with sway elimination design and quit fooling around with this "you don't need it with that truck" advice.
Doug and Cheryl
Old 05-31-2017, 06:27 PM   #22
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
2017 2500 ram /13 31' classic, with a 3" lift kit and 16" michelins work well with the Reese duel cam.....
Old 05-31-2017, 07:49 PM   #23
VaTravelers's Avatar
2017 28' International
Virginia Beach , Virginia
I pull my 28 International with an equalizer and an F250 - hardly know she's behind me.
VaTravelers is offline   Reply With Quote
Old 06-01-2017, 04:23 AM   #24
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
Watch some Pro Pride You tube videos, cheap education.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 06-01-2017, 06:05 AM   #25
MWBishop's Avatar
Huntsville , Alabama
Good point. I imagine the 30 does behave differently. So with the 30 the WD may not be needed for the F250, but sounds like the Anti-sway would be.
2017 Airstream 26U Twin
2017 F250 Platinum
MWBishop is offline   Reply With Quote
Old 06-01-2017, 07:04 AM   #26
Gainesville , Florida
Sure am glad we discuss the same things continuously, gives this bored, weak minded person something to do. Keep it up, I'm easily entertained.
Old 06-01-2017, 07:09 AM   #27
Half a Rivet Short
Carlisle , Pennsylvania
Hi
This way we can talk about them in a different order each time
Old 06-01-2017, 08:28 AM   #28
Mattirs's Avatar
2016 25' Flying Cloud
Fairfield , California
Hi
Also, the state of mushin, the beginner's mind, I pick up new things each time be they new or forgotten or a new insight of same facts.
Matti
Mattirs is offline   Reply With Quote
Anti-Sway Bar or WD with Anti-Sway for 19' FC? CanonFan Towing, Tow Vehicles & Hitches 32 09-20-2016 05:29 AM
Anderson Weight Distribution Anti-Sway Hitch vuch Hitches, Couplers & Balls 52 10-23-2015 11:08 AM
anti-sway/weight distribution questions quincy799 Towing, Tow Vehicles & Hitches 24 09-12-2014 08:59 PM
Weight distribution & anti-sway hitches - What changed from the "old days"? Phoenix Towing, Tow Vehicles & Hitches 14 09-10-2014 05:50 PM
