Old 04-29-2014, 05:59 PM   #1
2004 25' Safari
prattville , Alabama
Weight distribution
If I add more tension to the bars will that move weight from rear axel of tow vehicle to the front axel? I have a hensley arrow hitch by the way. Thanks
bearrand is offline   Reply With Quote
Old 04-29-2014, 06:44 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Hi bearrand.
The process actually distributes weight across all the axles of your tow vehicle and trailer. With the Hensley, you can dial in as much as you need to do this effectively.
Here's an etrailer article that might be helpful:
https://www.etrailer.com/faq-weightdistribution.aspx
Good luck!
Old 05-03-2014, 12:15 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Increasing tension will move weight from the TV rear axle. Some weight moves to the front TV axle, some to the trailer axle.
Old 05-04-2014, 07:43 AM   #4
2004 25' Safari
Thanks Bill M
Thanks Bill That's what I thought. I spoke to Hensley rep. who said it does not matter if you use the tension bars or not and to be careful not to put too much tension that will cause front end problems.
Weight Distribution and Tongue Weight AldeanFan Hitches, Couplers & Balls 28 01-27-2013 10:28 PM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 12:11 PM
Refined TV weight numbers = required weight distribution? flyfishfred Hitches, Couplers & Balls 4 01-12-2008 08:13 PM
weight distribution Craig Hitches, Couplers & Balls 2 04-14-2003 06:57 PM
Education on Sway & Weight Distribution John Our Community 7 01-28-2003 02:48 PM
