Old 01-04-2016, 11:53 AM   #1
2015 25' FB Flying Cloud
Paso Robles , California
"Weight Carrying" vs "Weight Distribution"
I've just moved and tuned my Equilizer hitch from my old TV to my new Ford 150 (3.0 EcoBoost, 4x4). The plate on the hitch says 500# tongue and 5,000# max gross trailer weight without WD (referred to as "weight carrying") and 1,210# tongue and 12,100# with WD. The tongue weight is obviously 10% of the max gross trailer weight. I will always tow my 2015 25' FC with the WD, but normally tow other "work" trailers with only the ball. I've not seen the term "weight carrying" before. Am I really limited to 500# and 5,000# without my WD?
PasoArt is offline   Reply With Quote
Old 01-11-2016, 07:55 PM   #2
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
YUP! If nothing else, it's a legality.
If you have an upset, try explaining THAT one to the prosecuter in court.
MelGoddard is offline   Reply With Quote
Old 01-11-2016, 08:04 PM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
For towing without w.d. I would stick with the spec on it so you don't damage the receiver. It isn't just the weight sitting there, but the additional weight when bouncing down the roadway. If you have a need to tow something heavier many people replace the factory hitch with a stronger after-market hitch.
Doug and Cheryl
Weight distribution & anti-sway hitches - What changed from the "old days"? Phoenix Towing, Tow Vehicles & Hitches 14 09-10-2014 05:50 PM
Weight Distribution and Tongue Weight AldeanFan Hitches, Couplers & Balls 28 01-27-2013 10:28 PM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 12:11 PM
Refined TV weight numbers = required weight distribution? flyfishfred Hitches, Couplers & Balls 4 01-12-2008 08:13 PM
